My new Heiji ryoba (long, lots of pics)
wilbur
>(This one's for you, Wiley!)
It's probably not a real secret that I like using Japanese saws. Up to now, the Japanese saws I've been using have been the Gyokucho replaceable blade saws, which are indeed very nice saws. But having read about the Yaitaki saws that Wiley, Pam, Denis, and others have written about, I got real curious about how a handmade Japanese saw might be like.
Problem is, there aren't many Japanese saw makers working these days. There was Yaitaki, but he's retired now. There's Mitsukawa. And that seemed to be it, until I started exchanging emails with So Yamashita, who is living in Australia, and has a website that sells Japanese tools (www.japan-tool.com). So's a great guy. He has a wealth of information about Japanese tools and their makers. He also has many tools that sell in nosebleed price ranges.
I initially emailed So about the Japanese saws that he had listed on his website, which seemed to be all "New Old Stock". I asked him if any of the makers of the saws he carried were still working, since I didn't want to be in the situation of having a saw by a maker that I really liked, and wanting to get more, but then finding that all of the old stock was out. Also, I felt that if I was looking for a handmade Japanese saw, I should do my part to keep that industry alive by supporting an active sawmaker.
So then told me about Nakaya Heiji. Heiji is a 5th generation saw maker who's apparently well known in Japan, but not so much in the U.S. His saws are usually completely handmade. Many "handmade" Japanese saws are made with machine pressed steel blanks. Heiji does every step by hand, including the initial forging of the blanks.
When So told me the price of the Heiji saws, which were about US$550, I pretty much passed out. It is probably true that making a saw by hand is probably one of the most labor intensive tool making processes out there (I'm sure Mike Wenzloff will agree), between the forging of the blank, the tempering, the scraping of the blade, the tensioning, the cutting, setting, and sharpening of the teeth. There's a very good video showing the making of a Japanese saw by hand, which gave me a lot more respect for this process. The video's in Japanese, but you'll be able to pick up what's going on just by watching.
After a while, and after picking Wiley Horne's brain (not for the first time, and not for the last time, I'm sure), I emailed So back about ordering a handmade saw, but that I thought that the Heiji saws were out of my price range. So told me that if I was interested, Heiji could make me a not-completely-handmade saw, using a machine pressed blank, if the saw wasn't too long, and that would be a less expensive way to go.
I thought a lot about what kind of saw I wanted, but decided that what I needed most was a smallish saw for joinery cuts. I asked a ton of questions which So patiently answered, and finally decided that the best way to get what I needed was to just have So order a 210 mm ryoba from Heiji, made with the machine pressed blank, set up to make joinery cuts in 4/4 North American hardwoods, especially paying attention to the rip side of the ryoba, which I was intending to use for dovetail cuts, and trusting that Heiji would know what to do.
About a month later, this comes in the mail.
Heiji saw
Heiji saw
It's a lot prettier than my Gyokucho saws, for sure!
Looking at the Heiji ryoba, there are some definite differences between the two. The blade of the Gyokucho ryoba that I have (no. 611, 240 mm, which is optimized for hardwoods) is an even 0.018" throughout. On the Heiji, there is a taper along the length of the blade from the handle end (0.027") to the toe (0.015"). The Heiji's blade seems more flexible.
Here's a closeup of the rip teeth. The Gyokucho is on the left, and the Heiji is on the right. You can see the little tool marks on each individual tooth on the Heiji ryoba, as well as the marks from scraping the blade of the ryoba.
Heiji saw rip detail
And a closeup of the crosscut teeth. Again, the Gyokucho is on the left, and the Heiji is on the right.
Heiji saw crosscut detail
The teeth on both the crosscut and rip sides are slightly more closely spaced on the Heiji. Like all ryobas, the rip teeth have a progressive pitch, with a finer tpi near the handle and a coarser tpi towards the toe. The rip and crosscut teeth have a different profiles, as you can see from the pictures above, with the gullets between the teeth seeming to be deeper on the Heiji. The crosscut teeth have a more aggressive looking profile, as well.
By the way, I'm just trying to describe what I see. I have almost no idea what these differences mean in the world of saw tooth profile theory.
So how does this saw perform? Well, I wanted a good joinery saw, so let's cut some dovetails. I took a piece of 3/4" thick white oak, and marked off some sample dovetail cuts.
Heiji saw - dovetail marks
As you can see, some of these lines are for softwood dovetail angles, and some are for hardwood. :@)
I proceeded to saw away. Here are the front and back sides of the board after I finished cutting.
Heiji saw - dovetail cuts
No pencil lines left. Staying on line was really easy with this saw. Who needs a backed saw for cutting dovetails? It doesn't look like I do anymore!
By the way, there's one thing that I've always had an issue with dovetail saws and dozukis. I always had the feeling that the back of the saw would get in the way of my looking at the line. That's why I was interested in seeing if I could use a ryoba for cutting dovetails, knowing that the pulling action of a Japanese saw would keep the cut very straight.
After trying out various cuts with this saw, especially dovetail and other rip cuts, I don't think that this saw will win any speed records for rip cuts, although it seems to cut pretty fast. I don't have much experience using western dovetail saws, so I don't know how this compares, but for the record, after the initial small strokes to get the cut started, it took about 18-20 strokes to get down to the baseline (3/4") in this 3/4" piece of white oak with the Heiji saw.
Now, to be fair, I'm able to do the same thing with my Gyokucho hardwood ryoba. But the actual cutting seemed to be more smooth with the Heiji, probably because of the tapering. It's difficult trying to describe the difference between the smoothness of the cuts. The best that I can come up with is that it's probably the handsaw equivalent of the difference between an average hand plane and a fully tuned and sharpened Lie-Nielsen. I also felt that in other cuts that I made I was able to steer the Heiji more easily than the Gyokucho.
But where the Heiji really shined was in cuts that it wasn't really designed for.
(Warning: graphic pictures of hand tool abuse coming up.)
Here's the block of wood that I got the 3/4" white oak scrap for the dovetail cuts above.
Heiji saw
This might look familiar, if you spend too much time on wooddorking [sic] internet forums like I do. It's the same piece of 8/4 white oak that I used in my Imai chisel torture test that caused much consternation on another forum.
Here's how I got my test board for dovetail cuts.
Heiji saw - resaw abuse
Staying on line for the long cut on the longer side with this saw was a piece of cake. I started the cut on the far corner, and focused on aiming the saw all the way to the end of the cut on the near corner. I didn't even look at the line along the cut. The pulling action of the cut keeps the ryoba in a straight line.
I also crosscut this 8/4 white oak board with the Heiji ryoba, but forgot to take pictures of that process. This picture is a staged recreation of the pieces. I can't believe how well the crosscut side of the Heiji ryoba cuts. Not only am I getting a clean cut, but the surprising thing is how aggressively the crosscut teeth goes through wood. The crosscutting action of the Heiji is noticeably more aggressive than the Gyokucho.
Heiji saw - crosscutting
So if anyone's worried about using Japanese saws in hardwoods, don't worry about it. All of the teeth of my little ryoba survived this 8/4 white oak.
Again, to be fair, I can do the same thing with my Gyokucho saw. But the Heiji ryoba, even it's woefully undersized for this sort of operation, cut noticeably more smoothly than the Gyokucho in this 8/4 stock. This was a bigger difference than when I was making joinery cuts in 4/4 stock. I think that the tapering of the Heiji ryoba is the biggest contributor to this.
I wish that I could tell you how much my saw cost, but I'm still waiting for So to send me an invoice. You're reading that correctly: he sent me the saw without any payment or deposit. Based on an estimate that he gave me, it's probably going to be in the same price range as a pair of Wenzloff rip and crosscut tenon saws.
I really love using this saw. I have a hard time seeing how using a hand forged blank would improve the cutting action of this saw at all. The only minor nit that I have is that I sometimes wish that the rip teeth had a slightly finer tpi, to make it a bit easier to start the cut, but I think that this is also a break-in issue, as the saw is so new. I have found that since I got the saw, starting cuts is getting easier. I sometimes wish that I had gotten a 240 mm ryoba from Heiji instead, but overall I'm glad that I have a ryoba that's a different size than the one I already have. I also sometimes think that I should have gone for the completely handmade ryoba instead of the machine pressed blank, but then I realize that that saw can wait for the day that my skills are good enough for a saw like that. Besides that, my wife would really kill me if I got that saw now, and my boys need their father. :@)
Thanks to Wiley for letting me bounce ideas off of him, and for giving me the nerve to order the saw. This is the second most expensive tool that I have, after my 10" jointer/planer combo. I didn't even pay this much for my bandsaw (thanks, Craigslist!). If in the future I am trying to retire and find that my 401(k) is replaced with a pile of handmade Japanese saws, Wiley's the one to blame. :@)
Re: My new Heiji ryoba (long, lots of pics)
I must say...
>That this is probably the most thought out purchase of a hand tool in recent history. The depth and effort you when through on your research, the experts you consulted and the agonizing over the decision is to be commended.
More people would be happy with their purchases if they went through the process, great work Wilbur.
And I didn't even make a comment about using those saws backwards (oh, well, I guess I did).
Stephen
Where's the Nib?
Parisian, VL
>Very nice write up Wilbur. I love my "cheap" Japanese saws from The Cutting Edge here in Houston. Looking forward to trying one like yours.
Again, nice write up.
Regards
Victor - in Hot and Hotter houston
Wiley Horne--So. Calif
>Nah. Thank you. Wilbur. But it's not for me or anything to do with me. This one is really for those guys that make fine tools by hand and sweat, and that endure everything to follow their commitment. According to So, Heiji can't eat by making saws. To eat, Heiji makes knives--the saws he makes for himself and for his tradition. It reminds me of Mike Wenzloff, another superb sawmaker, who pays a personal price for every saw he makes. I keep telling him, Mike, raise your prices. Not about the money--you can't physically keep this up at that quality level for that price.
Wilbur, that's a great video! I never saw that one before, thank you very much. Also, that's some really pretty sawing. I especially like the resaw job. Just as a personal observation, it's very telling what you related about the thickness taper of the handworked saw vs. the Gyokucho. The greater thickness of the handmade saw up near the heel (handle end) combined with the hammer tensioning gives these saws a unique action--you don't get that flyswatter effect.
Unsupported opinionizing.....Fine saws are the least expensive of woodworking tools, for what they are and for what it takes to make one and prepare it for use. We think they're expensive, but the guys making them aren't getting rich doing it because of the hours of work that it takes. I would encourage anyone--once you know you're in hand tools for the long run-- to obtain fine saws. Whether it's a vintage American or English saw, or a new wellmade western saw, or an excellent Japanese saw. Whatever your personal preference, get fine saws. [end rant] Oh, I want to hear and see more about Adam's newly minted saws, too.
Wilbur, many happy returns! Rule of thumb: Make your saw till twice as long as you think you need, and it may do you for 18 months.
Wiley
Pam Niedermayer, Austin, TX
>Quite an adventure, Wilbur. It's taken me a long while to realize what great deals most Japanese hand made saws are, $500 seems especially cheap given that the retailer chain probably gets 50% of that. Years of great heaving gasps when presented with prices.
And yet, this situation is very depressing. An artist who can't sell his product for enough to live and a buying public who are aghast. Saw somewhere the other day that if employee pay had kept up with executive pay over the last 30 or 40 years, the average yearly worker pay today would be about $500k. At least you're in one of our few growth industries. :)
Pam
MikeW
>Wonderful, Wilbur!
Aside from the evdence of scraping and the thousand love taps of tensioning, I realy appreciate the looks of the hand filed teeth of the Heiji saws. Quite nice looking.
Too bad the Japanese saws you hae cannot handle that hard Oak very well .
Congrats on the purchase. Like Wiley wrote, make room for others.
Take care, Mike
Two for one prices.
Marv....... Northern California Lake Co.
>Hi Wilbur,
Outstanding post....great pictures...
With a japanese saw, you get no extras like a useless nib but you do get two saws for the price of one.
Marv
Ryoba nibs :@)
wilbur
>Of course Japanese saws have nibs. Four of them, in fact. The ones closer to the handle are used more often, of course, since the ryoba cuts on the pull stroke.
Ryoba nibs
Take plenty of these with this post. :@) :@) :@) :@) :@) :@) :@) :@)
Re: I must say...
wilbur
>"And I didn't even make a comment about using those saws backwards (oh, well, I guess I did)."
Out of curiosity, I tried using this ryoba backwards. For some reason, holding the ryoba by the blade and rubbing the handle on a piece of wood didn't seem to do much. :@)
Wonderful story Wilbur...
Denis Ch�nard, Orl�ans, Ont.
>I'm glad you "made the jump", handmade saws are fantastic, wish I could afford more myself...
It's a sad thing that the remaining Japanese masters don't make a good living even at the prices we pay for the saws, such is the amount of workmanship in them... I just hope that some makers figure out a way to keep the tradition going (at prices they can live with).
DC
No, he means
>doing one of those Annie Oakley shooting-competition things, where you face away from the wood and cut without looking at it.
Yery nice saw Wilbur...
Scott Burr in Ben Lomond, CA
>I myself would be afraid to use it. Knowing me I'd bust a tooth or two off of it.
More Heiji stuff
>Hi Wilbur,
Just a belated congratulations, since I neglected that in my initial rant. Heiji-san makes great saws. I recently received one in the mail myself, a 210mm yokobiki (crosscut saw, unbacked, for you English speakers out there). In regard to the number of strokes to the scribe line, I think this is sawing technique, as opposed to some particular property of the saw. I went and found a 4/4 stick of white oak, and tested 4 saws ripping to a scribe line placed 3/4" down the face. The first three saws were a 240 rip dozuki (21 ppi), a 210mm ryoba (10ppi rip side @ midblade), and a 210mm tatebiki (rip kataba, 10ppi midblade). I sawed with the same care I would use on a project, and that took 7 strokes to the line or 8 strokes if on a slant. However, each of these saws has a significant negative rake (teeth angled aggressively into the cut). So I picked up a 270 rip dozuki (13ppi)--this saw has zero rake--and that saw was 5 strokes to the line, if sawing with care, and 3 otherwise.
What I mean by technique is that, for rips, I put two hands on the saw, which puts a slight downward pressure on the saw, just enough to keep feeding new teeth into the cut. Two hands is an old habit from playing infield. Feels natural.
Anyway, Heiji's saws are incredibly sharp, and I note from your photo that yours has about zero rake. So I suggest that your saw will get to the scribe line about as fast as you want it to--just a matter of feeding new teeth into the cut. Not that speed is important in sawing joinery. Just that the saw itself doesn't have an inherent speed, based on its particular ppi and rake.
Wiley ...... with way too many saws, and getting a hankering for more
Re: More Heiji stuff
wilbur
>Hi Wiley,
Interesting data on the number of strokes for a dovetail cut. Do you normally use a two handed grip with a Japanese saw when sawing dovetails? I use Japanese saws one handed, myself. I still haven't got the hang of the two handed method, even for longer cuts.
7-8 strokes to cut to a 3/4" scribe line in white oak! I once asked a question as to whether my ryoba was too small for a big cut through 8/4 white oak, or if I was just sawing like a wuss. I guess we all know the answer now. :@)
wilbur
>"At least you're in one of our few growth industries. :)"
I look forward to the day that I am put out of business. :@)
>Hmmm, using my LV pro dozuki I took at most 3 strokes to cut a 1/2 by 3/4 dovetail in black walnut. I compared that to a LN straight handled dovetail saw, same results. I mean, zip, zip, it's done. One handed in this case. I'm not bragging, but I do wonder why you guys require so many more strokes. What am I missing here?
Pam
Japanese saw makers
wilbur
>Hi Denis,
Like I said, one of the things I felt was important for me was get a saw from someone who is still active in Japanese saw making. At one point, I tried to compile a list of all the makers of Japanese saws that seemed to be readily available today. This is what I came up with, and where you can get them:
Heiji (japan-tool.com)
Mitsukawa (several grades: Hida, Iida, Tools for Working Wood)
Chuyemon (Hida)
Asakura (Iida)
Kaneharu (japanesetools.com)
Hishiki (The Japan Woodworker)
Kondo (The Japan Woodworker)
Nagaoke (The Japan Woodworker)
Shindo (The Japan Woodworker)
Of these, the active sawmakers seem to be Heiji, Mitsukawa, Kondo, and Nagaoke, and whoever is making saws for Kaneharu and Hishiki, both of which seem to be brand or company names, and not actual saw makers. Shindo and Chuyemon are retired or passed away, and Asakura is only listed as having a 210 mm ryoba available. Kondo and Nagaoke don't seem to be making saws at the same level as the upper level Mitsukawas. japan-tool.com lists a number of saws by other Japanese saw makers, but they are all retired.
So as far as active handmade Japanese saw makers go, that leaves Mitsukawa, and Heiji, and that's it. Mike Wenzloff mentioned on a recent Hand Tool chat that he's making a pair of Japanese saws, which, if he were to do this full time, would increase the number of active makers of handmade Japanese saws by 50%!
I did think pretty hard about purchasing one of the Chuyemon saws, and having it tuned up by Mark Grable. This would have been a less expensive way to go, and I think it was Wiley who said that I would get excellent results this way, but overall I feel really good about supporting an active toolmaker instead. I definitely know where my next Japanese saw will be coming from, unless Mike W. takes me up on my suggestion. :@)
Luckily, although Heiji has stopped trying to make a living by being only a sawmaker, it appears that he's quite a way from retiring, and based on my experience, it's a very easy process to order a Heiji saw.
Re: Yery nice saw Wilbur...
wilbur
>Hi Scott,
That's one of the reasons that I tried doing that resaw cut with a Japanese saw that was too small for the job - to see how hard you could push this saw. I think that Japanese saws aren't really as fragile as one would believe based on conventional wisdom. And based on the posts by Wiley and Pam below about the number of cuts needed to make a dovetail cut, you can use these saws much more aggressively than I do.
I guess I really _am_ a wuss. :@)
wilbur
>My first guess would be that the main difference is sawing through black walnut vs. white oak. But tonight I'm going to give it another try, being more aggressive with the cut, as Wiley is using fewer strokes than I am. I might also try a piece of walnut.
>Hi Wilbur,
Really, I think speed is of no consequence. My only point was that the saw itself does not have a natural speed, but rather that the cutting speed in a given piece of wood depends 90% on technique.
What is of consequence is accuracy and repeatability, which means finding your groove. Did you mention a concern about seeing around the spine of a saw? Do you have both eyes open when sawing joinery? Open em up. Same as I was taught to shoot the M1 in ROTC many years ago.
By the way, I don't think anyone teaches two-handed sawing. They teach one-handed as far as I know. But somehow when ripping using the pull stroke, I fall into an old baseball groove, and using the second hand makes everything come together for me. I doubt it is 'correct'.
Wiley
>Odate "taught" me two-handed ripping; but it was so natural that all it took was a suggestion that it might be a nice way to do things.
Pam
>Thanks, Pam! Sometimes when I work things out for myself, I find out later it's wrong, so I didn't want to lead Wilbur astray. Your information helps a lot.
Wiley
>He also taught the single armed method, which was a lot more difficult for me.
Pam
wilbur
>So I tried sawing some more 4/4 white oak tonight with my Heiji ryoba, and the best I got was 10 strokes to a 3/4" line, which is much faster than what I had been doing, but which required pulling down into the cut much more than I have been, or was comfortable with.
I tried sawing two handed as well. For me, I'm not sure if that method is good for a joinery type cut, but I can see an advantage for a longer/bigger cut. I'll have to practice more.
So technique probably has a lot to do with it, which means that I do saw like a wuss, I guess. :@)
On the other hand, I was able to get to a 3/4" line in 4/4 cherry in 4-5 strokes with my Heiji ryoba, which seems much more reasonable to me, so maybe it's just that particular piece of white oak that I've been playing with. Now that I think about it, that's the story I'm going to go with. :@)
I agree that joinery cuts and speed really don't go together. In fact, the thing that I highly disliked when I was going for the speed cuts was that I felt that I wasn't really in control of the saw, although it's a testament to this saw that it still cut perfectly straight and to my line even though I thought I had no control over it.
The main thing I wanted to convey in counting saw strokes was to try to describe how quickly this saw cuts.
I do have both eyes open when making these cuts, but I think that I am so right eye dominant that even with both eyes open, I have trouble seeing "around" the back of a dozuki. In the past, I've found that I have the same issue the few times I've tried target shooting, with either pistols or rifles. With both eyes open, if I line up the sight and then close one eye or the other, the sight invariably lines up with my right eye. Still, I was able to hit the bullseye and tightly group my shots anyway.
For sawing two handed, I assume that for this you have to clamp or hold the wood down somehow? I think one reason that I have been primarily sawing one handed is that I often will make a cut by placing the board on my bench, kneeling and/or crouching down in front of it, and sawing in a vertical manner so that the pull stroke clamps the board to the benchtop. I can't see doing this cut two handed without some sort of mechanism to hold the board. I'm sure that this is an obvious thing, but I wanted to be sure that I didn't miss something.
Also, do you use a two handed technique for dovetail-type cuts?
Well Wilbur, your not the only wuss haning here!
>I got the BST set of saws when I passed 6 months of quitting smoking.
I've busted 2 teeth of of 2 of the saws. Thank the maker they make replaceable blades!
