Re: Don't think I can build a Roubo
TomD
A gallon of milk weighs 8.4 pounds, I am told, and an 8 foot 2x4 weighs 9.6 pounds. If these are the limitations you are working with, you have your work cut out for you.
I own a lot of cast iron machines, there are few of them I can lift, and those that I can, I really should not have lifted. Get yourself an engine crane, or something, and then you can lift anything , and roll it around, depending on your layout. I'm medium strong, and as a result waited far too long to get materials handling stuff in the shop.
I don't really agree with most of the characterization of stuff in the above posts. There is nothing egotistical about big benches, etc... I was shaking my head while reading most of the responses. If anything, Woodworking benches should be heavier that they are. We may not see ourselves as the violent people we are, but we have the same needs for precision, and far greater needs for force than the metal working crowd, and they use metal and granite tables. Sure it takes far more force to cut metals, but it proceeds either by file, or scraper, or some huge machine. You don't see thos guys singing hammers, at least not in the machine shops.
The two methods that require the least energy to make a large bench are using the biggest stick you can find, and moving it with power. This is easy, because you don't have to do much to it. Depends on initial condition, but you just dress it, leave it on it's legs, and you are good to go. The other method is to assemble a top out of very small pieces, plywood is ideal. What most of us used are heavy pieces of wood that get glued up. There are many pieces of wood that need moving, over and over. And every clamp would be beyond your weight limit, every piece of wood also.
This is a weird, and cluttered pic. It shows my bridge crane, that I just finished using to raise a 200 pound sewing machine head to my second floor. So part of the story is materials handling. But the other part is that the right hand side of the crane is supported by a beam that runs along the wall, and is a 5x8 beam made of 3/4" plywood, All the parts were cut out at HD on their saw, except the bulkheads in the beam were sized on my saw. All the parts are light, and even the beam is a little light, though over your limit. It feels solid, is dead straight and flat, does not move, and was quick and easy to make. Vastly better than a door. It is part of a Japanese bench that you can see one of the saw horses for, over by the orange box. You make your base, glue up your parts on the base, and you do not have to move it from that point. Of course you can make it any width you want, and add any vise, crotchets, whatever.
This pic that I got off ebay shows the front beam of a trimaran under construction. The loads on such a structure are immense. Yet look at how simple the design is, and how light the materials are. So if you make a bench out of 3/4 inch ply, with 3/4" ply bulkheads every foot, you have a massive structure. I like to pair up the bulkheads in the area I expect to mortise over, usually the right hand leg, so it is solid right down to the foot.
That said, there was a bench in Fine Woodworking, that got a lot of play a few years back, it was made of 2x lumber, and had some innovative thinking. I forget what it was called... That was easy:
http://www.finewoodworking.com/Workshop/WorkshopArticle.aspx?id=28530
Not too much heavy lumber there. Some good ideas, I would still like more beef, could be lightweight engineered beef.
