Bench features can be highly personal
Bill Tindall, E.TN.
The details of the "ideal" bench depend on the details of how one works wood.
Those enamored with building shop furniture may build a complicated bench styled from some past time period for the challenge of it with less thought as to how they will actually use its features. I have a theory that benches from times past had all sorts of complexity to enable fastening stuff to the bench because they lacked thickness planers, routers(shapers) and inexpensive fast acting clamps. If you have these aids available a bench with a vise (or better yet a vise on each end) may be sufficient.
My bench has a substantial top overhang. This overhand plus a diverse assortment of "F" style clamps is sufficient to readily fasten down anything I need to for the style of woodworking I do (mixed hand and power tools).
That said, a few years ago I drilled a line of holes behind one vise and turned some round dogs of various heights on the lathe. I wish that I had drilled one hole and then drilled additional holes as the need arouse. then the holes would have been more optimally located. In fact a hole to the side of the vise has been more useful (to me but maybe not to anyone else). I do use dogs occasionally and never encountered any limitation that they were not square. I bought, but rarely use, a pair of hold downs, which only fit in round holes and don't fit behind the vise because the vise mechanism is in the way.
My recommendation would be to build a bench with no holes. If you see that dogs would be handy drill them where they will be handy. Drill a hole in some 2 to 2 1/2" hard wood for a drill guide. Clamp the guide to position the hole on the bench and drill it where it will be most useful to your kind of woodworking.
