table saw sawdust
Jack Putnam
I am working on a project where I need to cut a 45 degree angle on a piece of wood on my table saw. now the wheel that you turn to do this is on the side of the table saw the make of the table saw is a RIDGID. The problem I am having is that the wheel that you turn to get the different degrees will only go to 35 degrees. It seems that the sawdust has collected on the shaft that is where the gears mesh. (I guess you call them gears) in order to make the saw blade turn to a 45 degrees some how the sawdust hast to be cleaned out.
There are no panels to take out and the only way I can see is to use an air hose to blow the sawdust away and by looking through the slots in the front metal panel even then you can't see very well what's going on. Does anybody know of an easy way to clean the sawdust out I don't even think you could grease that area on the gears it would make it worse. Thanks for any help you can give me.
