planing diversity
Bill Tindall
Someone asked rhetorically, during one of the frequent discussions on metal, whether I had the stamina of Godzilla, or some such, because I apparently never needed, or looked forward to, a break when planing to sharpen the blade. This curious question has stuck in my mind whilst finishing up the French Footed bow front(now at last only lacking hardware to complete). I have come to realize that my planing is worlds apart from the questioner.
I never have occasion, or desire, to plane large surfaces. My planing involves removing bits of wood here and there in the course of fitting pieces. Most recently it was a hump in the top framing that was not letting the top lay flat, before that some additional tapering of a drawer top that was binding, and before that shooting a whisker off the end of a piece that was to be fit between two others, etc.
I never plane more than a minute or two at a time. As a consequence I never need to sharpen during a planing session and for the most part the plane is always more or less dull when it is pressed into service, or set aside. I am driven to sharpen when the plane won't do some task at hand, and this obstacle usually arrives unexpectedly because I typically have no idea what condition the blade is in when I reach for the plane. Hence, sharpening is an annoying, unexpected interruption in the task of getting something made. A metal, or coating, that would lessen these annoyances would clearly be desirable. Others, using a plane for similar tasks, would be similarly disposed.
Ditto for paring chisels. The only continuum of feedback I have on dulling is when dovetailing. In this case the session is usually sufficiently long that the favored chisel for the task will need to be sharpened "in route". I don't find these sharpening interruptions nearly as annoying because they are not unanticipated and indeed they provide a welcome break.
