Solid drawer bottoms: bevel vs rabbet
Adrian Mariano
It appears to be the standard practice when making solid wood drawer bottoms (without slips) to cut an undersized groove in the drawer and then bevel the thicker drawer bottom to fit into the groove. Maybe raised panels are done this way as well? I've done this just a few times and find that it's tricky to fit the bottom because it's easy to bevel too much and make it loose. And actually, if the bottom shrank that would also make it loose in the groove at the front. If the bottom expanded that would make it overly tight, it seems, though I suppose nothing dire would happen. If it's very tight it would not be able to expand into the groove and you'd have less space to take up the expansion (it would all have to go backwards). At least one article I read suggested that the front groove should have extra room to absorb some possible expansion.
It seems like cutting a rabbet would be easier to do and would ensure a perfect fit. But I don't believe I've ever seen anybody suggest using a rabbet. So what am I missing? Why is the bevel better than the rabbet?
(The only thing I can think of is that the rabbet is weaker because it creates a corner, which is a point of structural weakness.)
With plywood the stuff never seems to fit in the groove, and beveling or rabbeting plywood does not seem wise. Widening the groove is more trouble.
