New WoodChat!
finished sandpaper cabinet
McKay
I took a class with Chris Gochner at Snow college in central Utah and we built this little cabinet. I will use it as a sandpaper cabinet.
It is made from cherry with the center panel of gum wood. The glass is bamboo leaves. The top is held with hand cut dovetails. The bottom uses wedged through dovetails. The door uses through tenons and they are pegged using riven cherry plugs. I drove the pin about 3/32" down and used ebony as a cap. The cherry is treated with sodium hydroxide, (lye), shellac and pre-cat lac.
The trim was made using a rabbet plane for the back, a plough plane for the starting groove and then a #7 to bring down the chamfer.
The hinges were fumed with ammonia to blacken the bright brass.
Good class.
Re: finished sandpaper cabinet
roger lance
that will be some well housed sandpaper!!....beautiful cabinet!!....would you explain some more about using NaOH on cherry....what does it do to the cherry??
reacts with the tanin
McKay
It will react with any wood that has tanin. At least that is what I think that it does. I do not like to muddy cherry with stain, but I am too impatient to have the cherry age. I make a quart and have it standing by. At times I have treated the cherry and I thought that I had ruined the cherry because at times it will go a putrid greenish color. But once the wood is shot with lacquer, it really pops. I never get tired of seeing it pop. Because the lye is dissolved in water, the grain is raised. I go over the cabinet with 600 w or d and then shoot it. I also sand between all spray coats.
Why!?!
Bill Tindall
This is an honest question, for I am bewildered. Judging by what gets posted and the questions asked, the folks that hang out here spend a larger fraction of their time making stuff for their shop than the folks that hang out on the other Forums. I have always been mildly curious why one would choose to spend time building a tool chest (to take any example) when the skills could be used to build a toy chest(as an analogous example). My curiosity went up a notch with this post.
The cabinet appears to be the nicest piece of furniture I have seen posted on this site. I can not imagine why it isn't hanging in the most prominent part of the house (1)as a useful and decorative cabinet and (2) a testimony to the skills of the maker.
I don't get it. Why aren't you all using your considerable skills and resources making stuff for your "family" instead of the shop?
Heck, why not?
John in NM
Having nice fixtures in the shop can make it a more pleasant place to work and make more nice furniture. I would have discounted this before having years in a basement shop that I hated to work in.
Re: Why!?!
Pam Niedermayer
Not everyone has kids and other family running around, you know. I don't know about Steve, but also there's a limited number of furniture pieces one can put off buying instead of building. And then there's all the good(?) stuff you inherit eventually.
Pam
all but one...
McKay
There is only one piece of furniture that is left in my home that I did not construct. I make a nice piece for my children every Christmas. I spend a minimum of six hours a day in my shop 6 days a week(even when I taught woodworking I spent this amount of time in my shop). I have real pine wall boards. I just finished painting my spray booth. Why do I do this? I admit that I am a little ocd, but it just makes me feel good to be in the shop. My goal this summer is to put a raised wood floor above the concrete and to get rid of the metal entry door and put in a arts and crafts door. You should see Cris Gochnors shop in Salt Lake City. Beautiful place with hardwood floors on the bench area. I believe that this just adds to the peacefulness.
Dale Lenz
Re: reacts with the tanin
Dale Lenz
After applying the lye solution, do you do anything to neutilize it or just let it dry
TIA
just let it dry
....just adds to the peacefulness....
roger lance
I like that.
Guillaume Dery
Seems almost a crime to use such a beautiful piece to house something as plebian as sandpaper.
Love the cabinet though. Understated and attractive. Can you tell me more about fuming the brass? Never heard of that before. Also, would you happen to have a pic of some fumed hardware? I am really curious about that and think I may want to add that trick to my repertoire!
Very nice cabinet!
Guillaume
P.S.: was the glass sourced or is this stained glass work you did? Can't tell from the picture size
Moses Yoder
Re: Why!?!
Moses Yoder
The tool box represents the craftsman. I made a little tool caddy that I used to do some cabinet installation work when we were building the Blue Gate Restaurant here in Shipshewana. We had the best carpenter crew in the area building it, they did some amazing trim work in that building, and they took one look at my tool caddy and were in awe of my abilities. Technically undeserved, but it worked.
Re: Why!?!
Patrick Gibbons
Bill I try to build only the shop fixtures I need. This has included a bench, cabinets, saw benches and I still want to build a tool chest. Not really all that much. My sons' room is all but one piece built by me. There are other pieces in the house and I have plans for more. Your perception may be more than what's going on. I think shop fixtures are easier for some people to talk about here. I agree with you that we should be showing and discussing more of our actual projects. I recently posted a case I made and made the mistake of providing little commentary. Not much was said. I find that the commentary along with pictures are what people respond to. I plan on posting my next project which is for the shop... a saw handle. A coffee table is in the works too. I think you'd agree that we all should be trying to prove you wrong and post more projects.
This might not be universally successful approach
Bill Tindall
Until I tested it to be sure I would not presume that leaving a strong base on the wood would be compatible with all finishes. The most obvious conflict could be with the acid catalyzed conversion varnishes. But lacquer, shellac and varnish will all react unfavorably with a strong base like sodium hydroxide if there is some left around to react with.
It may be that when used in modest amounts that the acids naturally occurring in the wood neutralize all the sodium hydroxide added. Or, the light sanding that occurs after may remove what remains. In any case there are enough variables running around here that testing for a new situation is warranted.
For the paranoid, a rinse with dilute acetic acid (dilute white vinegar) will neutralize any base remaining and the excess acetic acid will volatilize away.
Sodium hydroxide has been used to color mahogany as well. However, in the case of mahogany the color is not light fast. But, it may be light fast enough provide color until the wood is colored by ageing. Personally, I was not satisfied with the richness of the color developed on mahogany, but it does provide a means of coloring that doesn't affect satinwood inlay. This piece has since aged some to a more desirable richness, but not to where it would be with a dye stain and oil coloring. see picture
Re: Why!?!
wilbur
There are many reasons that I can think of as to why someone might go to the trouble of making a sandpaper cabinet to this degree of refinement.
1. Aesthetics. Maybe the woodworker just likes looking at a cabinet that isn't just shop grade plywood.
2. Class project. McKay did say that he made this with Chris Gochnour at Snow College. It could be that this size cabinet made as a part of a woodworking class wasn't a good size for the living area.
3. Prototype. Maybe this was a first pass prior to building the "real" project. If I was to incorporate all the different techniques that this project incorporates, since many of them are new to me, I would certainly want to do a practice run.
4. Wrong conclusion on the part of the questioner. The presumption is made that if you post about a project that you made for your shop, then people that post here "spend a larger fraction of their time making stuff for their shop than the folks that hang out on the other Forums." This is not a valid conclusion, as McKay's response above bears out.
for some the shop IS the project
do you have room in your shop
Bruce, a MN Galoot
for me to move in? :D
ck to see if it is heated first.
Bill Tindall
Someone on the other Forum was wondering how to strip (finish that is) in a 45 degree shop. Burrrr.
Re: ck to see if it is heated first.
Bruce, a MN Galoot
Last Thursday the temp in my shop was 47. On Friday it was 1. Today, it was 37.
I know you're well aware of MN temps in the fall, Bill. You need to move back here for a refresher in the winter :D
Re: Why!?!
TomD
"This is an honest question, for I am bewildered. Judging by what gets posted and the questions asked, the folks that hang out here spend a larger fraction of their time making stuff for their shop than the folks that hang out on the other Forums."
Part of the reason for that is other activities like power tool woodworking, and turning, are only rarely accomplished with tools and stuff that are home made. And even then the standard tends to be the plywood box, as opposed to hand cut dovetails. So the centerpiece of a power tool shop, out of necessity is normally the table, saw. While out of necessity in the hand tool shop it is the workbench, and/or tool cabinet.
" I have always been mildly curious why one would choose to spend time building a tool chest (to take any example) when the skills could be used to build a toy chest(as an analogous example). My curiosity went up a notch with this post."
While I get the squelch, I do think the case can be made that a mature person, with an an appreciation of fine furnishings, is actually the better target of a box they could use for 60 years, as opposed to the box a kid outgrows in 5-10 years. Not to mention one doesn't have to deal with the sense of betrayal that occurs when they don't use it.
"The cabinet appears to be the nicest piece of furniture I have seen posted on this site. I can not imagine why it isn't hanging in the most prominent part of the house (1)as a useful and decorative cabinet and (2) a testimony to the skills of the maker."
I) As others have said, because for some the shop is the center of the house.
2) When it comes to the kind of work many of us make, the shop is a place where it is more likely to be appreciated.
In America, people generally appreciate only stuff that is expensive, which pretty much excludes the stuff any of us makes, since dollars and brand are pretty much inseparable. The other thing in demand is stuff that has a "look" which means the appearance of a thing, which pretty much passes over the whole deep detailing that goes into a real piece. Not even museum curators of fine woodworking have the slightest idea what a piece really means, so it just makes sense for makers to hang onto stuff rather than to give it up for cheap praise from ignoramuses
"I don't get it. Why aren't you all using your considerable skills and resources making stuff for your "family" instead of the shop?"
I suppose there is also the possibility that some people are doing that, but share shop related stuff due to relevance. But in general family doesn't get it. They don't have the background to like your work any more than a nail clipping you drop, "because it was yours". I'm lucky that my wife has built boats with me, and other stuff, and that she listens to me go on and on. My parents are both highly skilled, and my in-laws include an internationally known needlewoman. But it still comes down to the same point basically.
It is kinda the same reason people go to the VFW rather than share stories with their family. The family doesn't know, therefore would gain the most from hearing, but they can't ever get to understand, unless they got there through the same path.
And what that means is that if you make stuff for other people your work will always be taken down to their level. Which seems like a waste of time.
TomD
That sounds about right. I have hardly run the heater this winter because it has been so mild, by Canadian standards, but it isn't really comfortable, either. Long live wooden planes and tool handles.
Moses Yoder
Re: Needlewoman
Moses Yoder
If you wouldn't mind dropping a name, who is the "internationally known needlewoman"? My wife is known in local circles for her counted cross stitch, having taken many firsts and one grand champion overall at the local fairs.
Bruce, a MN Galoot
I am absolutely fanatic about wearing hearing protection when I use my noisy power tools. The shock of those cold ear muffs when I put them on is breathtaking.
Good Point
roninkokomo
My family certainly does not understand my love affair with the craft. My wife acts like she does with a " that's pretty honey" ... but IKEA would work just fine for her. If she requests a project the reaction is quite a bit stronger, but their understanding is about on a level of their understanding of why I adore good Bluegrass music.
SO.... it is quite possible that something nice is in my shop, because that is where it is most loved.
Hadn't thought of it in just that way Tom.
Re: Needlewoman
TomD
She hates computers, so I'm not sure about putting something where it is searchable. She used to own a store called a Stitch in Time, back in the 70s through 90s, and write articles and do a lot of classes, she is retired from a lot of that and still gets called in to evaluate collections and such in the US. She is more in the embroidery field than the needlepoint one. Sadly there is nose looking down on in needlework also.
