Wax for Hand Planes
Wax for Hand Planes
Wax for Hand Planes
Henry Allsworth
>Folks, I have seen several masters around the area using a paste/butchers wax of some sort on the hand planes and other tools but can't remember what the brand name is and am curious to know more about it. It comes in a squarish tin with is short and a cream tan color. It has black old style writing some decorative black lines creating some borders on the cover. The wax itself looks to be a light cream/beeswax color and its fairly soft.
Anyone happen to know what it is? It doesn't seem to be one of the common commercial brands.
Thanks
Henry
Re: Wax for Hand Planes
Tim Caley
>I don't know the answer to your question, but I just use Carnuba car wax. Just make sure that it doesn't have any silicone it or you will have finishing problems.
Glenn Madsen near San Francisco
>Are these some sort of super special rare planes? Because on mine, I use whatever wax is at hand, neutral colors only. Liberon, Butcher's, Briwax all come to mind. The Liberon is the softest of them, whatever that means.
Nothing waxed rusts here.
Brian Greene
>I too use whatever comes to hand. Having said that, I usually have a lump of parafin in each shop apron and while working simply squiggle a line down the sole of my plane from heel to toe. I've seen others wipe the sole with paste wax. Whenever I sharpen, I blow the shavings from nooks and crannies while the plane is apart, wipe down the freshly honed blade with whatever light coloured paste wax is at hand and lubricate moving parts,if required and sparingly, with Boeshield T-9. No rust and considerable reduction in friction when planing.
I've been told that car wax has abrasives
Bill Houghton, overcast Sebastopol, CA again
>Car wax used to have abrasives in it, to cut through the oxidation on the paint while waxing it at the same time. For this reason, I reserve car wax for the car (LOML would laugh, considering how infrequently I wax the cars), and use regular furniture paste wax on tools (currently Minwax in a can, $5 or so at the Big Orange Box Store several years ago; at the current rate, I won't need to buy it again for about five years).
Alex Grigoriev
>I use a white paraffine candle. A couple swirls on the plane sole, and it *flies*.
steve mackay
>Don't know about the square tin but my round tin of Johnson's has been going a long time. Of course now that I've got a CAST IRON TS table ( evil cackle ! ) I guess I'll be useing more of it. Smoooooooooooooooooooth !
ThomD
>Bees wax gratted fine and melted (room temp) into liseed oil is great. Or similar bees wax preps. BW is an amazing material that stands up to high speed lathe turning, as a bearing better than a lot of hight tech greases. And it's very nice stuff to work with. A proper plane doesn't really need any, but I suspect it makes the block last a little longer, or are we talking cast iron. Either way.
me too
roninkokomo
>I have used Johnson's Paste wax forever.
I did use some beeswax and BLO/terps on some of my woodies. Works Great!
Goddard's, I think, but
Joe Shelton
>candles and canning wax are just fine, too
Beeswax and Lard
Michael Brady
>I think the wax you are looking for is Goddard's. I checked their site and it looks like only a spray liquid form is still available. Woodcraft carries several brands of good past wax, but honestlt, for hand tools, I would just use Johnson's. You have to keep applying it to tools as you use them and it is kind of wasteful to use fine furniture wax for that purpose. Renaissance Wax is the one most museums use.
