A55 Smoothing Plane
Question about Bessey I-beam clamps......
I am curious to know more about these clamps......has anyone used them ??.......and what do you think of them??.......how do they compare to other clamps you have and use??.......would you recommend them for making panels??......etc etc.....
That they are advertised to be capable of 7,000 lbs of pressure is totally ridiculous for woodworking......if you need that much pressure to bring your work pieces together, you need to spend more time in stock preparation to say the least......but, have you found that they have a legitimate role to play in your woodworking??
Re: Question about Bessey I-beam clamps......
I have a bunch of their K body parallel jaw clamps buy not the I beam/sash clamps. Pipe clamps have served me well for 35 years when I needed the length and didn't have the money to buy K body. Now I have the money to buy K bodies and love them.
As often happens on WC I will answer a different question....I don't have any Bessey I Beam clamps but I do have some similar clamps and an alternative.  I find my I beam clamps to be heavy and awkward and the steel in them will stain woods with high tannins like oak.  Generally hateful.  The alternative (as suggested by Bill Tindal) is Dubuque aluminum bar clamps.  I have a dozen of them and they are my go to clamps.  My I beam clamps sit in the corner unused and my pipe clamps I have had since I was a kid only get used when I run out of Dubuque Clamps.  The aluminum does not stain the wood and they are light enough that you can carry three in one hand with no strain.  I don't know what the pressure rating is, but it's enough.  I just did a quick look up one the Internet and they may be cheaper than the Bessey version.  I bought mine years ago from Harry Epstein.
Dick......I also have a good collection of Bessey K-bodies, Bessey F-style, and pipe clamps.......and a little money that my X and her lawyer didn't take......and I like the clamps I have......but, I'm curious about the I-beams......
Barry.......LOL.....thank you for your reply......as you noted, the specific information sought is often not addressed......
Yeah, 7000lbs of clamp pressure is over kill of over kill.  And I've handled them in the store, and they are obviously heavy...heavier than k body. I would think these would tend to be used on large carcus glue ups...something of a big nature.  And swinging around a heavy clamp during glue up tends to make me mishandle them and makes the glue up go longer.
I purchased 12 for a big heavy job   disappointed in fit and finish  you can definitely tell Bessey lowered their quality by manufacture in China!  looked at the new I beam from Adjustable Clamp, made in China as well but the fit and finish looked better than the Besseys.   They have a purpose in the shop for large heavy glue ups in my humble opinion.
Michael and Al.......thanks for your replies.......I don't see these heavy clamps as the type you'd be swinging around adding to a glue-up here and there......but rather, used as the base/bottom clamps sitting on a worktable to start a panel glue-up for example......taking advantage of their flatness and lack of flexing......then add more maneuverable clamps on top of the panel to counter the Ibeams as necessary.......large heavy glue ups does seem to be their purpose........
I find the Debuque clamps to be terrific also. They cost about $38. A really  good and inexpensive hack is to get HF aluminum ones for about $11 and insert a length of wood. Got the idea from Paul Sellers. I use these just as much as the Debuques and they work perfectly for low pressure stuff.
I bought a number of these clamps. I watched some videos on YouTube that reviewed them. The following addresses some of the comments made in those reviews. The clamps came well packaged......they were shipped in bubble -wrap and cushioned in a cardboard box.....
I tested their holding ability by clamping down on a 2x4 with no movement/slipping of the clamp.......
I made some clamping pads with a 3/8" magnet and also some supports that will prevent the clamps from tipping during glue-ups (the clamps seemed fairly steady anyway without this aid).
They are heavy coming in at just under 11 1/2 lbs for the 48" clamp.......they will be used as the bottom clamps on substantial panel glue-ups and other larger projects.
