Hand Plane Till questions
I have about six hand planes and may acquire more. Considering building a Till or rack to store them in. I want it to be flexible because I am reasonably sure these are not my lifetime planes. I have some I have had since I was a kid and some I got at estate sales. I will continue to scout for more and may even break down and buy a few new ones.
So any suggestions on a Till. I am thinking of making it with a shelf so the planes will tilt inward at the top and maybe rest on a magnetic bar. This seems more flexible than making one with a slot for each plane and some sort of clip or latch. Any better Ideas out there? Or is this not a good idea at all.
Re: Hand Plane Till questions
I put a piece of carpet on the shelf behind my bench. Didn't have to build anything.
I'll give that some thought
Re: I'll give that some thought
Jim O'Connor
I lay the long ones on their sides on the shelf. The short ones set on a scrap of carpet. No construction, just need space.
Jack Dover
I have built a tilted rack. I have trust issues with magnets, so to prevent planes from a crash on a concrete floor I made these "braces" at the toe, where you push a toe first and then is slides a 1/4" back. A shelf, even a basic one, not only protects from dust, but it also seems to help with rusting, probably by slowing changes in humidity down - I have noticed there's less flash rusting once I've started putting tools in boxes or behind closed doors. Could be important if you're living in a high humidity area.
But if I would have enough space and a proper shop I would just do a tray (or several) lined with a piece of oiled carpet somewhere within my arm reach. They're called bench planes for a reason apparently and out of all features of rack and shelves the most important one is how fast can you garb a plane and then put it back. I think I would find most of the tills from pictures just annoying, they would require me carefully pulling a plane and putting it back would have be even more careful. So all those shoestring loops, mobile tills, holster like holders, etc. - they seem to be just for show
