Samantha's Dresser 11-veneering the drawers
Samantha’s Dresser -11 Veneering the drawers
In the last installment the veneer was sawed with a target thickness of 3/32”.
PIC 1
Next was selecting the veneer to use and where to cut it for the area to be covered. The lumber for this veneer was cut for me some time in the early 1970’s. It has been a long time to come up with a good use for it. I found that I could saw and joint this thickness just like a normal thickness board. A hand plane and shooting board was handy for adjustments of the butt joint.
PIC 2
These tools were considered for glue spreading. The Headley shop uses the paint brush and white glue. David Finck uses a credit card with notches filed in the edge. Others suggested a foam paint roller. The paint roller is a clear winner. BTW, it can be stored for days wrapped in plastic wrap and readily washed out in hot water. I used white glue for no better reason that it works for the Headley shop.
PIC3
Who ever invented vacuum bags deserves much praise from amateur veneer appliers. The price of these bags has come down a lot. I have used vinyl and urethane bags. The urethane are much easier to manipulate and seal (they are more limp).
After the glue is applied wrap the assembly with blue tape to keep the veneer from skidding. The blue tape is easily removed with little risk of grain lifting.
PIC 4
The result. Each drawer is veneered with two butt jointed pieces of veneer book matched from consecutive sawed pieces.
The next installment will describe fitting the drawer fronts and dovetailing the drawers.
Re: Samantha's Dresser 11-veneering the drawers
Hank Knight
Bill, that looks great! Nice job.
roger lance
Sunlight-In-Her-Hair will keep this with her and remember you always. Another beautiful piece.....love the veneer work.
Joanne in Point Pleasant, PA
Stunning! Nicely done.
PS.... butting the joints
The butt joints were jointed with a low angle plane and a shooting board. As seen in the picture the joint is taped, but in a special way best done with a helper. The joint is held together while stretched lengths of tape are applied across the joint. The spring of the tape applies "clamp pressure" on the joint.
As glue is applied to the veneer the joint is opened a small amount using the tape as a hinge and glue forced into the butt joint. The joint is closed back up and glue applied to the remainder of the surface. Presumably this glue provides some bonding of the butt joint.
Joe in a Cleveland suburb
Awesome work. Those drawer fronts are really nice looking.
Very nice.
Joe
Nice job, Bill
You're convincing me that I should proceed with my plan to resaw an outrageous piece of sapele that I've been hoarding. Talk about multiplying the effect...
Thanks for the write-up and pix.
Beautiful work Bill! I'm sure that piece will remain in your family for many generations. I hope you "Sign & Date" the piece in an area that can be seen by future generations - like a drawer bottom or inside a drawer....
The provenance
Usually I am building from wood where I know its history and my children knew something about where it came from or who sawed it. I like to put this information in the case using permanent fine tipped marker and then overcoat with shellac.
