Question ???
Question ???
Question ???
roger lance
I want to put a wood trim band around the top of my reloading bench and want to use a 1 1/8 " thick board and a 3/4" thick board to make this banding. Can't just miter both at 45°......so what is the angle of cut to be to form a 90° corner with these two different thick boards ?? Thanks in advance.
The trim will cover the plywood edge and 2x4.
Re: Question ???
Leave it at 45
Dustmaker Mike
I would still cut them at 45* bring them together mark a line in the thicker board and shave it down to the line. That should give you a nice tight fit and is pretty easy to do.
Re: Question ???
Re: Question ???
Basil
When the hypotenuse of the two triangles are equal....but you already knew that.
I really miss my little "CRC TABLES" book sometimes but not the blankty-blank that relieved me of it.
GOTCHA! Draw 2 parallel lines 1 1/8 inches apart....now perpendicular(90 degrees) to that draw 2 lines 3/4 inch apart. Draw diagonal line from one corner of the box formed by that intersection and measure that angle or set blade at that angle and adjust until perfect.
Re: Question ???
"Old School" answer says......
roger lance
that 53°/37° should about work.....
now, I'm old and old school.....just thought that with all this computer aided design.....
Re: Question ???
Re: Question ???
Ralph Lipeles
Make a sketch with a 3/4" board and a 1 1/8" board. Pencil in the intersection line and measure the angle.
Re: Question ???
Re: Question ???
William Duffield
You're not allowed to do that. The front face of your bench top would then no longer be flush with the front faces of the legs. :D
Re: Question ???
Quicky math...
Tony - Memphis
So, you have a triangle with one side at 1.125 and the other at .75, that makes a tan of the angle at 1.125/.75 which if you do the inverse tan on that, you get 56.30993°.
Tony
Re: Question ???
Correction......my mistake.....
roger lance
I've had that plastic protractor since the 7th grade and I miss read it !!.....it does read a little over 56° (and therefore under 34°)......my knuckles would have been wacked and maybe one upside my head.....ooops.
Re: Question ???
Re: Question ???
roger lance
Glad its not a Roubo reloading bench !!!
Re: Question ???
Re: Quicky math...
roger lance
You are correct......my mistake.....see above.
Re: Question ???
How U Do That?
robbcarr
I'm math illiterate... can you post exactly what you push on a calculator to get the answer? I have a TI-83+ calculator, if that makes any difference - it has [TAN] and [TAN-1] keys, but I don't have a clue how to use them!
Re: Question ???
Jason Roehl in Lafayette, IN
Not simple, but...
...I'll give it a quick-and-dirty rundown.
A right triangle is made up of 3 "legs": the hypotenuse (the slanted leg), and the "opposite" and "adjacent" legs, which are perpendicular to each other. For the miter example above, the angle being sought is between the hypotenuse and the adjacent legs (typically referred to as Θ--"theta"). The tangent of this (unknown) angle is equal to the opposite leg divided by the adjacent leg, 1.125" divided by 0.75" in this case. It would be written as such: tan Θ = 1.125/0.75 You can do the math on the right side of the equation, but then to find Θ (the angle we're looking for) you have to apply the inverse tangent function (that's the tan[-1] button, also known as "arctan"). So, Θ = tan[-1] (1.125/0.75), or Θ = arctan(1.5).
Jason
Re: Question ???
Beyond me....
robbcarr
Thanks for the explanation! I entered:
[Tan] [1] [.] [1] [2] [5] [/] [.] [7] [5] [=]
and get an answer of 14.10141995 if I then press [Tan-1] it says error. If I do [Tan-1] 14.10141995 I get 1.5 as an answer.
I then tried it a different way:
[Tan-1] [1] [.] [1] [2] [5] [/] [.] [7] [5] [=]
and get an answer of .9827937232
It may just be beyond my mental capability to figure this out. :)
Re: Question ???
Try this...
I'm not familiar your particular calculator, but do the arithmetic first.
That is, 1.125/0.75 = 1.5
So, let's skip a step, and just type in the 1.5, THEN hit the [TAN-1] button (you shouldn't have to hit [=]. That should give you the 56-and-change angle.
Jason
Re: Question ???
Where is my old trigonometry book??....
roger lance
that I had a high school course in about 50 years ago??? Looking up trig tables on the net gave me:
the tangent for 56° is 1.483
the tangent for 57° is 1.540
to extrapolate from this table for a tangent value of 1.500:
divide 17/57 which is 0.298....so....
56° + 0.298° = 56.298° which can be rounded to 56.3°
Now where is that book now that I actually need it ??
Re: Question ???
There are trig tables on the net?
John in NM
That's a bit surprising :D Kinda like a slide rule app for a phone! :D
The tangent of an angle is just the ratio of the opposite and adjacent sides of it's right triangle. So the 1 1/8" side divided by the 0.75" side gives you 1.5, and the inverse or arc tangent function tells you what angle has 1.5 as it's tangent.
I couldn't figure out what you were up to in the original post - why the differing thicknesses?
Re: Question ???
There are trig tables.....and some of us....
roger lance
still have slide rules.....plastic protractors.....and land lines (but I'm not saying who).....
The purpose of the original question was that I'm using a thicker trim piece on the front of the top to properly position the lag screws that will secure the reloading press to the bench. I want those screws to go into the center of that 2x4.....and since the trim on the sides could be thinner (and less costly), I went with the 3/4" there.....
Hopefully, you can see the layout lines.....I'm temporarily using a piece of scrap clamped to the bench to position the press.
Next week, I hope to glue on a laminate to the top.....and I'll try to document that process for anyone interested in learning how to apply laminate.
Re: Question ???
Avoid the Math
Edgeband your bench in 3/4" stock then use a piece of 1/2" stock to "pack out" your press for its contact width with the edge of the bench. That positions your mounting points and relieves you of trying to figure out how you will accurately cut those nifty 56+ and 33+angles that all these engineers have so nicely calculated for you.
Of course, if you enjoy making life difficult for yourself . . . .
Re: Question ???
PS
SLIP STICKS RULE!!!!!!!!! :D :D
Re: Question ???
Never avoid a challenge.....
roger lance
especially if you can be successful in meeting it......a feature of laminating the top will be a small chamfer on the sides and front edges of the top and this will look better in the way I'm proposing. As for cutting these miters, that's what God allowed a table saw to be invented to do.....easy peasy.
Re: Question ???
Ah-ha!
John in NM
Now it makes sense... I had the oddest image in my head, couldn't shake it until I saw that pic! :D
I actually use protractors all the time, still draft by hand, have a land line and no cell phone, and even have my dad's slide rule around somewhere. The idea of trig tables on the net just strikes me as amazingly droll - when the machine you're using to access those tables can do the trig and vastly more complicated math is milliseconds :D
Re: Question ???
You Sure About That Invention?
[John Deering Strange Brew, 2004 (c)]
Re: Question ???
I know this computer can do great things.....
roger lance
but I've no clue how to operate it.... :(
Re: Question ???
Is that Norm ????......
roger lance
always knew he'd make it up there !!!
Re: Question ???
Success!  Had to Change Calc Mode
robbcarr
After many attempts, I remembered that the calculator can be in Radian or Degree mode, so I changed it to Degrees and did
and got an answer of 56.30993247!
How an why you would want to be in Radian or Degree mode I don't know and why I had it in one vs. the other is probably by accident.
This calculator is way beyond my needs, and I certainly don't understand what all the buttons do, but it's nice to know that those other buttons actually do serve a useful purpose.
Now, if I even encounter this situation of joining two different width boards on a miter I will surly forget how to do this and resort to drawing two lines and and a diagonal between them methods, but at least one time I was able to do it with math! :)
