best place to buy bandsaw blades
Joanne -near Dansville, NY
Where is the best place to buy bandsaw blades?
We just took delivery of a Jet 18" wood/metal cutting bandsaw yesterday!
The blades are 137"
Thank you in advance for your help
Joanne
The blades are 137"
Joanne
Re: best place to buy bandsaw blades *LINK*
Woodcraft Bands
Two options I've used... *LINK*
John in NM
For reasonably priced, quality blades Supercut is a well known blade maker.
I've also spent just a little more on Highland hardware's house blades and found them to be excellent, smooth cutting blades. I've also used their woodslicer blade, which is so smooth you wouldn't think you used a bandsaw for the cut. The price on those tends to prevent their general daily use though.
Supercut
Richard Jones
I've used the Timberwolf blades and the Woodslicer blades, but for me, a much better blade is the Lenox Diemaster-2 bimetal blade. I use a 1/2" 3t skip, .035 thick and buy them from www.bandsawbladesdirect.com I use a 142" on my big Rikon, and a 1/4" 6t skip on my smaller 93 1/2" Rikon.
I would never consider going back to either the TW or WS blades. I know you won't be disappointed.
My $.02.........
Rich
Supercut issue
Yonak
The jury's still out for me, as the issue is not yet resolved, but Supercut may have some problems. I ordered five blades and the weld failed on the first two I used.
They do have a weld failure guarantee. You have to send them back to them and they will re-weld, free of charge, and pay the postage to return them to you. Fortunately for me, I had not yet returned the first blade I tried before the second one broke, so I will be able to send them both in the same box, saving the shipping cost.
I have not yet sent the package, waiting to see how the third blade fares, since I installed it three days ago, so I have not yet tested their free weld policy, but I'm sure they will do what they say they will do.
I have used them no problum Re: Supercut issue
(Message Deleted by Poster)
Re: I have used them no problum Re: Supercut issu
Larry in nw ohio
I also have used Supercut without any problems at all. In fact they worked very well that I am buying all my blades from them. I have split 4-6" oak and Walnut and they cut just as well as any blade I ever used, such as timberwolf and the one from Highland that cuts so well. I wish I could get them to advertise here. Larry
are you frugal?
There will be some place in most places that welds up band saw blades from coils of Lenox or Starrett band saw stock. Ask at your local cabinet shop where they get blades made. You size is about $11 at our local saw shop.
Re: are you frugal?
Philip Duffy
-- - -what Bill said. Far more cost effective than "out of the nice pretty box". Philip
Re: are you frugal?
Richard Jones
No such place near me. Who does yours, Phil?
Re: are you frugal?
Philip Duffy
Surset Saw in Chesapeake but; I order them on the phone and they deliver them to my local Ace Hardware store- - 5 miles up the road- - in ~ 2 days. Nice bunch of guys and good service.
Re: Supercut issue
Thomas S Stockton
I tried the supercut carbide impregnated blades, I had no problems with the welds although on my saw they left a pretty coarse cut . I felt like they had a pretty limited tooth selection so I have gone back to using lenox diemaster 2's. for my use they are the best blade I have found and they last a really long time.
Bandsaw blades tend to be a personal preference item and I would try some different ones until you find one you like.
Tom
Joseph Mulherin, sr
Joanne, I recently bought five blades from www.bandsawbladesdirect.com.
Did about 80bf before I noticed any wear on the teeth.
Bob
I have been using Laguna and see no reason to change.
Re: Lenox makes a terrific blade ...
Rob Sandow
I have always used Lenox Tri-Master carbide blades in my big Laguna saw for resawing work. I have another 12" benchtop Delta saw that I use for scrolling work. I don't find it matters too much what blades I use in that saw. Any decent quality blade works fine there.
Ditto on Suffolk Machinery/Timberwolf Blades
Re: Supercut issue
Yonak
The third of five blades broke at the weld yesterday. I am now convinced that Supercut has a welding problem, at least for the batch of 3/16" blades mine came from. I'm certain the blade was installed correctly and the band saw set up properly. The tension was right (at least on the last two, for sure), the guides are in-line and there are no stresses on the blades. I'm not cutting too sharp of curves and there's no burning or sparks. The blades just snap from normal use.
To be clear, I'm satisfied with the cutting performance of the blades ; they just fail at the weld. Unfortunately for me, I had already sent the two previously broken blades at a shipping cost of $12.64 for UPS Ground service. I think I'll use the last two remaining blades to see if they fail before I return this one for re-welding.
Re: Supercut issue
George Colonel's Workshop-Havertown PA
Good Evening Yonak,
You convinced me to avoid them. I'd ask them to cover ALL shipping charges associated with returns and rewelds.
George
Re: Supercut issue
Yonak
George, before you decide to foreswear Supercut I wish you would wait until we find out how their customer service fares. I spoke with their customer service representative this morning and she said they had not received our return shipment yet and, when they do, they will inspect the blades and determine the cause of the failure and correct the situation. She also said they would make it right with us regarding shipment costs, etc. BTW, a fourth blade broke yesterday. I feel certain it's a problem with a certain batch of welds. Unfortunately, it came on my first order with them.
Re: Supercut issue
John in NM
Sounds like insufficient annealing of the weld. I'm going to guess there is a new guy working there
Re: Supercut issue
Larry in nw ohio
Yes I hope people wait and see what they come up with the cause and what they do about it. I like them and their blades. A lot of the blades are carbide "Coated" at least that is the way it sounds like it`s done. So I think that makes them a little less expensive to make, maybe. Larry
Re: Supercut issue - follow-up
Yonak
Unfortunately, Supercut has determined not to reimburse me or pay for any future returns of the batch of band saw blades that failed at the weld. So far I have had four blades fail, out of five I purchased from them, in a four week period.
This decision was not made by a customer service rep without authorization. I had received two phone calls from them double checking the details before informing me they would not pay for shipping, as a matter of policy, even though they said it was clear the occurrence is outside of their normal experience.
They noticed some pitch on the blades I sent back and said they were sending me some solution, free of charge, to remove the pitch.
That is disappointing to say the least...
John in NM
I don't think I will recommend them to people any more - the little business I do, I sure don't treat customers that way.
How's the tension on the blade ? Supercut issue
del schisler
i have been using supercut bades for a long time and no break's so far, i do resawing and use the 1/2" blade and now i am using the 1/8" for band saw box's and no break's , I just tighten the blade just a little and not over tighten, now i don't have a tension meter, so i go on just enough to keep it from slipping on the wheel's , i have the delta with riser, and use the line on the blade tensioner for 1/8" and that seam's to work, i also run the new blade about 5 min before i cut any wood, i have heard to run blade a while before you cut, don't know if that help's but that is what i do. I used to use woodslicer but it went dull real fast, it was a smoother cut, but after the cut most went thro the planer and that got rid of the cut any way, the suppercut make a ruffer cut but it cuts fast, and so far the blade just keeps cutting, and i do lot's of cutting, i am not changing blades my 2 cent's good luck on yours
