Re: Electric guitar bodies
scott grandstaff
I haven't been able to find a long enough suitable piece of mahogany and the neck would probably be susceptible to bending unless I somehow insert a full length truss rod.
Pam
Frets wear
The neck through idea has been well explored and done. Same as the glued in, or set neck. Carvin guitars made a pretty good run with neck though. They will sell you a though neck to use. If you can find an older one, it'll not just have a truss rod but 2 strips of carbon fiber reinforcement besides.
Very stable, but honestly, necks move anyway. Its what they do.
And even Carvin has relented lately.
Gibson is still clinging to the set neck but they offer bolted necks as well.
The trouble isn't with the initial guitar. The neck though or set neck is just dandy, and for some time.
The trouble comes after a few years when the frets wear.
If you are rich you simply replace the whole guitar and hang the old on the wall, but for the rest of us...........
Fret jobs on solid attached guitars are much harder (read scandalously expensive) on one piece guitars where you can't just take the neck off.
Only a few places will even take on the job of refretting a Les Paul Standard or topline Carvin.
5 to 800 dollars is the usual ask for a full bound ebony board inlaid in pearl, and a waiting list!
Bolted necks are 1/2 that, at worst.
Besides, with bolt on necks you can simply pull the neck off and install another in an hour or less.
You can buy a whole new neck for much less than having frets redone. There are any number of neck companies out there making nothing but necks. Many of them fine companies.
Warmouth, mentioned earlier, makes necks in 11 kinds of wood and 21 different shapes/setups!
The genius of Leo Fender strikes again.
Lately stainless frets are being used on a few guitars. I look for more and more of these to be made.
Hopefully, eventually, someday, with hardened stainless.
Its my own view that frets should harder than string wire. Strings you can get for 2 bucks!!
yours
Hell on frets (ya see that black smeary looking stuff all over your left hand after a couple of hot jams??.... Yeah that's your frets.)
Scott
