Re: how to best make mortises
TomD
You already got a lot of answers to this in the other thread. Except the question of accuracy. Decent quality machines will do accurate mortices with any of the hollow machines. You have to set them up properly, but they cut clean squares. If you want accuracy, you do the usual things to get it. Buy solid over features, buy quality over price, age over beauty. I really don't know who would actually be able to tell you which knock off machine was going to be delivered and be better than the next. Even a side by side review will not tell you which machines, if they are not consistent, is the best. You may just get the same random distribution in the cross brand sample as you would get in the same number of machines from one of the manufacturers.
I do think routers and oscillators are going to be fractionally more accurate, and in super duper versions much faster. The hollow chisel was still the backbone of a lot of shops in the golden age. It is one of the great tools out there because it combines a lot of efficiency with the quiet and air advantages we associate with hand tools (and a lot better than the noise of hand mortising). I hate mortising with routers.
Chisels are another issue. I bought taiwanese, when they were the center of cheapness, and they have been fine. Set up on the chisels is easy. You simply make sure the junk ejects into the mortise hole, that they are square, and that your drill is set so that it clears the chisel as far as possible without nipping the side of the mortise hole.
