Gluing up stuff strategy- panels
Ron, this post is for you and you will find that I have no exceptional talents in this matter, but I do have lots of experience.
Let's start with the top. It has four boards. First I glued two together to make two pairs and then ran them through the planer to finished thickness. This step more or less cancels out any bows and humps in the pairs. ( I always try to thickness plane two or more rough- planed edge glued boards as a first step in making a wide panel. This step tends to cancel out wiggles in both pieces. Alternatively flatten on jointer. Not a practical option with these massive pieces. If the boards are flat to begin with I would just plane them to finished thickness and carry on. )
Now I have two wider pieces to glue together to make the final top. I lay these in the clamps and, without glue I snug the clamps to see what problems I have to contend with. I find that I can always make one near perfect joint so I never glue finished planed stuff more then one joint at a time. It is hard for me to explain all the tricks to coaxing the edges into alignment as the clamps are slowly tightened. But going slow is a key element. I want to correct any misalignment as the clamps are snugged. Once yellow glue grabs only steady pressure will move the joint. Bashing with a mallet is useless. Steady pressure works.
Sometimes I stand on the assembly as I snug clamps, or pinch the ends together with a clamp, or clamp against the bench. What ever is necessary to put pressure where it is needed to do some coaxing is employed. I consider it a disaster if the glued edge is more than 1/64 out of alignment. In the case at hand trivial scraping leveled the joint, but this assembly came together extraordinarily well (maybe because I fussed with it plenty knowing this strong stuff would not coax easily)
