In this case if you are not in a major hurry, call up beam compass on a browser. Ebay will be one but not the only response. There you can scope out your choice, 12", more using extensions. If accuracy is your need choose one of the old drafting firms like Post, K&E, or Dietzen. If you can accept only a tiny bit less accuracy I've seen them at less than $20. Because of what they are, you tend to baby them a bit, even so they are substantial enough for the shop with only moderate care. The pictured is up on ebay now under $20
When I was working on a round table recently, I was in need of one. I Googled around and saw one at Wood magazine that looked simple and easy. I didn't buy their plans, but I used their idea.
I can't seem to post a pic. For some reason, I don't seem to be logged in. I wish there was a typical login like other boards. Anyway, the Wood magazine design is quick and simple. I added a micro adjust feature using a block and a teflon bolt.
I'm posting this as an open reply because I've seen other folks do this, too; not to embarrass you.
At some point, you changed the name under which you're posting, from "Tony - Memphis," your profile name, to "Tony-Memphis." Note the lack of spaces between the words and the dash in the middle in the second phrase. This is enough to confuse Wood Central's software.
It's easy to fix. There are two ways to reset things so Wood Central's software recognizes you as the guy in the profile.
Method 1: from any of the message boards, find the “Set Preferences” link at the top of the page (in a box of links). Open this, enter your profile name in the “Personal Information” box, and save. If you haven't specified saving your password as part of your profile, you'll have to re-enter it.
Method 2:
1. Go to post a message, either a new one or a reply.
2. Enter your profile name (as above) in the "Your Name" box on the message page.
3. Enter your password (unless you're previously instructed Wood Central to save your password for your profile).
4. Hit the "Preview" button at the bottom.
For both of these approaches, if your browser is set to accept cookies, Wood Central and your computer will trade cookies, and WC will recognize you by your profile name in future posts.
If you have to delete all cookies or even just Wood Central cookies for some reason, you'll need to do this again to regain the profile access.
If you've set your browser to refuse cookies, you just have to remember your exact profile name (and possibly password) each time you post.
Give it a shot; you should find you've got full access, including picture posting, again.
What kind of trammels do you have? most will allow you to substitute a pencil in place of one of the points. I have A set of Sterretts and used to have a set of Generals that are a coply of the Sterrett design and both will let you pull one of the points out and insert a pencil. I also have a set of sterretts that mount on a beam and they have a seperate attachment that holds a pencil and screws in place of the steel point. Another nice design is the older stanley that has a spot cast in the side with a set screw to hold a pencil with the point still in place.
If you have'nt figured out that I have more trammels than the average tool obsesed wood worker you are correct, and I NEED all of them.
As for a beam compass I found a really nice Brown and Sharpe beam compass a while back for $5 at a garage sale. those old drfting tools have very little resale value today and make excelent lay out tools for small projects.
Yessir, that was exactly it! Thanks very much for the help. I had not noticed the spaces. I should have chosen something I would be less apt to mess up!
So, here is the pic. Not a great one (iPhone). You can see the micro adjust feature. This setup worked very well and was easy to make. Kudos to the folks at Wood for a good idea. I was using it fo veneer work and needed it to be consistent and sturdy. I replaced the old fashioned #2 with a mechanical pencil after this shot. I had to spread the eye hook open a bit. I also made an attachment to hold a #11 Xacto blade. That worked, but there was too much flex to cut veneer well. I then went with a matt cutting blade that worked much better. I also used a trick from Daryl Kleil (Vacupress) - he sugested making a 1/4 round template and using it to guide the knife. That's how I cut the field round after taping.
