Has anyone built a corner cupboard
I may be building one for daughter. I have never studied the framing/joinery of these things, which is much different from anything else I have ever made. I don't have any described in any book I have. A search of the Fine Woodworking CD revealed one by Hack. It involves the daunting task of fitting a long mitered front frame assembly into the case with a mitered joint that shows. I doubt this was a common way to assemble these things, and certainly not the easiest.
What I am looking for is how to assemble one of these things as would have been done by a 1780 cabinet shop needing to make a living:6-sided or 4-sided, back to side joint, side to wing joint(if 6-sided), wing to front frame joint, wing angle to front frame 45 or 90, how is top and bottom joined to sides, what joints hold it together and stiff? Somebody figured this all out in the most efficient way 250 years ago. I need to find where it is recorded
