I have never had a good way to cut reliable miters on the table saw. I get by with trial and error setting of miter gauge and dealing with the piece creeping along the miter gauge as it is being cut. There must be a better way.
Does someone have some sort of jig devise for cutting miters, say for making picture frames, molding and the like. Specifically I am framing a veneered table top.
Make up a sled that runs in both miter gauge slots. Be very careful to get the two fences at 90 degrees. I like cutting on the table saw better than all other methods.
of these can serve. Solid stock. The Dubby single and double sleds I've seen at the woodworking shows since the 1980's. At the shows they work but you know that those have been tuned to perfection. A lifetime purchase. I believe that you use a smaller diameter saw blade. In that instance the adjustable drafting triangle in the 4" to 12" size may also work for you. Because they are used for drafting the angle markings are dead on and can be used to set the miter fence. The triangle is a lot less risky purchase. The Dubby will have to be set up and the tolerances when doing so have to be tight. The drafting triangle can be used right out of the package. The prices on the Dubby are in the attachment and there are several versions- but over $170 to start. The drafting triangle in a large 12" size can be had for under $40 on ebay. To get you on the way ---
Attaching an extended wood fence to a standard miter gauge and facing it with adhesive-backed sandpaper can be useful in preventing creep. Of course it is mandatory that the miter gauge ride in the slot with essentially zero play and this is sometimes difficult-to-impossible with inexpensive O.E.M. equipment, thus the number of aftermarket miter gauge rigs on sale. As others have said, a sled arrangement is great although you need to be prepared to spend a lot of time setting it up. For work which allows it I've given up on TS miter cuts despite my saw's sliding table and long miter bar -- the old Dewalt compound miter saw is ever so much easier to use even though I still have to be prepared to fine-tune most miters with plane and chisel for invisible joinery.
I'm leery of relying on the tablesaw for 100% accuracy in anything. I used to tune up miters on the disc sander, using a 90º block attached to a miter gauge bar to assure that complimentary angles added up to 90º.
I can tolerate routers and other noisy sawdust flinging machines, but a "chop saw" exceeds my tolerance. I have one (DeWalt) but only use it for house trimming tasks. But, I must agree that for the task at hand it would be ideal.....after affixing double ear plugs and readying the clean-up gear.
I find routers vastly worse than a chop saw. Like the table saw, I don't always wear earplugs while using the chop saw. I still use routers of course, especially in a table, but they are probably my least favorite tool.
I still have my old Hitachi 8.5" slider. The only time it's not cut nice miters is when I let the blade get way too dull doing rough work and then tried to do some precise cuts. Carbide tooth blades can fool us easily because they cut so well. A dull one will still cut nicely, but the blade plate will deflect and give you a less than flat cut.
Bill....here is a simple table saw jig that makes perfect miters.....the board against which stock is held is at a perfect 90°......it does not need to be attached to the base at a perfect 45° to the saw blade.....so if one side is cutting 45.1°, then the corresponding side would be cutting 44.9°.....you get a 90° corner....
now a couple of things: 1) as you can see where I've got some screws stored I was using a couple of de-sta-co clamps to hold the stock steady (the clamps are currently in use elsewhere)....I'd simply put down a strip of PSA sandpaper on both sides and you should eliminate any stock creep
2) to get stock at the same length, you can add some wood strips with an adjustable stop block....one on each side
I used to use a sled like this and found it to be the easiest way for making picture frames other than a miter trimmer. This is basically the same jig Ellis Described that he uses on a disc sander.
I do all critical angles freehand on my disc sander by scribbing a knife line and sanding to it, this includes most 90 degree angles. But that's just the patternmaker in me.
I think Roger, miter jig is better and easier to build. I'm sure you will clean up the miters with a hand plane. Good hand plane surface is the best surface for gluing anyway.
Similar to building a shooting board. 2' square piece of plywood with a hardwood runner screwed underneath that rides in the miter slot.Put a stop on the front edge square with the blade then to cut miters you screw down a wedged piece of wood to the plywood,set at your angle. To fine tune it use shims.---Jack
The ones shown that appear to be a isosceles triangle with the apex pointed at the blade offer the advantage of the blade disappearing under the jig, safely. This is a very important feature. The alternate version has the blade "appear" out of the back of the sled and it is very easy to push your hand into it. Either way, put a "tail" box on the sled to cloak the blade and keep your hands out of it. Its easy when making repetitious cuts to get bored and let a hand drift into the way.
If you don't, you should start by making one, which will handle cross cutting something about 32" wide, and extends to each side of the blade a bout that far.
Once you learn the joys of using that, it is easy to just add sub-fences onto it. My favorite gauge, is simply a 1x2x ~ 16" long, with a pin about 1/2" from one end. The other end has a sharpened screw tip sticking out of the bottom about 1/8", to hold it wherever I push it down.
Start with a framing square, to mark the 90º index line on the front side of the arm. Then with a drafting square, or speed square, mark the 45º. I'm sure you already know the way to divide angle by striking arcs from point along an arc, which can give you 60º and 30º etc.
However, if you then mark an arc at 14 5/16", from the center of your pin, then each 1/4" along that arc is = to 1º. Or you can double that out to 28 5/8", and each degree is 1/2" along the arc, so making very fine adjustments is very easy.
There is no need for holding knobs, since all the parts are on top of the sled. I just lift the swing end of the arm, then press the needle sharp pin d own into the plywood sled. Of course, the pivot end of the arm, is near the cut, and should be sturdy enough to resist the force of the blade passing through the wood.
Going back to change an angle by .25º is easy with this method, for that perfect fit on the final cut if a corner cones out off just a tiny bit.
I haven't read all the responses, and someone may have said the same, but I have an Incra1000SE. I mounted a sacrificial fence which I faced with self-stick sandpaper. That solves the creeping problem, and the Incra accuracy is right on. I also have a jig I made a thousand years ago which gives dead-on miters. It's essentially a sliding miter jig - the primary purpose was to provide a means to get opposing sides of a picture frame exactly the same. Hal
