I have a new shop vac that will be dedicated to my RO sander. I would like to have a rolling unit with both on board. I was considering a switch that would turn the vac on when the sander is turned on. But I am not sure what they are called?
Can't remember what they are called either, but I think Sears has/had them. A cord you plug in with two receptacles on it. You plug both the sand and vac into them and then plug in the cord. When you fire off the sander, it fires the vac. Auto Switch maybe? Hope Sears does fail me again.
I have a similar switch on my table mounted router. I wired a light switch (toggle) to a duplex receptacle and plugged both the router and shop vac into that. When I flip the light switch both have power. You could do the same thing and if you wanted to turn off the ROS the vac would still be on or you could turn both off with the light switch.
And you will have saved some money over the other choices that have been mentioned.
I'm putting together a sanding unit as well. I was lucky to get a display unit for a Mirka Ceros. It included the Mirka on demand shop vac in the bottom of the rolling display, but I am adding a 5 gallon bucket and an Oneida Dust Deputy on the shelf. I see you can even buy them at Ace Hardware now. From what I read, it will really extend the filter cleaning time. I've had the parts for some time, just haven't put it together yet.
Tom As Barry said Sears has them for $20, I have 6 or 7, bought over them years. I have been using them for 30 years or more. They are the best and the cheapest I have found, and so far only had one ever go bad. I`m not sure what they are called, maybe Auto-switch. Good luck Larry
