A friend has some sort of tool attachment for a mill. It's in a plastic box that has failed from exposure to sunlight. Crumbling to ruin. I am going to try to make a wooden box to replace the plastic. It will have a number of fitted compartments.
What wood would you use? I am eyeballing a piece of red oak just because it's sitting in a obvious spot. I have many other possibilities. Should I be concerned about the tannins in the oak marking the tooling?
I would go with a close grain hardwood like maple. Tooling tends to have sharp edges that can cause cuts and splintering. Even if you are talking about something small like a set of parallels. Oak just wouldn't be my first choice.
Agree. But even Gerstner boxes are only oak on the exterior with interior parts other hardwood covered in felt. I just don't think oak is the best choice for compartmentizing a box intended to hold potentially sharp edged steel parts. Just my two cents.
Make the box out of a wood of your choice, but realizing that it will live in a machine shop environment, so it'll see oil, dirt, dents, and a bit of bouncing around. The insides for storage cavities can be made of nearly any wood, as all woods are softer than steel, but a tighter grain would would be less apt to chip or splinter during use. Don't finish the wood inside. Spritzing with some oil will keep rust from forming on the tool.
I would pick maple too, even though oak is cheaper. I think maple is better because it's close grained, it's tight and very resistant to abrasion. The attachment will be sipping oil, quite often have some chips on it - if that would get into oak it will make the box look filthy. Those attachments are heavy, maple doesn't ding as easy as oak.
And nothing wrong with plywood. See if he has other boxes, maybe you could blend yours in. Plywood can look very nice, esp for applications like this, it's also quite durable.
Since the original plastic failed from sun exposure, I'd guess the replacement box will be subjected to outside environments. I'd use a marine plywood to make the box exterior and anything else appropriate for the fitting system. Is this a sawmill? What kind of accessories does it hold? Blades or tooling?
When I was in gunsmith school (Trinidad State Junior College) in Trinidad Colorado each stationary tool type had a box of accessories. We had lathes and Mills. By the way is that mill a Bridgeport?
Each box of accessories was made of plywood and solids (don't know what type) and it was painted. All accessory items were well oiled as they were all oiled in use and then wiped down as part of the process of cleanup. The accessory tray was returned to the tool room when not in use.
My main concern would be to make it rugged. G(glue and nails) So the weight of the accessories doesn't cause it to fall apart on force. I would paint it. I don't want paint or other finish getting on the accessories.
