Hoarders Anonymous?
Charles Stanford
...or maybe not so anonymous....
Hoarders Anonymous?
Charles Stanford
Re: Hoarders Anonymous?
Moses Yoder
Just because I have over a hundred planes doesn't make me a hoarder. If I had over a million, then maybe I would be. A couple hundred different ones are handy because you only have to sharpen once a year. I just got the Lee Valley 724 plumb bob, but I needed a paper weight to keep the papers from blowing off my desk in case the window is opened. Looks like I'll need half a dozen, so I hope they keep making the annual bob, that way I'll have a matched set.
James Watriss
Yeah, sharpen once a year... for 2 months.
: P
Bill White
You party animals are not well!!! Yuck, yuck.
Bill
Chuck Nickerson
No! I need two each of all apparent sweeps of Fray/Spofford braces: 7", 8", 10", 12", 14", and 17".
Just don't tell my wife what I paid for those 17" ones.
And don't tell me the mythical 19" size actually exists.
Have a Fray & Pigg?
Frank D. in Montreal
Which is what I do. Since I don't like to flatten my stones, I need about 3 dozen.
Hoarding or . . .
steve mackay
Is a woman's (and some men) array of make-up and "beauty products" hoarding ? I find that more hand saws and hand tools make me smarter and better looking. So it is actually a matter of self improvement.
Per grit?
TomD
Frank,
Try flattening them on a concrete block like the Japanese do, and you will see the rapid progress, out of doors, little mess. Also try working the whole surface of the stone. This means overlapping the edges with bits of the steel hanging off.
So how do you flatten the concrete?
You rub two concrete block faces together
Actually you need 3 blocks
Bob Hackett
If you try it with just 2 then one conforms to the shape of the other and you could potentially get one crowned and one hollowed which would just repeat.
Crank a third one into the mix and alternate as you flatten and you`ll end up with 3 truly flat surfaces.
Just be selective of the two you choose...
roger lance
and you will be ok....maybe someone will propose four as the necessary number of concrete blocks to have to assure flatness....or five....
Re: Just be selective of the two you choose...
TomD
I just measure one with a straight edge. I have a few blocks lying around from when the guy who built this place did the foundation. It was not a long drawn out process getting a flat one. It works great. I do sharpen off stones so flattened, but I also have two 800s. So I flatten both on the stone, and then work them together and move on up. My point is just that it really works fast, so even if you want to go all anal on a diamond stone, why put more wear on it than required.
You can get somewhat different effects just by skewing the stones as they work, as opposed to bringing in a third stone.
LOL
