More Articles Up
More Articles Up
More Articles Up
Garrett in Victoria BC CA
>Thanks to Scott Freedman, Scott Perry, John Truxell-Svenson, Dave Runkle, Dave Frommer, and Dan Donaldson, many more articles have just been published in all categories of the Articles & Reviews site.
There are many, many more on the way so keep clicking the flashing dot on the maroon menu to your left.
Cheers, Garrett
Editor
Re: More Articles Up
deanj
>Thanks all:
I have a question however -- In Plane Iron Testing
by Roger Nixon.
I didn't see any mention of the mouth of the plane being changed. If you use a thicker blade you by default get a smaller mouth opening, which leads to less tearout. So if Roger didn't adjust the mouth to be the same for each blade the findings are not all the suprising -- A larger mouth will tend to make tearout more apt to happen. So, using tearout as a critera is sketchy of you aren't keeping all the variables (other than the blade) constant. Granted you can't keep the wood 100% constant, but the plane setup should be.
Re: Hey! Where's my flashing... *LINK*
>Click on the link. Can you see the maroon menu? My dot is flashing.
Cheers, Garrett
Message Board
Scott Burr in Ben Lomond CA
>I alwasy come thru the front door. I restarted Netscape and bingo! It's back
