Does a Unisaw really need matched belts?
Henry Higginbotham
I've always thought I understood that Unisaws needed a matched set of three drive belts, presumably because two belts that are nominally the same length might in fact be different.
A friend recently bought an old Unisaw (all cast iron, from the mid-16th century, I think) that someone had started restoring and then abandoned. He found a (probably Chinese) Unisaw belt set on eBay and inquired of the seller whether they were matched. The seller replied that, advertising copy be damned, matched belts were a myth and that he had visited both the Delta and Powermatic factories, and that both just used the first three belts they could grab, and laughed at the idea of matched belts.
I plead cluelessness. Anybody know anything more that what you've "always heard"?
Re: Does a Unisaw really need matched belts?
My understanding
Lee Schierer in McKean, PA
Back in the good old days, belts were close to the length specified. The method of manufacture was such that unless you got belts off the same mandrel that they could be slightly different in length which would result in uneven wear.
Modern belt manufacturing is such that most belts no longer need to be matched as the manufacturing process is improved so the difference between belts isn't significant. I can't speak for Chinese belts, but Gates belts no longer need to be matched sets. Personally I would buy a quality set of belts from a local distributor
before I would buy a generic brand from ebay.
Lee
BrianMonumentCO
If you Unisaw is like mine it has 3 belts that run together.
If you replace 1 belt do ALL 3 at the same time.
Is the Pope....Catholic ????
roger lance
Rumor has it he is.....all three belts are running the same distance and I would recommend, at least, making the effort to have them match.....who is setting the standards for quality here ??.... China or what use to be the USA ??
Dick Coers
Depends on how much he loads the saw. If one belt is tight, and the other two are not, one takes the load and wears out sooner. One belt will certainly transfer enough power to cut plywood. Ripping 2" hard maple is something else. If cheap is the shopping requirement used, don't expect belts of equal length.
Steve Schoene
course the Unisaw needs matched belts. BUT, within a manufactures lot the belts made today by quality makers, such as Gates will be sufficiently matched without the separate matching process that once was needed to get belts sufficiently alike.
So buy three at once, from the supply house not from a big box and you will be 100% happy.
exactly....
what my engineer friend that restores machines told me.
Larry in NW Ohio
Henry It`s been a few years ago that I needed 3 belts and could not find them, must have been about the time they stopped making them in 3`s. So I went to the belt size I needed and just took them one by one and tried to match them myself, some were around 1/4" long or short. but after the stack I did find 3 that I thought I could use. Good luck with the search Larry
Depends.....
John in NM
As Lee and Bill pointed out, if you are buying premium machine laid belts, any three the same size will be fine. The matched set business is old school from when manufacturing tolerances were not as good.
But would I believe an ebay seller who has "toured factories" -- not even if he was selling bridges! :D
Belts and blades it doesn't pay to go cheap. Buy good ones and you will have fewer problems and longer tool life. It takes years for a Gates belt to wear out, in some cases decades. What's saving $15 on a questionable belt in that kind of time frame?
Amen to that
Every place in the US will have some industrial supply place that caters to local shops and industry. They will either have belts in stock or can order them in a day.
Thanks
Henry Higginbotham
Good info. I'll pass it along.
Tom
These days, all I run are the link (serpentine) belts. I don't know if that is a good thing or not, but it does simplify matters, particularly with belt intertwined machines, and the standards of construction are seemingly high. I guess I should say that by "all" I mean that I only replace with these belts, and at times fit them to my most prized machines.
https://www.woodcraft.com/Articles/Articles.aspx?articleid=381
A Small Footnote
I run all my machines on Fenner drivers ("link" belts) including my Jet Exacta which is a 3-belt drive. They run extremely smooth. There are, of course, cheaper (H-F) version link belts, but I only use original Fenners. The set on the table saw are 10 years old and show no appreciable wear.
