New WoodChat!
Starrett comb sq
Starrett comb sq
Starrett comb sq
Joe shelton
Pardon my ignorance,again, please.
Has LS Starrett many different blades and heads for a 12" combination square? I plundered around their site a while, comparing different item numbers, to no avail.
Further, will the protractor and center finding heads of my square with 24" blade work on a 12"?
Do they sell a 12" blade alone?
Thanks for any help.
Joe
Re: Starrett comb sq
You might contact Joel Moskowitz at Tools for Working Wood. He sells Starrett tools and is quite responsive, in my experience, to e-mailed questions.
Yes and no
Neal in San Jose
Yes, most Starrett retailers will sell components individually. There are several 12 inch(actually, all blade length) styles based on how the graduations are laid out, but all similar length blades are the same dimensions. Some even have metric graduations.
No, components generally only interchange between blades of similar lengths. For instance, my 12 inch protractor won't fit either my 18 or 6 inch blade. I don't have a 9 incher, so I can't tell you about that particular one, but different length blades have different dimensions, thus the other components are not interchangable. Also, be aware that there are some blades that are scales only, and are not intended to be used with any type of head. They don't have the center groove necessary to hold other components.
Another interesting twist is that sometimes components from different manufacturers are interchangable. I've seen Brown and Sharpe heads on Starrett blades and it worked just fine. However, if you consider going this way, try it in person before parting with any cash.
craigd
Re: Starrett comb sq *LINK*
craigd
I have a Starrett protractor head (No.492), 12" & 24" rules (both No.4 ), Union 12" combo + centering head + rule (also No.4), and they all interchange. When you drop to 9" (mine is Lufkin) and 6" (Starrett) the rules aren't as wide.
I bought a bunch of Starrett rules from Walt at Brass City records at quite good prices.
Brass City Records & Tools
Robin Corell in Atascadero CA
If your 24" blade is 1" wide then your square head will fit on a 12" or 16" blade but not on a 6" blade. Not sure if they still make it but they used to even make a 1' wide x 36" blade.
The heads are made in either cast iron or forged steel. If the floor of your shop is concrete pony up the extra money and buy the forged steel, if you have wood floors the cast iron is fine.
There are two types of protractor and I prefer the reversible. hard to explain why but it just suits my layout needs better than the non-reversable. Both are good tools.
Robin
Jerry Gibbs
The Tools for Working Wood site (a sponser) says they sell blades alone.
Also...
John in NM
There are two protractor heads, one where the blade passes along the side of the protractor edge, and one with a wider protractor edge and the blade passes through the middle of it.
The first one is cheaper and comes in the cheaper set (I think) that does not have hardened edges. The second one comes in the more expensive set.
And if you buy from Tools for Working Wood *LINK*
Get to their website by going to the WC marketplace (link below*) and clicking on that. If you do that, Ellis gets a little extra money.
*but you can also go to the navigation box in the upper left corner of the screen and select "Marketplace," which will, at least on my browser, open up as a separate window, so you can do your shopping without losing your place in the forum.
http://www.woodcentral.com/wcmarketplace2.shtml
Brian Greene
In addition to my 12" set (3 heads) I have a 4" set with a rule and center finding head. Very sweet ... I love it. Starrett makes a very extensive catalogue of measuring tools appropriate for woodworkers. There are many combinations but just about everything is also sold separately.
