New WoodChat!
Is anybody making anything?
Re: Is anybody making anything?
A mess
We're in the demo stages of remodeling a room. Chimney coming down, etc. The only woodworking involves 2x4s and nails. Pretty stuff later.
Re: white pizza last saturday - no pictures
coupla small projects of little interest here
Boarded Furniture
Patrick Gibbons
I've been working on Xmas presents. I wanted to make projects that were simple but nice and decided to build some nailed projects. I'm putting together some benches in different styles. One is a bench with storage in a Shaker style, another will be colonial and another I'm going to try and imitate a 16th century style. After that I want to try a blanket chest. I've just started a new job and at this moment it's about 100 degrees outside. I'm not getting a lot done. I want to share pictures of the projects as I finish them. Stay tuned.
Yep
James Watriss
Wrapping up a saw and jig for cutting tenon shoulders, inspired by some tools I saw demo'd by a French chair maker.
Also, making new cherry legs for an Italian made office chair.
And making patterns for a kiddie rocking toy, shaped like a boat.
And wrapping up a trestle side table.
David Barnett
(Message Deleted by Poster)
Home improvements
I'm rehabbing some windows in our home when I'm not dealing with a thousand other things. I'm gathering momentum though for a jewelry box that I'd like to make by the end of August. More on that if/when it happens.
I'm also thinking a lot these days about some great lumber in my shed that is crying to be furniture. I have a very nice stash of narra, as well as walnut flitches, Indian rosewood, birdseye maple, wormy chestnut and tons of oddball pieces. Eventually, I want to build a dresser that I designed twenty years ago. The original drawings were lost in my shop fire, but I've never forgotten the design.
I'm wondering how people decide what to build next. Now that I'm not building furniture and woodwork for a living, I don't have a set agenda. When I got out of the business, I vowed that I would only build pieces I wanted to make, and only for myself. Often my efforts these days are more design and construction oriented, with concentration on interior millwork, cabinetry and maintenance on our old farmhouse. Every now and then, when I get a (what seems to me) great idea, I consider making a speculative piece for possible sale.
I'm always designing, building or turning something, but my schedule doesn't permit concentrated efforts very often. It helps to see what others are up to, to get the juices flowing. Thanks for bringing it up.
Re: Vise Enhancements
William Duffield
Like Ellis, I've been mostly working on home improvements (using mostly power tools, so I won't bore you with that here) but Im also making a new pair of handwheels for my Moxon vise.
The old ones (the third iteration of this vise) were hard maple, 4" in diameter. There's one of those laying on the lathe bed.
The new ones will be 5" in diameter, and made from bloodwood, which should give them enough additional angular momentum with a flick of the wrist to push the front jaw closed on the stock. They don't work as well as cast iron, but I'm getting closer. Seasoned bloodwood is a bit frustrating to turn, since the shavings are pretty dusty and I don't like to spend the extra sharpening effort, but its density is an advantage. They'll be the same shape as the maple ones when I'm done, with no sharp corners.
NICE!
Describe the chucking arrangement?
Hi William,
First, are those truly bloodwood or are they padauk? And, how do they attach to the shafts of your Moxon vise?
I'm considering building one of those and I would like to know more about the design.
small progress
GolfSteve in Calgary
craigd
Mitre planes
craigd
Finishing up a set of three mitre planes, two @ 20º, one @ 12º, all with Apple (1/2", 7/8" & 1 1/2").
Re: Describe the chucking arrangement?
William Duffield
I was hoping to pique some curiosity with this teaser!
There are lots of levels of complexity hidden herein. First, the handwheels and the rest of my Moxon vise hardware are inspired by the Benchcrafted hardware, but mine uses 3/4"-10 UNC threaded rod and matching nuts from the Orange Borg, instead of cast wheels and acme threaded nuts and threaded rod. Mine's not nearly as elegant, but it works OK, and it's price is an order of magnitude less. http://benchcrafted.com/MoxonVise.html
As for attachment, the bencrafted document on installation of their Moxon vise is inspirational. http://benchcrafted.com/PDF%20Files/Benchcrafted%20Moxon%20Vise.pdf
Instead of building a whole Moxon vise, per Jameel's design, I just build a half-a-Moxon and attached it to the front of my Bench-on-Bench.
For sure, it's bloodwood. It stays red, and even fully seasoned it sinks if I drop it in a bucket of water. The distorted color in the photo probably has something to do with the lighting over my lathe.
Info and photos on the chucking of the handwheel in the vise to follow. Stay tuned.
The design, construction and use of the bench-on-bench is another story.
John in NM
I'm splitting my time between drywalling and making grips, though I use a lot of powertools for those :D I do use cabinet scrapers extensively on some of the stocks though.
William Duffield
It's going to take a few steps, with illustrations, to get to the chucking.
Some of the photos are from the construction of the maple handwheels and some are from the new bloodwood wheels. It should be obvious which are which.
Theses wheels are hybrids, mostly wood, with a steel nut inset in the front face to engage the threaded shaft. I roughed out the wheel on the bandsaw, drilled three concentric holes with forstner bits on the drill press, mounted the nut, built a mandrel, chucked the assembly in my scroll chuck, and trued up and shaped the wheel on my lathe.
The sketch with measurements is not to scale. The major diameter of this one is 4", while the new ones are 5" in diameter. Using a 2" Forstner bit I drilled a hole 1/2" deep, half the diameter of the tire. This hole would be 3" in diameter for a 5" diameter wheel. Then I drilled a 1" diameter hole 5/8" deep. 1" is the largest bit that is smaller than the wrench that fits the nut. This bore MUST have a flat bottom. The nut is 5/8" thick. Then, I drilled a 3/4" diameter hole all the way through. This is the major diameter of the all-thread.
All the curved lines I've sketched on the note pad will be taken care of on the lathe later.
William Duffield
Step 3 - Install the nut in the wheel blank.
For this, you'll need two nuts and a length of all-thread. Put 'em together and tighten 'em up. With a marking knife, scribe the outline of a nut at the bottom of the 2" diameter hole.
Chop out a hexagonal mortise to fit the nut snugly. It is important to keep the bottom of the mortise flat and perpendicular to the 3/4" diameter through hole.
Epoxy the nut into the wheel, using the all-thread and the backup nut to keep it aligned while the epoxy kicks. Be very careful not to get any epoxy squeeze out into the through hole or onto the all-thread. If you goof up, disassemble it with a heat gun and try again.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
I have several projects on the bench right now, this weekend I will be fitting some framing parts for a special picture, maybe sharpen some chisels...hmmmm, flatten some stones first... all after hit the gym of course..
Take care,
Jim
Re: Not furniture, but wood  with simple tools
TomD
I'm working on a longbow, and amas for a folding trimaran,
Speaking of panniers for bikes here are a few bike projects from over the years.
Plywood panniers for my mom's bike, very light and sturdy, and still working after 20 or more years. The red rack is a porteur touring rig I made for my touring bike in 07. And also a pic of bamboo fenders from 05. The fenders had a lot of hand work in them, and the rack was a lot of hand joinery. The panniers were composite which involves a lot of handwork, though the woodwork was not probably hand work for the most part.
TomD
"The design, construction and use of the bench-on-bench is another story. "
Seems like it might be the better part of it, have you covered that elsewhere?
Ooh! Oooh! Got to use some hand tools today!
One wall of our remodel has been ready for siding for a while, but I kept getting distracted by other parts of the project. Today, while our yard worker was loading chunks of concrete from the demolished chimney (the truck's now hunkered down with the first half of the chimney chunks) and our younger son was working on framing for the next wall, I put up the tar paper and most of the siding (a pattern called "V-channel rustic," a fairly common Queen Anne pattern; similar to the image below). The bottom course had to be scribed to the water table, so I got to use coping saw, Stanley 60 plane, and chisel. Felt nice to be using hand tools again.
The Stanley 60 may be one of the finest block planes ever made. I managed, a couple of years back, to score a Sweetheart-era version (more bedding for the iron), and with a Lee Valley iron, it's like having magic wood-cutting fingers: you just move your hand, and wood disappears.
William Duffield
Not yet, at least not on WoodCentral. I have presented it to my local woodworking association and at a couple of local SAPFM chapter events, and at the SAPFM table at the Lie-Nielsen event at Hearne Hardwoods last fall. I'm going to present some of the ideas again at the end of October at another SAPFM event in VA. I also usually throw it into the back of my Scion whenever I'm going to anywhere there might be people interested in woodworking with handtools, just in case anyone is interested.
Do you seriously think anyone here might really be interested in this kludge?
Re: Finally, the mandrel and the chuck
William Duffield
The method I use has it's problems, but they may not apply to your chuck, and there are work-arounds.
I have a One-Way Talon chuck equipped with step jaws that I use for this.
The mandrel I use is just a short piece of all-thread and an extra nut. It should be short enough that one end doesn't bottom out on the end of the lathe's shaft, while the other end doesn't get in the way of your gouge when turning the inside end of the "tire."
The potential problem with this arrangement is the teeth on the inside of the step jaws. They adversely interfere with the threads on the mandrel, and it tends to misalign when you're tightening the chuck. I deal with this by pushing the ends of the jaws tightly against the end of the nut while I'm tightening the jaws and make sure I have tightened them very securely. It stays aligned unless I get a catch.
An alternative is to find a bolt in the same thread size with about 2" threaded and the remainder of the shank smooth. Make the mandrel by cutting off the head of the bolt. Another alternative is to use a set of jaws without dentition.
craigd
Love the Phil holder!
Re: Love the Phil holder!
TomD
Thanks. On that bike it had to be zip tied. But the ultimate idea is to have a bike where there would be BOs to carry that in a neater way. I almost set the shop on fire Tig welding that cage. I used 1/8" wire, and ramped up the amps to a commensurate level. It didn't like that, and a glob of molten wire hit the deck, and it set the floor on fire, but you can't see the fire through the number 13 lens. Oh well...
