New WoodChat!
Cedar chest for tools
Michael Donaldson
Michael Donaldson
I have a large blanket chest that my dad made, it is made of walnut, with a cedar lined bottom. I am thinking of converting it to a tool chest and adding a till to it. Are there any issues with the cedar and the tools, bearing in mind that about on third of my hand planes are woodies?
Re: Cedar chest for tools
rononkokomo
Don't think so. The only place I know where cedar can cause problems is if you try to use an oil varnish finish in the box. It will not cure. I don't believe it will have any negative effect on tools.
Ron
Michael Donaldson
Thanks.
Patrick Gibbons
Eastern red cedar or aromatic cedar is a remarkable wood. It shouldn't harm anything. I doubt you'll be cutting into it but if so keep in mind the wood can be quite brittle and prone to splitting.
Show pictures when you're finished
Question re cedar chests
Patrick Gibbons
Has anyone ever found any scientific basis that cedar repels moths?
I think its more camoflage than repel...
John in NM
The way I understand it, the cedar oil tends to cover the odor of wool, which is what attracts the moths - same way the smell of a bakery tends to attract humans. Putting your wool in a cedar chest is roughly like placing a bakery next to a paper mill :D
Dale Lenz
Re: Question re cedar chests
Dale Lenz
There is no evidence to my knowledge. I don't argue when someone wants something built out of ERC due to bug repellence. If they ask me what I think, then I tell them what I understand.
When going to school for a BS in forestry a girl in our class wrote a paper over ERC and that’s when I found out that information. Its knowledge I normally don't boast about in an ERC shop, they don't want to hear it! Perception is difficult to change. I say, let it work for you, if possible.
roger lance
Michael.....I think you should reconsider and use your dad's chest for what he intended....blankets/bedding/clothes. Design and SIZE your own tool chest to hold what you now have....and will probably have....it will be much more efficient that way.
Brian from Monument
Last time I heard tools don't come with moths. Nor are the moths interested in the tools.
At least that is one reason why one would have a cedar chest.
Michael Donaldson
Michael Donaldson
The problem is that we don't have room in our house for it, so it has been sitting in my shop, so I figured I would put it to good use. We will be moving as soon as I find a job (right now my most promising job leads are in Wichita and Denver). Maybe our next house will have room for it to be a blanket chest, maybe it will be a tool chest. We'll see.
It might
Bill Tindall
All depends on whether the cedar oil has any attraction for metal. If the cedar vapors set down on steel the resulting film will retard or even prevent rusting from simple humid air exposure by displacing the adsorbed layer of water that enables rusting. If nothing else it would make tool boxes smell nice.
Patrick Gibbons
One characteristic of a tool chest is that it's light as possible. The tools add enough heft. Your walnut chest would be heavy to begin with. I'm not against repurposing but make sure you don't regret the change. One day a child may want a blanket chest.
