source for cast iron plate
George Allchin
>All the talk below about diamonds and cast iron for sharpening got me thinking...... Where can I get cast iron. I opened up my Mc Master Carr catalog and found cast iron in the index.
I bought a 1" x 4" x 36" piece for $87.00 and 2 "grits" of diamond paste for $25.00 more. I plan on cutting the plate in 3 - 12" pieces, surface grinding them flat, and yee haa, a polishing we will go!!!!
Kind of expensive but I will have 6 surfaces to use.
When in doubt look in Mc Master Carr.
George in Lowell, Mich.
Re: source for cast iron plate
bill tindall
>What is the surface on the plates as supplied? They may be already Blanchard ground which we have found to be acceptable.
Re: surface of cast iron plate
George Allchin
>Bill,
I'm not sure what I will get but I should know next week when it arrives. I work in a toolroom so I plan on surface grinding it, after I cut it into 3 pieces.
I'll let you know what I get.
George
Paul Alt on Cape Cod
>The McMaster Carr cast iron plates are "as cast" and oversized so that after surface finishing they will meet the advertised dimensions.
Paul
how to surface plate
bill tindall
>We tried simply milling plate and that did not work for 1 micron grit.. apparently the mill tears particles out of the cast iron and leaves a mostly micropitted surface. Very little contact with tool. Surface ground plates have worked fine.
Bill, 1 Micron is pretty fine
Forrest Addy
>Bill, 1 micron is pretty fine. I get mirror bright finishes lapping carbide and hard steel with 9 - 12 micron (green) diamond. The reason I bring it up is finer - slower.
