gluing up panels wider than your planer
Lars Parrington
what is your prefered method for keeping the joint(s) aligned so as to minimize time spent flattening by hand afterwards? furthermore, how much effort would you expect to spend on the hand flattening? are you just taking a scraper down the length of the joint(s), or breaking out the jack plane and starting from there?
these are the options that seem obvious to me:
1.) tongue and groove. i like that it can be cut by hand. i worry about being able to see the joint at the end of the board and about the joint not closing tight on both sides of the groove. perhaps 2 grooves with a separate spline would eliminate the latter concern.
2.) biscuits. ear plugs required. with vacuum attachment on biscuit joiner, it could be quick, easy, and not messy. will have to plan out locations of any crosscuts in advance to avoid putting a biscuit there.
3.) nothing. my usual method, which i am hoping to improve upon. i've had some limited success by tightening the middle clamp first and working my way to the ends, torqing the ends of the boards to adjust the alignment at each clamp as i go.
i ask because i have a couple casework projects coming up that will involve 18" wide panels joined with through dovetails at the corners. i am leaning towards buying a biscuit joiner. i do have a matched pair of tongue and groove planes that could probably be made to work with a few hours of fettling.
