Loading a Strop
Loading a Strop
Loading a Strop
John Foster
Hi
I have a new wood backed leather strop and a new stick of green compound. My question is about loading. Some sites say just put a trace ( they also use words like just noticeable, detectable, minute ) amount of compound on, others suggest putting on a liberal amount, even warming the strop to melt the wax and really impregnate the leather. What do folks here do?
Thanks
Re: Loading a Strop
Re: Loading a Strop
Jack Dover
There should be sufficient quantity of compound for it to cut. Really hard to describe how much to put on, but I just scribble a few wiggles and then just watch my cutting edge. If it's not polished to a bright mirror a few more wiggles are scribbled, if it's polished but there's compound on a bevel - it maybe too much or it's time to clean the strop.
Or in simple words - it doesn't really matter, eventually compound will smear all over the strop and a single wiggle would be all you need.
Re: Loading a Strop
Re: Loading a Strop
David Weaver
Add a drop or two of non drying oil to the strop when scribbling the crayon and it'll smear more easily.
Re: Loading a Strop
Re: Loading a Strop
I use baby oil to soften and spread the green compound.
Some years ago I compared green compound and diamond paste: http://www.inthewoodshop.com/WoodworkTechniques/Stroppingwithgreenrougeversesdiamondpaste.html
The strop looks very loaded in the pics, but really was used quite sparingly. Here it was freshly applied. I learned that a little goes a long way, and seems to get finer over time. The leather (or hardwood , as I now prefer to leather) will become black, and still be cutting.
Re: Loading a Strop
Would mineral oil work?
Re: Loading a Strop
Yes
David Weaver
Mineral oil and neatsfoot are both good choices. Dissolves the wax a little a greatly improves the action of the strop. Sometimes, a drop of oil is all that's needed to free up the abrasive in the strop and no more is needed.
Same is true for autosol on wood if it cakes. It's usually in need of liquid rather than more abrasive.
Never had a strop come undone from its paddle from oil yet, either.
Re: Loading a Strop
Re: Loading a Strop
Ralph Lipeles
Green is for polishing brass.
If you are stropping tools, I would recommend black emery. I have a double ended arbor mounted to one end of my workbench. It has a wire brush on the left side and a buffing wheel on the right side. I use the buffer for polishing antiques that I am restoring and for buff a just sharpened tool edge.
Re: Loading a Strop
Re: Loading a Strop
I believe the instructions for the Tormek leather stropping wheel says to apply a bit of mineral oil then the compound. They provide a paste compound but the stick compound works as well.
For my leather strops glued to boards, I don't use any oil unless the leather surface is slick. My favorite leather-on-board strop is very thin pigskin.
My favorite strop for some tools such as woodturning skew chisels is not leather but a piece of MDF resawn to expose a rougher surface. I rub compound on the rough surface with no other treatment. This works extremely well.
Re: Loading a Strop
Re: Loading a Strop
Steve jenkins
What about light weight machine oil like used on pneumatic tools.
Re: Loading a Strop
color recommendations
The green stuff largely is aluminum oxide abrasive which is perfect for edged tools.
Re: Loading a Strop
Re: Loading a Strop
William Duffield
Do you think it's a good idea to take machine oil internally? USP mineral oil, found in the drug store, on the shelf with the other laxatives, is a much safer choice.
Re: Loading a Strop
Re: Loading a Strop
William Duffield
Yabbut, I hate the smell of baby oil. It's probably an allergic reaction, maybe to the slightly higher, but still insignificant, price. :D
Re: Loading a Strop
not a safer choice......
.....because there is no safety issue using any kind of light oil on a strop.
Re: Loading a Strop
my understanding is...
David Weaver
...those are usually some kind of light petroleum oil with some additives (stabilizers or corrosion inhibitors? who knows - I don't now much about them). You can check the MSDS to see if any of the additives are objectionable.
That aside, I would use less personal caution on my own strops and just use them and check the MSDS only if they were being used on something that goes in mouths without being washed.
The consistency is about right and I'd bet all or almost all of them would mix with the wax in the wax sticks.
Re: Loading a Strop
Now that bill has spoken..
David Weaver
..he justifies my second paragraph, but even further.
Bill's chemistry-based advice has greatly saved me effort on some things and avoided trouble on others.
My point about just trying it, though, is that unless you have a prized strop (sentimental or something extremely expensive), most things you try won't do any harm and you'll forget you ever considered they would. I've not been that particular about oils on my strops (wouldn't use used motor oil or a drying oil, but other than that) and paralleling what someone else said here - I made 3 paddle strops at one point and have never made another.
I did make a butt strip strop for razors years ago and haven't been picky about what oil I use to clean it, it's also definitely nicer to use now than it was new.
In fact, the only failure of a strop I ever had was expensive horween shell - the surface treatment comes off of it too easily and then what's under it isn't as nice as what's on top. A single razor with pretty spine work ate it and the $175 it cost me to make it.
Re: Loading a Strop
Petroleum oils on leather
Jack Dover
I'd do additional research on petroleum\motor oils, since motor oils make rubber brittle and crumbly, could do it to leather too. I've asked about mineral oil because it's known to be safe on leather.
Re: Loading a Strop
Re: Loading a Strop
William Duffield
I use chromium oxide in mineral oil that I apply with a syringe. I look at it this way: If I get it thinner than optimum in places, it works like an unloaded strop in those places, which is still effective, but significantly less so. If I get is thicker than optimum in other places, when I apply an edge to it, it spreads it around until the thicker places are no longer too thick. My strop is now the same shade of green all over. If it stops polishing or slows down, I add a little more.
I don't use mixed abrasives (containing alumina or corundum, zircon, silica, silicon carbide, cubic boron nitride or cubic carbon, etc.) in a wax carrier (green crayon) for two reasons: wax and mineral oil are redundant, and it's easier to overload the leather with wax. The abrasives that are harder and sharper than chrome, and the scratches they leave in the steel, initiate fracturing of the carbide minerals in the steel and thus premature edge failure.
Of course there are some environmental abrasives that the leather picked up while it was still attached to the horse or steer, or from the woodshop and the edge steel itself. That contamination is probably a large part of the reason "bare" leather is still an effective strop. This last point could be proven one way or the other with some unicorn leather, since unicorns are perfect, and do not take dust baths. :D
Re: Loading a Strop
I have used 3 In 1 oil for decades
Anyone fretting over whatever is in oil should add to their concerns the aluminum and chromium in the green stick and the host of elements- chromium, molybdenum, vanadium, manganese, etc- that could be in the metal worn off the blades. Or, decide sharping a chisel only presents a sharp edge hazard.
Re: Loading a Strop
Re: not a safer choice......
William Duffield
…unless your bench dog chews up your strop. :D
Re: Loading a Strop
William Duffield
Hmm? I think I would recommend against using cutting oil on a strop, just due to the warnings on the label.
WD40 might also have some disadvantages, just due to its long term volatility.
But there are always exceptions, if you dig deep enough, and ignore what the LD50 numbers tell you. :D
Re: Loading a Strop
Re: I have used 3 In 1 oil for decades
Jack Dover
I'm not going to lick my strop any time soon, so the exact oil composition is important only for figuring whether it will destroy a strop in the matter of weeks or not. From my limited experience of working with engines I know that there are materials that would fall apart from very little quantities of motor oils pretty fast. It's nice to know 3 in 1 works though, I have bunch of leftovers kicking around.
Re: Loading a Strop
unrelated
Cutting "oil' not chemically related to lubricating oil. Ditto WD 40.
Re: Loading a Strop
Think old time line shaft factories
If oil destroyed leather we would never have gotten out of the stone age.
Re: Loading a Strop
justify
Justify this statement with data or a reliable reference. I have never seen this claim before.
I use diamond which would be even worse, were your theory accurate.
