jointing techniques
paul womack
>In an attempt to clarify recent comments, and stop a useful discussion being side tracked by disputes over jargon, I'm made a diagram.
This shows 3 techniques which can be used to make the edge of a board square to its face.
The leftmost image shows a straight blade, set to take a uniform shaving. The board is made squarer by taking a partial width shaving. The plane is kept stable by being seated firmly on the edge of the board. Multiple shavings using this technique will eventually make a square edge with "steps" which can be made into a smooth, square edge with a finishing pass.
The centre image uses a cambered blade. Again the plane is seated firmly on the edge, and the geometry of the camber allows a tapered shaving to be taken, again bringing the edge closer to square. Sucessive shavings are taken so that the successive tapers can out the error, leaving a square edge.
The rightmost image shows what may be the most obvious technique; the plane is held perpendicular to the edge of the board (i.e. with the sole at the desired angle for the edge) and a shaving taken. This makes a small surface at the correct angle; successive shavings will make the surface larger until it is full width.
I have attempted to make no comment on the relative merits or properties of these techniques; I've merely trying to present some kind of agreed jargon for a helpful discussion.
BugBear
