Pull Stroke Sawing - Vertically?
charlie belden
>The earlier review of the Veritas DT Saw got me thinking of my experience with japanese pull saws - and earlier - jeweler's saws.
Having used "push saws" for cutting joinery (PAX tenon, LN DT and various Gent Saws)as well as japanese saws (dozuki, Odate DT) I find the pull saws easier to use and control - and with more gripping and cutting orientations than push saws.
For through dovetails - cutting them with the part horizontal and the blade vertical - while seated - with the Show Face up - I have several advantages over the Stock Held Vertically Method as well as the Push Saw approach.
1. I can see the end of the cut looking almost straight down so I'm less apt to overcut
2. I can see if the blade is vertical - important at the end of a stopped cut
3. I can also see the line I'm cutting better because I'm looking almost straight down on it with my eyes closer to it than when using a push saw
4. I'm less apt to "muscle" the saw through the wood because of the shape of the handle.
From my days with a jeweler's saw - mainly doing piercing - control of the saw was critical. My mantra was "Control The Cut - Let The Saw Do The Cutting". The latter was encouraged by how I was taught to grip the handle - thumb and fingers on THE SAME SIDE. With this grip it's almost impossible to force the saw to try and cut more than it wants to cut - crucial when the saw blade is not much thicker than a human hair and only two or three times that wide. Muscle a cut and you'll go through a lot of blades.
Which gets me to my question - about saw handles and grip.
I've studied western push to cut dovetail saw handle angles and they seem to go from maybe 40 degrees to 50 degrees and are shaped for only one basic grip - some with a "notch" for your index/pointer finger. While the grips are designed to apply pushing force, the pistol grip handle also allow you to apply forces on the blade you shouldn't be applying - rotation/torque.
Granted, japanese pull saws usually have an oval handle which will allow you to apply some rotation/torque, but no where near what you can do with a western "pistol grip" saw. And the oval shape of a japanese saw handle does give you some tactile feedback on how the blade is "pointing".
With all the handle ideas out there for push dovetail saws, including the Glen Drake Two Pistol Grips version, and the recent trend to pull cutting "western" dovetail saws why are the "backed saws" still being made with basically the same handle shape that's been around for a couple hundred years?
And dwhy are we still PUSHING dovetail saws?
(ramble mode off)
Re: Pull Stroke Sawing - Vertically?
Dean J in MN
Because they work?
Of course other saws work too. But looking back at when the DT saw (and its important cousin the carcass caw) were being used to make a living we see the shape and important hang angles being optimized for work on dovetailed casework. I know I would not want to cut the 100+ dovetails on a case piece with a straight handled saw; I'm used the the high hang of a western saw and see no downside to the handle, hang angle, nor push configuration. On the contrary, these features all help.
-Dean
simple answer to your question
Bill Tindall, E.TN
>I am as smitten by western dovetail saws as you are with pull saws and I could equally rationalize why. I will address just one point. What you call a disadvantage, the handle enables torquing the saw, I find its biggest advantage. With a western handle I can tell how the saw is oriented much easier than a "saw on a stick", which is how I regard pull saws.
I used to teach dovetail classes at our club. Both types of saws were available. Some students like one kind and some the other. I didn't try to convince either camp that they had made a poor choice.
I have a question. You said, "thumb and fingers on THE SAME SIDE.". Try as I might I can not visualize this grip
Re: simple answer to your question
charlie belden
>Bill:
Attached is a quick shot I took of the grip I was describing. It gives you control for Up/Down strokes, the oval shape of the handle gives similar directional feedback as the pistol grip grip - BUT - you can't FORCE the blade into the wood with much pressure because the back of the handle isn't - and can't be - PUSHED by the webbing between thumb and forefinger or the palm of your hand.
The torque you DO NOT want is the one basically around the long axis of the saw - push or pull.
With a western pull saw, the pistol type grip encourages wrapping three of your fingers around it - GRABBING the handle. You don't need to do that at all - just enough holding force to control the saw - no torqueing around the long axis at all. You can use a push saw with your fingers straight, "gripping" the handle between thumb and forefinger/index finger - the force needed - into the cut - coming from the heel of your hand.
Does any of that make sense?
Doesn`t seem very ergonomic
Bob Hackett
>Correct me if I`m wrong but if you wrap your thumb over the handle doesn`t that put your wrist in a more neutral position?
I`ve been led to believe that the neutral position is what is best.
The pistol grip of a western saw with the proper hang for the job being done would come closer to that neutral position than the grip in your pic.
MB
wilbur
>Although I pretty much use Japanese saws exclusively, to the point that I'm pretty much a wreck with using a western saw, I've been coming around to the point of view that western and Japanese saws have much more in common than one might think, outside of the direction of the stroke.
My latest data point came from looking at a plate from Nicholson detailing the types of tools a woodworker would use. I've Photoshopped (actually, Gimped, for those open source fans out there) his illustration of saws with a picture of a ryoba. It sure looks to me like the profile and angle (cant?) of the teeth are looking pretty similar.
experimentation at the keyboard
>I was just sitting here, pretending that the highlighter on my computer desk (the largest round object I could find without moving) was a saw handle, and moving my thumb from one side to the other of the "handle" didn't change my wrist position at all.
If I try to imagine cutting that way, I find myself holding my forearm and elbow in position and swinging my arm at the shoulder - is this the motion you use, Charlie? If so, it's not too inconsistent with the advice often given on sawing with a western saw, except opposite in direction.
Re: experimentation at the keyboard
charlie belden
>" If I try to imagine cutting that way, I find myself holding my forearm and elbow in position and swinging my arm at the shoulder - is this the motion you use, Charlie? "
Because I'm sitting, or kneeling, I can get my body close to the work
with my upper arm against my ribs and movement is from the elbow. Because the stroke is short, maybe three or so inches, it doesn't require much wrist movement. Think scroll saw.
Frank D. in Montreal
>Hi Charlie,
I use both style of saws indifferently (as much as I've wanted to choose one style that I preferred, if only to save me money, I haven't been able to).
With practice I find that one doesn't need (and, I think, shouldn'T need) as much visual feedback to make a critical cut. Of course some visual feedback is important, but I'm not sure having one's face in the cut is ideal with either style of saw. I also use the old trick that Charlesworth taught me of using a mirror (behind the piece being cut) to saw dovetails or tenons, and I find it useful for both types of saws.
I think the muscling through the cut is more due to blade thickness than style. Some western saws just breeze through a cut, no tenseness necessary.
The real question is how to start the cut. If you don't need to muscle through a cut, and if you don't need to apply rotational forces, that means that you've started the cut perfectly vertical or in line with your mark. What allows one to start a cut perfectly wityh a Japanese saw, compared to a Western saw? I'm not sure one style is easier to line up than the other; both take practice to line up at the begonning of a cut.
Another argument you seem to make is that the possibility of applying rotational forces is a disadvantage. I'm not sure I see why. Of course ideally you shouldn'T need to, but I've found myself, even with my Japanese saws, either backing up to re-establish a kerf gone astray, or trying to correct a cut. The oval handle allows one to correct a cut by rotation if necessary, although the best way to correct a cut for both styles of saw is to lower the angle and bend the blade slightly towards the traced line. But either style of saw is never inherently more accurate than the person cutting.
I think that on the push cut, western style handles are the most appropriate shape. It's not surprising that they are still being made. A western style handle on the pull cut, in my opinion, is not appropriate, other than for very rough-cutting saws which require a lot of brute force, just as straight handles are less apropriate in most cases on the push cut (gents saws notwithstanding).
Indeed
Bill Tindall, E.TN
>Once I start my LN saw it saws in what ever direction it started (for better or worse). No reasonable torque on the handle will deflect it and in fact the grip is so light that there is no likelihood of torquing. So the only advantage or disadvantage of the handle (torque- wise) is whether it enables the saw to be started straight to begin with. Beyond this point some western saws, for example the LN, just "feel-right" in my hand, much like a well fitted rifle and I suppose other stuff as well.
I may have an advantage
Bob Hackett
>I use both push and pull saws and actually went and made a few cuts to test the grip.Charlie`s grip found me having to adjust my foot position and stance to the point where I was no longer able to site the saw and line as I was used to.I found myself too far to the left of the cut rather than directly over it.
The advantage I speak of is that I am pretty much forced into the most ergonomic position in order to work.After 5 surgeries to my dominant arm and shoulder if the wrist/forearm isn`t neutral and relaxed then the hand is quickly numb and the remaining operational tendons are screaming.
MB
Zona makes push and pull - & I like both. *LINK*
David Barnett - SW FL Gulf Coast
>But the pull variety Razor Saws are amazing for small and/or very hard stock, whether wood or ivory or whatever (which is a pretty broad range). What's more, they're dirt cheap.
I'm used to round-handled tools and have no orientation problems, but I tend to grip the spine beyond the handle and point my index finger. For furniture-sized DTs I'm not letting my IT go anytime soon, but for miniature or fine stuff - esp. inlay in objets d'art - these saws are a great value.
Zona Razor Saws
Sit. Don't Stand
charlie belden
>Bob:
I learned this way of sawing with a "pull to cut" jewler's saw. Jeweler's saw blades are pretty delicate critters, and pushing against them, twisting them or bending them - will snap them in a New York Minute. So you only apply a minimum force towards the cut and the actualy cutting force is DOWN.
"Pierce" sawing is done SEATED - with the surface of the part being sawn at about mid rib cage height, with your "saw hand" directly below the cut, elbow in at your side.
All sawing movement is done from the elbow, the upper arm being fixed against your side and your wrist "locked". You can adjust your seat height to get your wrist in a "neutral" position. The grip on the handle is light, just enough to hold the saw in alignment and to pull down to cut. This IS NOT a power cut grip - it's a finesse cut grip. If your hand hurts - you're probably gripping TOO tight. Don't expect to bang out a half dozen drawers worth of dovetails in an hour. You're after tight dovetails, not Beat The Clock.
If you pay attention to your body, and note if things feel tight as you saw, adjust your body position until you feel relaxed and comfortable. Once you find that position, you can saw for an hour without any soreness afterward. Pay attention to your neck and shoulders. If they feel tight while you're sawing you're tense - probably for a reason. Adjust your body position and lighten up - it's just a dovetail you're cutting - not brain surgery. Humming or whistling helps you relax - and have fun.
BTW - maquetry folks saw this same way - though they're are of course sawing MUCH thinner stock. But they do angle the cut "inward" slightly so parts will fit together without binding or splintering.
Re: Zona makes push and pull - & I like both.
Raney
>I use both japanese and western saws quite a bit. I use very different grips for the two, but in my experience there is no such thing as a 'perfect' grip or stance. There are some tricks that help somewhat, but no matter what you use, there is a learning curve to useing either type - and the curve mostly consists in learning to apply the force only in a direct line, while avoiding torque.
I honestly think it's more or less a wash in terms of which is 'better' in terms of rotational torque, because the advantages Charlie points out are pretty much offset in my experience by the fact that with a pistol-grip it is much easier to NOTICE any changes in rotation because it involves much more extenstion in the vertical axis. So just as taller planes are easier to keep dead-plumb, I think western saws are easier to sense plumb as well.
I'm of the opinion this has everything to do with practice with whichever type of saw you use. There are definitely circumstances and types of cuts/woods where I think one or the other has some advantage (which is why I like both) but avoiding rotation ain't one of 'em.
I agree
Bill Tindall, E.TN
>They are great for thin stock as they saw with no chatter. Can't believe they cost so little. I use them to cut dovetails on very thin drawers and other special tasks.
I`ll try sitting
Bob Hackett
>I am in a unique position here.Many of the techniques I used to use are no longer an option and others must be modified and refined so I suppose I`m more open to change than some.
Because a standing approach is what I was taught(Let gravity work FOR you was the mantra)that is what I was using when I tried your grip.For me the main rotational point was my shoulder rather than my elbow.My shoulder is where most of the damage was focused so isolating that and moving the point of rotation to the elbow is worth exploring.
I`m sure there`s a learning curve,there always is,but if it will allow me to work longer and pay for it less at the end of the day then it will be time well spent.
Mainely,Bob
Re: Pull Stroke Sawing - Vertically? (long)
charlie belden
>snip
The more sense you engage, the more info the brain
gets to use.
In engraving, there's a "walking Z cut" usually done with
a line graver. You engage the left corner of the graver
with the metal being engraved, rock the rest of the
cutting edge into the cut, then pivot off the other edge
of the graver's edge and make the next cut rotating in
the other direction. It's called "wriggling" - sort of like
"walking a board" on end. Getting the spacing of the
patten uniform is tricky.
My engraving teacher would sing "doodle-doodle-doodle"
as he made this type of cut - and "rocked" on each
"doodle". For small fine patterns he'd "doodle" faster,
and for longer patterns he'd "doodle" slower. It was all
about establishing a rythm - and singing helps do that.
Of course, you had to be close to hear him - close
enough to invade his "personal space" to hear him. He
laughed when I aksed him about his "doodling". He
wasn't even aware he was doing it - having been taught
that little trick many many year earlier.
For photo purposes I was holding a dozuki cause it was
handy. For dovetails, the Odate Dovetail saw is much
shorter - and the stroke is only maybe three inches at
the most. And since this is a finesse/control cut, not
a power cut, there's very little force involved - if you
let the teeth do the cutting - on the PULL stroke.
Tage Frid used that trick too. Problem with mirrors is
that you're seeing a mirror image. When you're looking
at things directly, the brain doesn't need to make any
adjustments.
Well there's another difference between western push
saws and japanese push saws - the teeth - what kinds
and how they're ground/filed. The teeth on a japanee
saw are a mix, one tooth does one thing, the next
another and and the next one does another before the
pattern repeats. And each tooth has several "facets".
So the japenese saw cuts wood in a very different way
than a "western" saw.
> with a Japanese saw, compared to a
Ah - there's another difference. You want to align the
cut to TWO straight lines - one on the end grain and one
on the face grain, the two lines falling in planes that
are square to each other.
With a push cut saw, the part is usually held vertically
and you're seeing the end grain horizontal line best,
standing looking down towards the part. If you cut
straight down on the end grain line you'll have a problem
when cutting tails because their sides slant outward
away from the end grain line.
But with the part horizontal you can see the entire
scribe line on the face grain. If you rest the saw blade
on the juncture of the face grain and edge grain line -
and pivot off that point to align the far end of the
blade to the face grain line - left thumb nail ON THAT
LINE - blade against that thumbnail, you can make a
slanting initial cut - that's about half the desired cut
length - AND - down the line on the end grain - just a
little.
NOW, when you rock the saw to vertical you've got a
notch at the top of the line to register the saw blade to
and can make the first light vertical cut in the end
grain - TO the end grain line.
For both cuts, you want to LEAVE THE LINE, or, if
you're really good - SPLIT THE LINE. You DO NOT want
to TAKE THE LINE since it's the only thing to tell you
where you are relative to where you want to be.
There's a LOT more to using a handsaw, pull or push to
cut, than just PUSHING or PULLING it through the wood.
Starting the cut is the critical part. If you blow that -
trying to STEER the cut to correct the intial problem -
or once you're into the cut - usually make for more
problems than it might solve.
And this points up another difference between the two
types of saw, and how they're used.
The "pistol grip" push saw encourages / allows you to
do things you shouldn't do.
Let's start with the intial face grain/end grain corner
cut. With a push saw the teeth are cutting "uphill" -
into the end grain. Nora Hall, a euro trained carver, and
excellent teacher (DVD only for me unfortunatley) uses
a "Broom Bristles Analogy". If you try and cut a
broom's bristles from their ends (UPHILL) - the
bristles are separate/spread (tear out) rather than
being severed. BUT - if you cut TOWARDS the end of
the bristles (DOWNHILL) - you can sever them.
So - with a push to cut saw, and the part vertical, you
have to drop your "saw hand" and point the tip of the
saw UP - AND - have the saw at an angle - to start a
Pin Cut - IF you don't want to cut "UPHILL". That's
pretty awkward. If you start the cut down the "back
side" of the part you're sawing into the "end of the
bristles" AND it's also awkward.
With a "pull saw", starting the cut - while standing - is
a LOT less awkward - and avoids the "cutting uphill"
problem.
> line.
That's true - but - unlike a push saw, the pull cut saw
handle discourages "muscling it" to correct a cut gone
awry because it's more delicate, unlike its push cut
cousin.
THAT we absolutely agree on. It's usually the Loose
Nut on the handle end that's the source of most
problems - regardles of the tool being used.
Well I'm not so sure about that.
You must remember that european woodworking comes
from a tradition of "do it yourself" - or maybe relying
on a blacksmith or tool maker to make your tools. And
since sophisticaled metallurgy came to europe - and the
americas - late in the game relative to Japan this is
notsurprising. So once you had the saw, YOU had to
keep it sharp. A flat file and a triangular file were all
you needed to do that - and something to hold the blade
while you filed of course.
Japan had much more sophisticated metallurgist/tool
makers - namely sword makers. When Samurai fell
from favor they shifted that edge tool making
knowledge and skills to other things - knives - and
woodworking tools - like the saw. And the clients of
the people who bought their tools were a select few -
who were very powerful folk. So a woodworker with
clients like that could spend some money on great
tools, and that supported great tool makers who had
the knowledge and skills to make great tools - one at a
time - and maintain them when they became dull.
SO - one group of woodworkers went about things with
a Make Do With What You've Got, and a Fix It Yourself
approach. If that meant you needed more muscle to do
the job - well handles were not that hard to make - and
there was plenty of hardwood available. . .
I wasn't suggesting putting a push to cut saw handle on
a pull to cut saw, though there are pull cut saws like
that available today. Those saws may turn out to be
similar to "transition planes" as more american
woodworkers get access to and become familiar with
pull to cut saws, with "stick" handles.
Sit, stand, lay down, etc.
Pam Niedermayer, Austin, TX
>Whatever position, it's incorrect to saw with the elbow as pivot point. It's important to saw with the shoulder as the pivot, and elbow and forearm steady in their relation to the shoulder.
Now with super small stuff, maybe the shoulder pivot is overkill, perhaps even detrimental; but at least for regular sized work, should pivot is the bee's knees, fast, economical, easy on the body, all these good things..
Pam
Where it's possible, yes
>Bob's point is that his body no longer allows that.
Dean J in MN
Push vs Pull :: Pin first vs Tail first. It is a matter of preference.
However, what you state above doesn't echo the experience in my push saw shop.
Attached is a photo of the start of a dovetail with my carcass saw. It is hung to allow that uphill cut with my wrist in a neutral position. There is no pointing the saw up, it points up when I hold my wrist neutral. As you say, follow two lines, and this allows me to follow the end grain and face lines, which I can see clearly.
When I'm cutting half blind pins the board is flat on my bench, and again I see both the end and inside face line, and a neutral wrist orients the saw tip up.
Cheers!
Dean
Sure, but I responded to Charlie.
>Seems to me a primary advantage of the pull saws is they can be much thinner steel, thus producing a very much thinner kerf and, at least in my experience, much surer control.
For me, I also like the straight handle, but that doesn't preclude a western saw, as they come in straight handles, too.
Pam
Strongly disagree
Bob Hackett
>Pam,
As evidenced by the number of us who got spanked in the finish thread,The word INCORRECT can be dangerous and prone to backfire.
Most people (not to put words in your mouth)say something is "incorrect" but what they really mean is "that`s not the way I learned it" or "that doesn`t fit the way the way I work right now" or "that`s not the way my Daddy did it".
The more I get into this phase of working either with or around this injury the more it`s driven home that I MUST keep an open mind.Instead of trying to steadfastly keep to my old techniques I`ve found it far more productive and less painful to look at new things(or revisit old passed over techniques) and think about how I can use them to help me.
If it was an absolute MUST that sawing must take place from the shoulder my choices would be limited to either small projects or routed dovetails on larger projects or taking 5+ years to complete a medium size case project.Don`t say I could always learn to saw left handed because the left was butchered by shrapnel and Army doctors and has even less feeling than the right.
One of the gifts this injury has brought me is the paradigm shift in my thinking it`s caused.I now am more interested in the why rather than the how.If something doesn`t jive then I stop and think maybe I could change if I knew why it doesn`t work for me.I try it and if it still doesn`t work then I ask specific questions while keeping an open mind and trusting that it COULD work.It obviously works for the person who demonstrated it or explained it to me.
My personal experience is that keeping an open mind leads to growth for me.Unless it can cause harm or injury,is unsafe or downright dangerous then I try not to think in terms or "right or wrong".
For me,in WWing terms,only the word "incorrect" is incorrect.I usually get in a bind or miss an opportunity for growth when I forget to think and end up using it to describe how other people work.
Many paths to the same destination.
Do you start with pins or tails,Pam?
Mainely,Bob
Re: Strongly disagree
>While I recognize that sometimes there are physical reasons for doing things one way or the other, I do consider it incorrect to advocate not using the shoulder as the pivot point for typical sawing tasks, even when sawing vertically.
Pam
