It would seem that all "strip type" 6, 12" wood working rules use something called 4R (1/8, 1/16. 1/32 and 1/64) graduations.
The Lee Valley catalog quotes "making it extremely useful for woodworking". I find the 1/8" useless and the 1/32 and 1/64 inconvenient to read, if not impossible. The problem is that often the best ruler edge to use in a measurement turns out to be the useless to me 1/8, 1/32 or 1/64 scales.
I don't find the 4R extremely useful. 1/16" is the smallest graduation I ever use, estimating fractions of a 1/16 for better refinement. Every edge of a ruler calibrated to 1/16" would be "extremely useful". Am I the only nut case that has this gripe?
I'm with you, Bill. 32nds for marking is useless to me. 64ths are a joke. There's so much fudge there .. the thickness of the line .. the thickness of the ruler .. the angle of view .. general failure of my eyesight ....
About the only time I go for less than 1/16" is measuring from the fence to the blade. This is usually for cutting width prior to jointing. Then, with the blade tooth resting on the ruler, I can estimate between the lines quite well.
I do, however, use 32nds and 64ths and other oddball fractions when designing in CAD. It just turns out that way when dividing into sections sometimes. ..But I never have to measure it with a ruler. The drawing takes care of it.
A lot if this could be attributed to the manufacturing businesses. And about 20 years ago the
whole nation got on a kick of switching over to them metric systems. We have our own system for measuring....and do not need the European systems. Metrics and the medical measuring is
I very rarely use a ruler, probably not since leaving school ( a slide rule was the latest technology then) and tend to use story-sticks with knife-lines transferred from my stock. You really don't need to measure much at all;
Transferring eliminates many headaches and makes your work much more accurate.
Using complicated fractions and trying to mark off a ruler is just looking for trouble.
If i need to measure anything i will usually check it with a digital caliper.
+ 1 on the light & heavy 1/32. I never use 1/64. In fact I set aside any measuring device (tapes or rulers) that have 1/64 graduations. They are just one big blur to my eyes.
I'm with you on this one. When I need to measure something in the 64th arena, which is usually thickness, I will go to a caliper or a feeder gauge and express it digitally.
Actually, I think one advantage of metric is I can actually see the smaller measurements, e.g. 1mm and 1/2mm - roughly a 25th and a 50th, though I suspect the 1/2 mm will be a blur soon with advancing age.
If I really care to mark something to 1/64th the t-square rulers with the tiny holes get pretty close.
If you have to work wood with precision it pays to work it with precision tools. One very handy item in the machinist's bag of tricks is a digital caliper. They aren't terribly expensive, they're almost immune to dust and the usual shop hazards, and they give you clear numbers you don't have to squint at to read. If you measure a mortise and need to cut a tenon to fit it, the caliper's inside function will give you the dimension. Come time to bump the rip fence over, you can hold the caliper firmly against the table and use the extended depth function to track the fence setting as it changes digit by digit.
Don't get scared of thousandths. It's just a graduation. It makes no difference how you divide an inch - into eighths or thousandths - they are all the same if you can see what you are doing. Don't sneer at thousandths either. A halfass good woodworker fits his glue joints, tongues, tenons, etc to a couple thousandths and doesn't think a thing about it. It aint snobbery or bad taste, it's good workmanship.
You can get a cheap battery eating 6" caliper for $30 and a good quality 12" or 18" for a lot more but the quality version will be the last such tool you buy: they'e an heirloom tool - they last that long in woodworking if undamaged.
Once you get used to a digital caliper you'll toss all that Incra crap out or sell it to people who don't know better. All you really need for precision woodworking is a good combination square set, a set of trammel points, a measuring tape, 8" dividers, a marking knife, a framing square, a pair of stair gage attachments for the framing square, a string, a good level - see the trend? The classic stuff complemented by a digital caliper and - maybe - a digital protractor.
Thousandths of an inch aint nothing, there's 15+ of them in every 1/64". Get a decimal equivalent charts and get used to it and perfectly fitted glue joints. panels, mortises, drawer glides etc no longer pose a serious challenge.
I agree it's frustrating to have 1/64th on my starret showing at inopportune times :-). 1/32 would be okay for me, my eyes are not getting any younger.
Other thing to keep in mind with finer increments on a ruler is paralax error, right? 1/64 is easy to mess up if your perspective is not directly orthogonal to the surface being measured...
I got tired of the finicky and battery gobbling digital calipers (I have two) and bought a Starrett dial caliper. I wish I had bought it in the first place!
Its tempting to think that because digital devices may display a few digits to the right of the decimal place that they are more accurate. Its not the display that provides accuracy, but the mechanical workings inside.
If you want to see how well your measuring device works, take the measurement a few times and see how much it varies.
My plastic digital caliper is repeatable to about 1/32 (0.03125), but not 1/64 (0.015625).
To be sure, the difference is probably not important for most woodworking needs,
....even before they got cheap. Everyone one I know that builds furniture has one for now they are cheap. But they don't substitute for a 12 and a 6" flat rule.
I am lucky to keep dimensions to within a 16th on a wood project. Anything past that is almost unattainable due to my short attention span plus the humidity around here will swell up wood almost as fast as you can work it. Tooling I will check to a 64th. Love the Wixey digital.
I find it readable and consistent. I come by my measuring from old fashioned long ago graphic art design. I use drafting tools a lot. I use proportional scales and dividers. I take most of the smaller items under 2ft with a metal stainless rule. Smaller than 24 inches I use smaller drafting rules and, calipers and various drafting hard point dividers. Often I don't use any marked scale but known quantities like templates, existing parts, keyway spacers, center punches, drill bits and/or one or more pieces cut to some dimension and used as a gauge. If I need to divide something into sections I use metric scales . Rare in MY woodworking that 1/2mm is important. Most lines of mine are marked with an engineers square and Exacto knife. When things get confusing I have a electronic calculator called the "Construction Master" that I find helpful for numerous tasks both large and small -- especially roof valleys and overhangs. Perhaps the one item I use most is the GRAY plastic 6" General brand dial caliper that is good to 1/64" but I care less about what the dial says. I just fit it, tighten it down and use the space inside or outside the legs. When it fits, THEN I mark down the measurement for repeatability. They are inexpensive and I have them in the garage, shop, at my desk, and near the TV for when some idea hits. Truth is my eyes are going with age and whatever gets me there is what I use, My problem is not figuring, tools or scales, but execution. for me a thin glue line gap is usually forgiving enough.
At first I was boggled by the question which has so many obvious answers. I will try to answer globally. I have built enough stuff that I have found what is best for me. I employ a digital caliper, tapes and flat rulers, and measurements directly off the furniture onto the piece to be cut in combination where each works best.
I use a digital caliper when I need a highly accurate measurement. Taking the example of the bench build, I used it to measure the root diameter of the lag screws for drilling the pilot holes with a number drill. I used it to accurately plane a shim to go under the vise. And I used it to measure along the tusk tenons and bridal tenons to see they were uniform in thickness. I use it so much it stays in the front of the bench drawer.
Ruler- The convenience of size. For me it is the most handy way to make remote measurements. Sure I could measure the length of something with a stick and then go to the lumber rack to find something appropriate but a tape is more handy.
On the furniture it is usually a matter of size of measuring device. A flat ruler fits places a stick doesn't. But were I can, for example I mark a tenon width from the mortise at hand, I will mark a piece to be cut from the place it goes. The distance between dovetail and M&T shoulders was scribed from the leg assembly. Etc.
I never use a story stick. I don' t build something twice so there is no need to record the "story" in a stick. I do use a stick for turned spindles. I could use a measure less but don't find it handy to do so.
I guess that I have worked for so long without using a ruler that I struggle to find what I would use one for.
As you do I would use a tape measure for rough cutting lumber to length.
A digital caliper for checking stock size.
A story stick is not primarily for keeping a record for future projects but for the one that you are working on at the time.
A story stick contains all of the pertinent information of your construction; the overall dimensions, lengths, widths, stock size, spacings, joint size and placement.
They are the master template for your construction from which everything is transferred onto the individual pieces that you are working on.
This is a simple foolproof way of maintaining accuracy and consistency of all of the components.
To mark a stock size on your story stick, you hold a square on the stick, strike a knife line, place a piece of stock against the square and strike a knife line against the edge of that.
That is a precise, indexable and transferable reference for your stock size. How can things be more simple?
I use two story sticks most of the time; One the master one, with the individual stock sizes, spaces and joints marked, then I use that second one which I make the multiply layouts transferred from the individuals on the master.
This guarantees that all of my stock sizes, spaces, joints etc are transferred from one original.
You can divide lineal spaces into any number of equal parts with two sticks, with greater accuracy and probably faster than you could measure it. You can check diagonals for square, the are a lot of uses for sticks.
Over the years I have worked on many very complex jobs, the biggest concern was always avoiding error and maintaining precision.
This method of working was designed to make life easy, to avoid making and accumulating error, ensuring precision, guaranteeing results.
I see very little need for a ruler.
Story sticks have been around a long time, and have been used for building everything from houses to the great Cathedrals and even the pyramids.
I think that every woodworker should start using them.
