Re: Steve uses shellac
barryvabeach
I have done a fair amount of string inlay, with both mahogany and walnut in the field. After several different attempts, with limited success, I find that the best approach for me is to complete the piece and sand it, stain the field, apply shellac to the field, then the top coats of finish. When everything is dry, I then cut the slots for the string inlay, then glue in the inlay, trim it flush with chisels and card scrapers. There are some areas where I have trimmed too deep and removed some of the stain from the field, in those areas I tape off the inlay, and using an artist brush, apply the stain, shellac and finish to the field. When that is done, I take off the tape, and I use an artist brush to apply shellac to the inlay, which should prevent any stain from migrating onto the inlay, then spray finish on the whole piece. This is a photo of a sideboard I am working on. The inlay on the drawers was done this way. Mahogany veneer, medium walnut transfast dye, blonde shellac, then several coats of water based top coat.
