Shutter Jigs
Shutter Jigs
Shutter Jigs
John McGaw
Have any of you worked with the Rockler shutter jigs? I've been looking at the price of shutters to fix up my windows and came to the realization that they are just too rich for my limited budget. Then I got a catalog with a 20%-off offer from Rockler which featured their 1-1/4" movable shutter jig setup. I've certainly got all of the wood I'd need or could obtain such at a reasonable price and the jig set cost about what one (small) window's purchased custom shutters might cost. Worth it or not?
Re: Shutter Jigs
Re: Shutter Jigs
Rick Christopherson
The jigs are very good and well designed. The set that you would get for your small movable shutters would include the jig that drills holes in the stiles for the pins and holes in the slats and control arm for the connecting clips. It also includes a second universal jig for drilling holes in the ends of all slats (regardless of size or type).
If you're making a bunch of shutters, the cost of the jigs are trivial and well worth not having to hassle with making them yourself. The greatest benefit is in the louver pins and control rod clips for these particular shutters.
I was going to say that I wrote the instructions for these kits, but then I remembered that there was a last-minute rush and I simply turned over my graphics and draft text to Rockler to finish them up in-house. I haven't seen the final instructions, but as long as they used my draft instructions and the graphics, you will have clear instructions to follow. I used tech-art for all of the detail images (like the one shown below) and photos for each of the procedure steps.
I can't speak for the cost because I have no idea what they cost. But I can speak for the quality of the kit, and I am confident that you won't be disappointed. (I have nothing to gain here, but I was impressed with the kit and the design when I worked on the instructions for them.)
Re: Shutter Jigs
Re: Shutter Jigs
Robin Corell in Atascadero CA
This is an attic vent I made for my house but I used to make shutters like this as a sub contractor for a shutter company. For the half circular ones I used plastic pins simiar to the ones Rockler sells but for the elliptical ones like the one in the picture I prefered wood dowels.
I designed and made my own jigs to drill the holes using a drill press I modified into a horizontal boring machine. It took me a couple of simi cirles to figure out what I needed in the way of jigs and probaby a bit over a day to make them. For a couple of shutters you can do the layout and drilling by hand, but for more than that you would be wise to purchase the jigs and I would also strongly recomend using the plastic pins.
Over all the shutters are pretty easy to make. The hard part is painting/finishing them.
Robin
Re: Shutter Jigs
Excellent work, Robin!
That's a wonderful and unique design. Great job!
Is there a control rod or mechanism for them?
Re: Shutter Jigs
Re: Shutter Jigs
Dave Bair
Norm Abram did shutters for one of his shows. Visit the newyankee workshop site to determine the episode. As I recall, his shop-made jig worked very well.
Re: Shutter Jigs
Re: Excellent work, Robin!
Thanks Ellis, The design of my gable vent was determined by the pitch of the roof and the pre-existing opening with a post in the middle. The ones I did for the shutter company were usually simi-circular with a 3" wide frame. While all the shutters move, in the full simi-circular shutters the shutters left of center and right overlapped in opposite directions with the center louver lying on top of the louver on each side of it. I never figured out how to economically add a hidden control rod.
They look much more difficult to make than they really are, the key is in the layout. I submitted this as an article proposal to Fine Home Building but never heard back from them.
Robin
Re: Shutter Jigs
Re: Shutter Jigs
John McGaw
My recollection was that Norm was making stationary shutters but I could be wrong.
Re: Shutter Jigs
Re: Shutter Jigs
JimG
I also made my own drill press jig. I spaced the louver centers 1", which gave me 1/4 overlap. I then cut a spacer for my jig that spaced the stile to the first hole, then some 1" spacers. I numbered the spacers so as to always use the same sequence when drilling, just to account for minor differences in the spacers.
HTH,
Jim
Re: Shutter Jigs
Re: Shutter Jigs
joseph mulherin,sr
I remember Norm making those shutters. The slats were on a slant and hard set...not movable. they were for outside the windows to be shut when the high winds flew and to protect the glass.
Re: Shutter Jigs
Re: Shutter Jigs
roger lance
There may have been two shows on shutters as I remember the jig for the unmovable shutters.....but I also remember seeing him make shutters for the inside which had the ability to open and close.....I remember an elaborate jig system to place stables accurately in the tops of shutter blades and a corresponding jig to attach a staple through the staple in the blade and then into a thin board that was used to open and close the shutter.....he built these inside shutters for a TOH project in a library in the house.....and he also built some inside shutters as window treatments for his own house.
Re: Shutter Jigs
There are numerous videos available at YouTube
roger lance
on shutter jigs.
Re: Shutter Jigs
Bob
Re: Shutter Jigs
Bob
Here is a great jig for fixed shutters. 1/4" aluminum I found them for sale at the web site printed on the jig. Cost was $85 no shipping unless it changed, I think hes a wood worker he also sells a jig for cutting the parts for segmented bowl turning for about $35.
Re: Shutter Jigs
Re: Shutter Jigs
roger lance
John.....note that this week on the New Yankee Online site , they should be playing the second program of jigs in which Norm builds his shutter jig.
Re: Shutter Jigs
They are showing Norm's fixed shutter jig.
