Re: Got some more tools from my dad
Moses Yoder
Woodcraft has oil stones that will work pretty good for your carving tools at a reasonable price. Inspect them if you get them to make sure there are no cracks in them. Lee Valley has a combination oil stone that looks good, haven't tried it, but 2 stones for the price of 1 is hard to beat. The small stone would be large enough for carving. I use kerosene for honing oil, and James Krenov did too. Warren is a good reliable source of info and you might ask him what he uses.
I like water stones for my plane irons and chisels. A carving tool is a much smaller area, and would dig into a water stone, so you need the oild stone for it. A good water stone set, 1000, 4000, and 8000 grit will run you close to $200 but they will last half your lifetime I imagine. To start out cheaper, search the articles section here for scary sharp or sharpening with sandpaper. Another option is to sharpen with diamond paste on a cast iron substrate; lots has been written about that.
If you intend on becoming a woodworking, you will want to learn sharpening. There is a huge difference in satisfaction between using a good sharp tool and using a poor quality dull tool.
