My first dovetail joint. *LINK*
Michael Donaldson
It is absolutely horrible. It is so bad, it's funny. I have a lot to learn. a lot.
http://thatwoodwork.blogspot.com/
Michael Donaldson
Re: My first dovetail joint.
Leo Cuellar
For a first attempt, that is actually pretty good. I haven't done one in so long, I doubt I could do any better. The main thing is: if it is something that you really want to do, keep on practicing!!! Mark extra lines in the waste area and practice your saw control. It does not need to be part of a project to be valid, just do it. We all tend to be our own worst critics as well, so don't beat yourself up over it, if it takes a while.
Not bad
Jack Guzman from Maine
Michael,
The only way that could be bad is if you didn't improve. You have to start somewhere. When I first learned I followed Ian Kirby. He said to draw alot of lines in a typical dovetail angle on the edge of a board and cut,cut,cut. Stance and the way you hold your saw are very important. The only other thing I needed was to concentrate on marking. Practice until you get your muscles to memorize the movements. ---Jack
We've all been there
Patrick Gibbons
You did very well. In a year or two you'll be amazed how far you've come. The only real question to ask yourself is, "are you having fun?". It's obvious you are.
Dale Lenz
I'd be Proud of them Mike. I believe my first DT, I kept in my shop laying around for months just to review from time to time.
Jerry Gibbs
My first dovetail joint ( literally the first) is on the wall at the Marc Adams School of Woodworking for all the world to see. It has my name on it. The only consolation is that there are worse. Jerry
Brian Anderson Gunsmith
Dovetailing is a skill.
You need to practice to improve it.
If you are having fun keep going.
Remember most of us that already know how to do dovetails made dovetails that are well not our finest hour.
To me it looks like you might want to set your marking gauge a bit wider. IE put the striking edge outside the mating piece not at the edge. It looks like both tails and pins are short.
But that is part of the learning experience.
roger lance
Michael....you are doing very well....you are moving up the learning curve quickly....its fun to watch your progress and enthusiasm....keep going !!
Attaboy !! Keep at it
CStan
I suspect your pins are fatter at the baseline than they are at the end of the board. A bit more paring and checking may have made these go together much better.
Try this using thinner stock. Plane it down to a weak 5/8's and give it another shot. Mind square and plumb with your sawing, as it applies.
CStan
It it's not glued take it apart and put your small square on the pins and tails to see where your sawing is bad. Sawing inside the line - easy mistake to see - you usually realize it while you're still sawing. Sawing off perpendicular or off square (or not marking the endgrain of the tailboard square) maybe not always readily apparent before or while you are underway making the joint.
In other words, you need to do a post-mortem to figure out all the mistakes that need to be corrected.
