I plan to use a zero clearance insert, a Micro-Jig Gripper, a dial indicator on a magnetic base and the rip-fence fine adjustment knob to cut 1/32” strips with an accuracy in the .001 range.
Are you cutting wood or something more stable? How thick? How was it dried? What species? Wood moves.
The blade can be a lot more important than the saw itself. The blade that comes with the saw won't.
How many miles do you have on the saw?
For those who don't recognize the model number, this is a compact (only 48 lb.) job site table saw, with a direct drive motor, aluminum fence, aluminum rail and aluminum table. The miter slots are cast, so forget cross cutting with accuracy.
Since you have an aluminum table, the magnetic base is useless.
With that set-up, you won't even come close to 0.01.
All you have to do is flex a finger as you push it through, and you miss your tolerance. Any resonance in the saw blade will make it impossible as well. Thickness sanding on a backer board will get you closer, but that kind of tolerance is just not possible. That kind of tolerance even takes diligence in steel. Heat from the cutting process can even throw that off. Curious what you are doing to need that kind of tolerance.
That kind of accuracy is pointless with wood, because as soon as the moisture content changes you will lose it. 0.001" is 3.2% of 0.0325", so even with very thin strips your tolerance can change by +/- 100% of your spec.
Let me describe more of my process and that may answer some of your questions.
I am making thin "planks" to cut scale lumber for model building. I take these planks and surface sand them if they are too rough using a Byrnes thickness sander and saw them to width using a Byrnes table saw.
I am using 2" thick kiln dried and seasoned poplar, with the typical lengths no longer than 16-32".
I have been successful in the past by using Tenryu saw blades on a vintage Delta contractors saw retrofitted with an Incra micro adjustable fence, but in the future, I am looking for a new lightweight portable machine to replace that combo.
I have successfully managed cutting 1/16" strips with a +/- variability of .003" - .005" by using test strips to get the right plank size, and then cutting a board full of planks.
I could use another fastening mechanism to hold the dial indicator since I was just told it has an aluminum table top.
I have not yet purchased the DEWALT DWE7480, but based on my web searches and manual review in seemed like a reasonable portable machine for the application I am describing.
I don't know enough about any particular saw to comment on whether it will work for you or not. I would speculate that blade choice is going to be more important than saw choice, provided the saw has sufficient HP to rip 2" thick poplar with a full kerf width blade. A thick blade will tend to run more true.
I prefer Forrest over Tenyru, but if you've been having good results with Tenyru stick with them. Blade manufacturers might be helpful with suggestions to meet your goal, what with tooth geometry and blade diameter options.
I hope you'll be keeping the setup you have used successfully at least until the new one has proven itself? You're kind of in uncharted territory there, so I think you'll just have to buy the saw to figure out if it will suit your needs or not.
If you are sanding them to thickness anyway why do you care what thickness they are to start out, within reason? I need 1/32" thick strips for string inlay. Fitting inlay into a 1/32" slot is more demanding of thickness than making "lumber". I question whether one can see 0.005" difference in thickness or where it would matter. I saw it more or less about 0.040" and sand to fit snug in the groove.
I agree with others that the blade is more important than the saw. Thin kerf and lots of teeth. However, I would be band re-sawing 4 to 6" wide "veneer" and then sanding to thickness, then ripping out the boards. I am told that with a carbide band saw blade that precise veneer can be resawed and its surface is smooth.
I only sand if the cuts are coming out "rough" with burning or blademarks. I estimate I need to sand about 2% or less of my total runs once I get a good setup.
That is why I am asking about this saw since I don't own it.
You obviously have perfected a thin strip sawing procedure that works better than anything I have discovered. I would like to know more details about exactly how you do it.
After many miles of thin inlay strip as I have cut I would have thought it impossible to achieve the precision you are getting. Typically the inlay is cut fat and sanded or scraped to fit. There won't be much or any experience out there cutting with the precision you require. Most would think it impossible.
As far as the saw I would think that any saw would be as good as another unless the rip fence is of critical importance. With a thin kerf blade any saw motor is going to be able to rip 2" poplar. The only other moving part is the fence. Cheap fences are hard to adjust precisely/smoothly. Depending on exactly how you do the ripping the fence could be a fatal flaw...or not. I think you are going to have to personally check out the details to know for sure it will work for how you will use it. You are doing something that is not commonly done (if ever) so finding reliable experience will not be easy.
I would expect variable results with thin kerf....
John in NM
They are great for lower cutting resistance, but they are not as stable as a thick plate blade. More prone to deflection from dulling and wobble from vibration in the saw (seen both, the latter with a Tenyru blade). Thick blades will also do both, but reason leads me to guess that the effects are not as pronounced.
Thin kerf blades have their uses, but I would not call this one of them. Running a thick 8" blade might just suit this job well however.
I suspect tooth geometry is also going to be important, though it's going to be a toss up between smooth cut (less aggressive blade) and minimizing vibration/deflection (more aggressive blade).
I would not say "perfected", as I generate a pile of waste to get a "good setup".
Once I get my "good setup, I run a lot of wood thru it as it is somewhat difficult to create a setup deterministically. Another aspect which may make a difference is that I am using poplar.
To give a counter example, I used to make rim stock from ash, cherry, and maple for my wife's baskets. I would route the shape and then slice the shape from the board. There was enough variability in that process (+/- .020") that I would run the strips through a Performax drum sander to even out the stock.
Hard to say how much variability was introduced by the router, the stock feeder on the router table, the various woods and the fact that the raw stock was typically 48" in length.
By comparison, poplar in 16" to 32" lengths provides less variability.
Additional setup details include an MDF board between the Incra fence and the blade.
I have built coffe tables, computer tables, rocking horses from red oak using some 6/4 lumber using a Craftsman "1 1/2" horsepower table saw with a Freud thin kerf blade in the past. I am pleased with the results and I am a somewhat particular person.
I've had thin kerf Freuds that cut as well as a Forrest blade initially.
The question is how long that degree of sharp lasts vs thicker blade. Linear feet of thin kerf vs linear feet of regular blade. I've not done such a study and I'm pretty sure blade manufacturers wouldn't bother either - not the sort of thing they are interested in.
Thin-kerf blades are less able to dissipate heat than standard plate blades. As a result, they are not a great solution for ripping lots of stock at a sitting (sawing?), especially in dense woods, which create much more friction and heat than softwoods and poplar. If a thin kerf blade overheats, it can get ugly fast. I have kerfs in an old Unisaw blade insert that my last thin kerf blade created for me, many years ago. It's just never been worth it for me to bother trying to save .030" of lumber. The real reason to use thin-kerf blades is that they require less power to go through the same wood that a full-thickness blade could do with an adequate motor, which makes them a good workaround for people with saws 2hp and less. Unless you're ripping a lot of stock....
I talked to an amigo who happens to manufacture carbide blades, and he demos them at shows using a DeWalt contractor saw, the cheaper one, straight from the box. He can cut some amazingly smooth and uniform rippings with a standard blade, and with thin kerf blades as well. In your case, where your objective is to saw 1/32" thick "planks" from your poplar boards, you'd be turning three quarters of your wood to dust with a standard blade. That may or may not be suitable, but, hey, poplar is really inexpensive.
I just thought I'd mention a trick I used to use to never waste ANY wood. You guessed it, use a plane. I once had a quickie commission to get as many 1/16" thick chips of wood as possible from a baseball bat that Pete Rose had used in the season when he hit his 4,000th base hit. The customer was selling souvenir autographed certificates, with a piece of the bat (a Louisville Slugger, BTW, not the Mizuno that Pete actually used most of the time) and he couldn't afford for me to waste all his precious lumber. The short story is that I set up a hand plane -- probably a low angle jack, IIRC -- to take that thickness shaving, and proceeded to produce 19,000 pieces of wood from one bat.
You could do the same with your planking. You really want to use a low angle plane, though, or else you'll get too much curling and breakage of fibers on the tension side of the shavings. Disclaimer: I have not tried this. I'll be out in the shop later and try some shavings, so I might be reporting back. But it would be easy enough for you to try for yourself. Another upside of this approach is that you will have perfectly smooth faces on your little strips, if that's attractive to you. You also can save the price of a tablesaw and a special blade. The pieces will probably have some curve to them, but I imagine they would lay down nicely on your models.
...when a veneer slicer peels off a piece of veneer, it has a loose face, on the lower, convex side. Different species have different degrees of brittleness, density, etc., so they all react slightly differently to working, with hand tools or power tools. The resulting veneer will have tiny voids and cracks. You really need the grain to be continuous and not cracked in the cross grain.
Yeah. What Barry said. I'm pondering the waste to product ratio when using either the thin or full kerf blades to cut out 1/32 inch strips. Good thing you're not ripping ebony to make model furniture.
I am retiring from my wood sculpting business and am getting rid of all of my floor machines. My Delta contractor's saw was purchase around 1985 and has a 1.5HP motor.
That bat you "said" you turned into 19,000 souvenir pieces? Some people would have kept the bat and turned some other piece of ash into souvenirs. Come on, you can tell US. WE won't rat you out. Is that bat hiding in the back of a closet? The statute of limitations has run out.....inquiring minds want to know?????
Hi George. The reason that I asked is because I have two shops, and in the small shop I have an old Rockwell 9" Contractor's table saw with a 1 hp belt drive motor and a Unifence. It's a great little saw because it takes up about 25% less room then the 10" Delta Contractor's that I have out in the main shop.
