What you are aiming for ...
I currently have an Adria DT saw. Like it a lot. I also have a small Dozuki saw that is ok for crosscuts.
I am looking for something I can grab and use for quick clean crosscuts of small pieces like drawer parts and so on.
I'd like to get a small brass backed saw. Something about the size of my Adria, maybe with an open handle.
I've looked at the Adria and LN offerings, but I am wondering if there is a place to buy refurbished old saws that are sharp and ready to use.
I am not interested right now in refurbishing one on my own and learning how to properly sharpen a saw.
Hi Joe
First off, you need to narrow down your search to the saw plate size and the teeth configuration. Only then will you know that you are buying the appropriate saw.
The two crosscut saws I recently built are the specifications you are are after. One was a carcase saw (11" long plate, +/- 2 1/4" under the brass back, and 14 ppi crosscut), the other was a smaller joinery saw (9" long plate, 1 1/2" under the brass back, and 16 ppi crosscut). The carcase saw is for crosscutting boards with widths of 3" and greater, while the joinery saw is for narrower widths, plus more delicate cuts such as the dovetail ends of a tail board or small tenon shoulders. There are pictures of my saws in a thread below.
The absulte Best Bang for the Buck in a new joinery saw is the Veritas Small Crosscut (16 tpi and 9 1/4" long plate) ... http://www.leevalley.com/US/wood/page.aspx?p=64007&cat=1,42884,64007
Veritas also have a 11" long and 14 tpi crosscut carcase saw here: http://www.leevalley.com/US/wood/page.aspx?p=66066&cat=1,42884
At under $70 each they are a steal in a new saw with this quality. Please note that I have used neither, but do have and use the Veritas dovetail saws, which are superb. I cannot imagine that the others would be less than this. Veritas also stock the Wenzloff saws, of which the types you are seeking are available. However the prices for these are at least double the Veritas and more than you indicate you wish to spend.
