I'm not talking about leaving bark in a natural edge bowl, that everybody has done.
Have you ever used it like you would a veneer, or stripped it off a tree, using the full round cylinder, or band-sawn the wood, making a cylinder of wood, but with the bark left on? What did you learn, and were there any surprises?
You know, some trees have such wonderful bark , it seems like there should be more of it being used.
Re: Do any of you have experience using tree bark?
If you search Google images for "Adirondack Rustic Furniture," you will be treated to a world of decorative bark art, white and yellow birch bark being the main ingredients. Natural, unprocessed materials like bark invite creative use. Maybe we need to have another contest, to see what people can come up with.
I guess everybody knows the generally accepted rule that a plain sawn lumber will cup away from the pith as the wood dries. However, the bark seems to want to do the opposite. A few months ago, while the bark was still tight, I thought I would experiment / make a waste-basket for my office, using the bandsawn box technique of standing a limb section about 11" diameter, x 13" tall on the bandsaw, entering the side at about 45*, then cutting out the middle, leaving about 1/2" of wood inside the bark.
I had set it aside to dry, but pulled it out, to find that the wood had contracted, eventually splitting down its length on opposite sides, then the two halves have curled in a lot more. While this may seem to indicate that the compression strength perpendicular to the grain of the bark was greater than the tension of the wood, it might be more likely that the bark prevented the wood from drying on the outside, causing the wood to do that within itself.
I guess I could test that, by stripping the bark, then doing basically the same thing, but sealing the outside, but without the bark.
however, back to the bark, the outer dead cells of the bark do seem to have taken a set, while the sapwood and inner bark contracts. There is probably a lot of variation between species, and due to thickness and season that determines how it will act as it drys.
I was just looking at some cherry slabs that I sawed a couple of weeks ago. I removed the bark on the best of them, but left it on some. I just inspected it, and the sapwood is already down about 1/10" on some.
That cherry is on top of some big walnut slabs, and the mixed aroma of the combination flung a craving for some ribs on me. Ha
It is common on spring logs to have the bark peel off on the log yard as logs are handled. When it dries it invariably curls tightly, that is to say the cylinder defined by the bark gets a smaller diameter. This observation makes sense. The outside of the bark is already dry and the inside is soggy when the bark is separated. Hence, the inside shrinks and the outside doesn't.
I cut some white birch logs to decorate the fireplace in the summer. They look kind of ratty after a few years. What ever the application the surface of bark is not durable, resistant to scuffs, etc. and the many kinds of bark will shed bits and pieces.
Surel you're not barking up the wrong tree, there?
When my son was in Indian guides, we used bark from the new growth on what we were told was a Siberian elm* to weave baskets. interesting stuff: easy to weave when first stripped off, leathery-hard when it dried.
*Perhaps brought here by the Russians at Fort Ross - nah, more probably purchased from some nursery. Very different from the elm I hear about from y'all back East: straight grain, split easily.
I don't suppose you know how they process it? It looks nice and flat in the stacks. I'm betting that they mill it to a standard dimension , then stack & sticker it with binding straps, before sending it through the kiln.
As it turns out, my sister has a yellow poplar tree down in the creek behind her house that needs to come down before it falls on her bedroom. It is too steep to get the wood, but I might haul some bark up and out by hand. The old limb scars look like giant eyes on that species.
I have some pieces of cork oak that a friend prepared and gave me. The tree was freshly cut and he stripped the bark as soon as he got it. He then used gorilla glue to glue it to same scraps of marine ply he had on hand. not sure how he clamped it. Ive cut part of the ply off of one and the bark seemed to be fairly stable.
Ive used it in a couple of wall sculptures and people seem to really like them as they sell fairly well.
Robin
Hank Knight
I built my wife a bird house that resembles our home, which has a large stone chimney. I used hickory bark to simulate the chimney. I started by visiting our wood pile and collecting pieces of bark that had separated from the log. All of it was dry and curled. I cut it into strips and sanded the inside on a flat surface covered with coarse sandpaper until I got a reasonably flat gluing surface. Then I glued the bark to the "chimney" (a piece of hardwood) with West's epoxy. I actually coated the whole chimney piece with epoxy. Then I attached it to the birdhouse with screws and epoxy. The bark veneered "chimney" is admittedly small, about 2 1/2" X 3/4" X 10", but it has been outside in the weather for several years and it is holding up just fine. It is under a tree, in the shade and out of the direct sunlight. I'd post a photo, but I'm away at the moment.
