Re: That's a no brainer.. perhaps in one sense
Tom
Not true as far as I know. The energy of say an elephant gun bullet at the muzzle if you are hit by the bullet, and it expended all of it's energy in you (unlikely if you are not an elephant, is 4000 footpounds and up. The recoil is in the 100 and up foot pounds range. This is because the bullet weighs, say 500/7000 pounds and is moving at 2600 fps, while the rifle weighs, say 11 pounds and is moving at whatever the math says that works out to, but a low number of fps. Since velocity is a second order effect, and mass a first order, only, the effect on energy of 2600 fps second is significant.
As far as the effect on a body at the terminus is concerned, bullets are designed to destroy the target, not move it. So on big game there is a trade off between penetration and the destructiveness of the wound channel. To have assurance the bullet will be effective, it has to be designed to survive for the maximum penetration required from the worst angle, and the worst impact against target elements. But at the same time, ideally, it will be as destructive as possible along the way, and waste no energy outside the target. On average you are looking at dumping energy from a light object into an object that may well weigh thousands of times more than the bullet, while the ballet decelerates over a distance as long as ten feet..
