......dovetail markers ... and more.
I am about to make some more and I will document the process as well as make a case for why they are the tool for the task when I get another made.
Hi Bill
That is indeed a different dovetail gauge. I would be most interested in knowing how it is used. It is not that obvious. Pictures in use would be better than just a description.
And what angle do you prefer to use? For example, I find that 1:7 is my preference in thin 1/4 - 3/8" drawers, while 1:6 looks better in 3/4" thick carcases.
My markers are really simple - just a section of brass angle. Here's a set in 1:8, 1:7, 1:6, and 1:5 (makes it easier to decide which size will look best) ..
Of course I did make one with bling, for a joke .. a dovetailed dovetail marker
I find the marking knife like the one you posted, which is similar to Blue Spruce and others, to be the most function design of those I have tried.
Actually, the knife that Dave Jeske (BS) and my design (see Vesper now) are the only two with similarities. Those by, for example, Chester Tool Works (Dave Anderson) and Czeck Edge (Bob Zajicek) are different in design. It is these (subtle to some) features that typify what I was looking to discuss. The BS and Vesper have a similar ergonomic body shape that allows it to mold into the palm. I have not actually held one of Dave's knives so cannot comment on its size relative to the Vesper. I suspect that they are similar. The blade on the Vesper is about 1/2" longer. The bevel angles are the same.
By contrast, the CTW and the CE knives have straight bodies. The bevel angles are different, lower ... which means that the knives must be held at a lower angle to mark. This reduces their effective height when scoring between dovetails.
Including some sort device to aid sharpening it would be a nice addition.
I tend to hone my knives freehand. Dave Jeske has a good video demonstrating this.
http://www.youtube.com/watch?v=622fDmpM8JA&feature=player_embedded
As it happens, I did come up with a method to use a honing guide to sharpen these itsy-bitsy edges ..
Step One is to cut a 2" length off your garden hose. Slice it down the centre. This will be used to protect the wooden body of the knife and also increase the grip within the guide.
One can make a jig to set the angles, but the simplest way to hone the edge is to (1) place the bevel flat on the media, and (2) ensure that the outer edge is parallel to the honing guide ...
I have designed a proper guide for these knives on paper but have not built a model. If there is interest I will build one and post pictures.
It would be difficult to improve on the functionality of the "wheeled" marking gauges for layout.
I use these as well. However I recognise that it is the rounded blade that I like as it is unidirectional. The downside to the Titemark and LV wheel gauges is that the fences are small and the wheels do not permit much downforce, that is, the lines are shallow. Fior this reason I often prefer a wooden cutting gauge. These are capable of deeper lines.
I regard squares as multitaskers. If they aren't ruled I have no interest in them.
I use Starretts quite often as well, and occasionally also for marking off. In the main I prefer a small square, 4" or 6", for marking joints. What I particularly like about the small Vesper 4" is the slim sides. It is light and beautifully balanced, which makes marking easier. My other favourite is a 6" Starrett double square.
