Stumped
Stumped
Stumped
Gary Smyth
I ran across and purchased two items at the same table at the local flea market. Both are made well with the name DRYAD, Leicester. Checking the net, Dryad (aside from being the Greek nymph of trees (oak trees)), is an arts and crafts house in England. They make furniture and specialize in Mission style. Also textile, hammered metal, pottery etc. But searching around that site I did not find anything that looked like either item. The items are new and well made as many wood British and European tools are. The wood is hard, maple or perhaps a fruit wood. Forty five degree and other cuts are even and clean and the clearances tight. Where metal meets metal there are bronze/brass bushings. These do not appear to be inexpensive items. On the larger item “vise” the wooden screws are 40mm or over 1 1/2" in diameter. The hub is 60mm (2 3/8”). There is one turned handle to turn the screw. The jaws are 75mm (3”) square. There is no hole or other apparent clue for attachment to a bench. However, one of the “jaws” has a rabbet its length. I have no idea of its purpose.
The smaller item is also a mystery. Same company. It has a variable height 10mm wide very sharp knife. The single wooden screw is 30mm (approx 1 1/8”) diameter with two 10mm round steel bars the hold the “jaws” in relative alignment. The jaws are 35mm x 70mm x 180mm (approx 1 3/8" x 3" x 7") the screw pin is 14".
I don’t know what these are called to check further -- or even what industry used. Sizes are shown using rule on pictures. Email to Dryad no response this day.
I would like to know what these are and for what they are used?
Also, how are wooden screws cared for? Oil? Wax? Silicone?
Re: Stumped
A guess.....Moxon vise (large one)....
Re: Stumped
Perhaps, but I was under the impression
Gary Smyth
that a Moxon had jaws of unequal length (or holes) in order to permit clamps or dogs. Still, you may be right. Awaiting other thoughts.
Re: Stumped
Re: Stumped
Dick Coers
First item looks like a miter shooting board or maybe a miter paring guide. Second, looks like something that went into a small miter gage slot. Just guessing.
Re: Stumped
they are book binding tools
Robin Corell in Atascadero CA
I don't know how they are used but I recognize them the printmaking room at school.
As for the type of wood my best guess is beech.
Robin
Re: Stumped
Re: Stumped
Janice Manuel
I make bookbinding tools...not familiar with that one though.
And the link given...is to a page of my customers web site..and is of an item I make for him....I don't know much about how they are used, but I've made lots of them over the last 20 years....
http://apps.webcreate.com/ecom/catalog/product_specific.cfm?ClientID=15&ProductID=21085
Re: Stumped
As identified - bookbinding
Gary Smyth
As has been identifiied it is a bookbinding tool. Both tools work together. The larger piece called the press is typically placed in a open frame of some sort and the ends of the press are trapped to hold it fast. For cutting the rabbet is facing upward. Book signatures (small sections of collated folded pages are collated and passed into the press with what will be the open pages up. The smaller tool is called a plough and it rides in the rabbet with the cutter facing the press bound signatures. The plough moves through the rabbet with the one sided blade cutting the signatures perfectly even. the screws move inward a bit at a time to reduce the effort it takes to cut the signature pages. When it completes the ploughing. the book pages are traditionally flat and even. If the press is turned over with the book's spine end up the signatures can be glued, taped, or sewed, and with on covers on, engraved/tooled lettering can be applied. In most inexpensive machine made books when a book bound with a flat spine is opened the signatures flex and form a concave curve within the covers. Custom/better bound books place a convex curve on the signatures before binding so the the spine is rounded before the covers are added. When this type of book is opened, the signatures move to lay flat within the binding.
Thanks to all who guided me. By the way, Beech is the wood, as stated. Oil and bees wax are the traditional lubricant to protect the wooden screws. Over time bees wax fills gaps and make the work a bit more efficient. For my new device I'll have to turn a new pin or two and I'll look for a broken wood baseball bat and make them of straight grained ash.
Re: Stumped
Re: As identified - bookbinding
Lars Parrington
so do you expect to use it as a bookbinding tool, or repurpose it for woodworking?
