Bandsaw question
Edward in Vancouver
Couple of years ago I picked up a Rigid 14" bandsaw, brand new. It ran rough, and I ended up "balancing" both wheels with hot glue and pennies. Even so, It still ran a bit rough, most noticably when the motor was running down after I flipped the switch. With the belt taken off though, the motor ran smooth.
In any case, I am able to resaw and make cuts fairly smoothly, but I keep on breaking blades--right at the weld. Doesn't matter what brand, but I always use 3/8 3 tpi, and after say, a dozen uses, the blade always snaps at the weld.
Last night it happened again-- a straight cut in some 3/4'' doug fir, and the blade snapped right at the weld. I unplugged the machine, took off the broken blade, had a long think, and then grabbed a screwdriver and my cheap-o dial indicator. I popped the tire off the top wheel and did some measuring. The wheel is not perfectly round, out by 4-5 "ticks" on one small area (the indicator is divided into 100 "ticks". Hey, I'm a pastry chef, not a machinist....).
Would this be the reason I'm prematurely breaking blades, an out-of-round wheel putting stress on the weld with every revolution?
If so, how can I correct this? Can I leave the wheel mounted and take a file or dremel to the "hump"? Mount the wheel on my beaver 12" gap-bed lathe and "true" it with a file? The wheel is cast aluminum.
As far as I know, Rigid discontinued the model right after I bought it, which probably explains the cheap price I got it for. Seriously doubt if they have spare wheels, and if they do, if the are of the same quality or not.
Thanks in advance,
Edward
