New WoodChat!
Four drawer nightstand
roger lance
Being new to the posting of photos, I did not do a very thorough job of documenting the build of my nightstand....but there are a few pictures....
this is the piece in the dry fit....the front drawer dividers are mortice/tenon fitted
the rear drawer dividers use sliding dovetails which I used as an experiment to help reduce the trauma of the glue-up
each piece was then finished and then came the glue-up....confession time on the drawers....these are my first handmade half blinds....the drawers were originally sized for half blinds on an Omnijig at 7/8" intervals, but with the influences of this forum, I decided to be a man and make them by hand....thus the uneven spacing of the dovetails....the next piece will be evenly spaced....thanks for looking.
Re: Four drawer nightstand
Your first handmade half-blind dovetails??? No shame there, whether for man or woman; if I tried that, the cat that would fit through the resulting gaps would be fat enough to go on one of those weight-loss (un)reality TV shows ("Fluffy Gets Fluffier?").
There's a ladderback chair that came down in my family, probably "factory" done, but turned by hand. The finials atop the rear posts are very different from each other in size and specific shape, although of the same general shape, something I was the first in the family to notice (or at least comment upon) after years and years of the chair's presence in the living room - and I didn't even notice the difference until we were going through the furniture, dividing it up as our parents' house was getting ready for sale. If future family members notice the variations in the dovetail spacing, it will just confirm for them that it was hand made.
Nice looking night stand, and thanks for the posting. Bill T's right, that we don't do enough "here's what I'm building" posts.
Question
Bill Tindall
One of the challenges of a frame and panel side is arranging for the drawer supporting parts. Something additional needs to be added to keep the drawer on track, side to side; the case side with a panel is not suited for this task. . Could you make a picture showing how you accomplished guiding the drawer in place. I have yet to come to a conclusion on the best way to do the internal framing for drawers where the case side is frame and panel.
Dovetails- if they hold the drawer together then you were successful. They don't need to be a fashion statement.
Re: Question
roger lance
Hopefully, you can see a running dado in the middle of the back drawer divider....there is also a corresponding dado in the front drawer divider....the drawer keeper is screwed and glued to the drawer runner which has tenons that are glued into these dados....there is no physical contact of the drawer system with the floating side panels
Why does the dado spam the entire back/front?
Re: Why does the dado spam the entire back/front?
roger lance
Pam....I'm in process of developing my style....the full length dado was made in anticipation of installing dust panels between drawers....but after discussions on this forum regarding dust panels, I opted to only install a dust panel on the bottom of the piece....if you also ran a dado along the drawer runners, you would have an easy way to install dust panels as was done on the bottom....so there is no real need to run them full length if you are not installing a dust panel except it is very easy to do and fast at a table saw....but mortises could be cut and accomplish the same thing (which I may elect to do in future pieces)....also, I must say, these drawer dividers are about as small in width as I'm comfortable to work on with that dado.... note Bill Tindall's drawer stops on the front drawer dividers (another topic of the forum)....I also made thin drawer sides and used slips (both forum topics)....these conversations do have an impact.
Stuart Hough
Fine work Roger! I really like the color of the end result. You should be proud!
Thanks
Pam Niedermayer
Of course, thanks. Depending on the width of your case, you may have had to add another rail to support a thin dust panel. I like dust panels, they've always done well by me.
Pam
dovetail spacing
McKay
I have always wondered why there is such an emphasis on the spacing of dovetails. The way that I look at it, if I wanted to have evenly spaced dovetails I would use a Omec, Leigh, or other jig. To me, the dovetails are beautiful and even spacing would be distracting. IMHO
Really nice job Roger.
Hi Roger
That is a lovely side table. Nice proportions and beautifully constructed.
I suspect you started the dovetails with the top drawer, and ended at the bottom?
I thought that you grooved the drawer dividers simply because it is easier than chopping mortices for the side rails.
Can we have a picture of the completed nightstand and drawers closed?
Moving up the learning curve
Bill Tindall
I wish I had a Forum like this one to learn from 30 years ago. It has taken me decades to learn the details of typical case construction in "fine" furniture.
The problem with books and articles is that authors often write about their unique way of doing something rather than the way "everybody" else does, and has done, it. For me studying antique furniture was a more useful guide for how to frame a piece. The problem is I have not had the opportunity to get inside many pieces with panel sides. The other problem is that I don't live in an area that has opportunity to study fine antiques.
What is next?
Bill Tindall
The success of this project shows you can make about anything you want to. What is next?
roger lance
Derek...yes I started on the small drawer first and worked my way down....I did cut the dados intending to do dust panels but changed my mind....the dados were always intended to accept the drawer runner tenons....and they are easier to cut than mortises....no doubt....but if I were to make a case with solid sides (not frame and panel), I'd use wider drawer dividers and mortises on them with the front tenon of the drawer runner glued in its mortise and the back tenon of the drawer runner left dry in its mortise to allow movement with expansion/contraction of the case side....so I'm a little undecided on how to proceed in the future with a full length dado or mortise on a frame and panel carcase....as Pam has pointed out there are advantages to the full length dado ( add a cross member to the center of the drawer dividers for a long drawer for example....etc)....but the mortise is more elegant (perfectionism has its costs)....I've been distracted from finishing the drawers, so I'll post some photos of the drawers closed and an example of the A&C hardware (from Rockler) and then post again once completed....
thanks for looking.
Re: What is next?
roger lance
Not sure Bill....there are so many things on the list including some practical cabinets for the laundry room and garage....I'd like to make a tall dresser like you just completed (my compliments....beautiful....and the top came out great)....what about you ??
Re: dovetail spacing
TomD
There are a lot of approaches to dovetails, so I guess one gets to choose from a range of options. I started out when Krenov was the rage, and he had the variable spaced perfect dovetails. Harder to do than it looks. Of course those dovetails were exposed, and rather showily at that. Antique furniture rarely rises to that, and while it has it's conventions of quality, the execution often does not suggest they were intended to be viewed all that critically. My view is that forced crudity is fake so if something requires no more care than another part of the furniture, when we all know how dovetail mad the craft world is, then I am going to put the effort into it. I don't see why I should spend less time setting out dovetails than most dovetails nuts do reading and salivating over the latest saws.
Boring....
Bill Tindall
Finally, after 19 years, I am replacing the #3 common rough cut poplar stairs leading to the under development family room with something nicer. Compared to furniture it is boring work but it is going well so far. There are a lot of steps involved (oooops, that pun just slipped out) . They will be painted and the logistics of getting very slow to dry floor enamel to dry on the multitude of parts, and a place to dry them is difficult. I like prefinishing stair parts. For one thing I can spray most of the parts and thereby get a glass-smooth finish.
Pam Niedermayer
I think the long slit/mortise could be an important hassle for the person who does the dusting if they won't be filled with panels. Remember all the appliances designed by men who never even thought about cleaning them? All the geegas and dials and buttons seemingly designed to attract as much dust, dirt, and oil as possible.
Pam
roger lance
Pam....I could easily fill those slits with a thin piece of stock....fitted and glued into place....better??
Another undiscussed design element....
roger lance
we have not discussed the incorporation of leg levelers as a standard feature....this (or any piece) might wind up on an uneven floor and be rocking....so I put levelers in a recess on the bottom of each leg and tried to have enough "meat" around the leveler with a chamfered edge so breakout will be avoided.....what are your opinions of this feature ??
I'm stumped
Bill Tindall
What is a leveler? It sounds like a good idea, Beats a book of matches. But it is not something I am familiar with.
Re: I'm stumped
roger lance
Bill....I don't know how to link....but go to the Rockler site on this board and see item #12295 which is spoken of as a glide....1/4-20 one inch treaded rod that is screwed into a tee nut or other threaded insert in the bottom of the recess on the bottom of the leg....the glide/leveler can be unscrewed to then level/stabilize the piece....a felt pad could be attached to the bottom of the glide/leveler to prevent scratching a wood floor....I'm not interested in gliding the piece just making it convenient/easy to level....and basically hidden from view.
Re: Another undiscussed design element....
If they'd been affordably available in the 17th-18th-19th century, I suspect we'd think of them as elements of fine furniture. There are very few billiard-table-flat floors in any house that's old enough to drink in bars, and a lot of matchbooks and other shims holding up the "short" leg of a lot of furniture. The chamfering of the foot is a nice touch, too.
You've had direct experience with them, Bill
Bruce, a MN Galoot
They are located on the legs of every cafeteria table you've ever seen. They're the screw-in feet that someone has munged up and cause the table to jostle about when you put your elbows on it. :)
Re: I'm stumped
TomD
I'm not sure it does beat a book of matches. I put a bunch on some krenov style saw horses. I eventually removed then when I got tired of the rattle, scuffing, noise. Meanwhile a shim can work very well/
