Music Stand
Music Stand
Music Stand
Roger Myers
As I frequent the hand tool side the most, and the work was primarily with hand tools, I had posted several pictures of this on the hand tool board. Here is a full view picture and if interested you can see some more detailed info on the hand tool board.
Thanks,
Roger
Re: Music Stand
Re: Absolutley beautiful NM
Re: Music Stand
questions
First, let me join with the others that found the piece lovely to admire. It just seems perfect in every way. Thank you for sharing it with us.
1. Will you provide details on how the inlay was done on the leg?
2. How was the hexagonal column brought to shape? I can imagine the possibility of spoke shaving it but I can not imagine myself being able to reproduce the graceful curve while keeping the flats at the proper angle and uniform in size. Are there "tricks" or aids involved or "just" exceptional free-hand technique? And then, how does one excavate for the inlay on a sculptured surface like the column?
Re: Music Stand
Answers
Roger Myers
For the legs, I made a pattern for the inlay that is the correct offset in from the outside profile. Clamp this to the face of the leg and scratch around the pattern as if you were just doing a line inlay. Remove the pattern and excavate to the line using a hand router plane, set to a depth just shy of the thickness of your inlay.
Use the pattern to mark the inlay material and cut and trim the inlay to fit the recess as tightly as you can. Glue the inlay in place. Then fasten the pattern back to the leg, this time with double stick tape, and rescratch around the perimeter of the pattern. You should be removing some of the glued in inlay and recutting the original line. This is done with a 1/32" cut width, what I normally use for stringing. Then fit stringing as you normally would, and scrape all surfaces flush.
For the column...the basic profile is turned on the leg. Then using a pencil post gauge on the lathe, index the piece and mark the hex outlines along the axis. Then you spokeshave the flats, using the lines as guides, but your final shaping is by eye.
The cavity for the inlay on the column is then created. Using a scratch stock with the base 60* to account for the angle as a result,of the hex shape, and a cutter that is also offset to the 60*, create the outline. The cutter must be at an angle and not enter the wood at 90* or else the groove will get wider as you go deeper. Then excavate with a hand router plane. Fit and glue the inlay. Rescratch for the stringing, fit and glue the stringing, and flush.
All of the inlay and stringing work was 100% hand tools, and I can't imagine getting good results any other way. Takes a fair amount of time, but I think it was worth it.
Roger
Re: Music Stand
follow up
Thank you for providing the detailed explanations. I am unfamiliar with the pencil post gauge but it is now clear how one could shave to the pair of lines establishing the flat on the post. I had not thought of using a pair of lines to guide the shaving.
"Then fasten the pattern back to the leg, this time with double stick tape, and rescratch around the perimeter of the pattern." Will you provide details of the "scratcher" used to scratch around the pattern for the stringing. This part has me flummoxed but I expect the details of the tool make it straightforward. Is the scratching indexed off the pattern (I think yes which leads to the question of the scratcher details?) or off the edge of the leg (that would employ a standard scratcher with a fence).
Re: Music Stand
Re: follow up
Roger Myers
Bill, the gauge runs on the lathe bed and holds a pencil parallel to the bed.....simply an easy way to run indexed parallel lines.
For the scratch tool...it does reference off of the pattern. You can't really reference off the outside of the leg as it has round over on the edge that varies. The scratch tool can be the hand held one that Lee Valley sells or one that you make yourself.. I,m not crazy about the hook pattern cutter that they use, as I prefer more like the Lie Nielsen/Latta cutter design, but they do not make a free hand cutting one. But they are also easy to make yourself.
It is patient work, but I know you like that kind of work.
Roger
Re: Music Stand
Re: Music Stand
Joe in a Cleveland suburb
Absolutely beautiful.
Awesome work.
