OT Furnace not working
tom
The furnace in my shop will not work. The ignitor does not come on. I check the ignitor with a meter and it is OK. There is no power getting to it though.
Any thoughts?
Re: OT Furnace not working
Bruce, a MN Galoot
I don't know if you have the same type of ignition system, but on mine, there is a thermocouple-type flame detector. It sits just inside the fire box and is a little probe about 3 or so inches long, held in place by a screw. They get dirty. If you have one, pull it out and polish it with either very fine sandpaper (600 or so) or some by fine steel wool. It's a cheap fix, so I hope that's the problem.
John McGaw (Bodger)
What sort of furnace? Gas? Oil? Old traditional type or newer high-efficiency?
Modern furnaces have some 'intelligence' built in and can seem touchy about what they are willing to work through and what they aren't. For example, my older HE gas furnace has an initiator blower which actually sucks air through the cold side of the heat exchanger and blows it up the plastic exhaust stack; the initiator has to start and create a certain level of air flow then it waits for a ten seconds and then it turns on the gas valve then it waits for a couple of more seconds then it turns on the ignitor. If the flame sensor doesn't show activity in a few seconds everything shuts down and it waits for a minute and tries again and after a couple of tries it just gives up and starts flashing an LED on the (invisible) control board buried inside the furnace. If flame is detected and the inside of the hot side of the heat exchanger gets up to a certain temperature the the main blower starts. There is a whole logic tree for everything the furnace does and it doesn't take much to stop it and what did the stopping isn't always obvious.
tom
It is a propane unit. I went through a number of You Tube videos and checked a number of items. I think it it the control module. I have a HVAC guy schedule to come out.
Robin Corell in Atascadero CA
Ive had to fix my furnace 2x in the past 11 years. the first time it was the thermocouple and the last time it was a co2 sensor that is up near the top just below where the flue starts. Both items will tuen off the main control unit if they are not functioning.
Robin
tom
Furnace is fixed!
The HVAC guy came out this AM and I am with heat again. The problem ws the tube that ran from the prssure switch to the draft inducer motor had a build up of crud just inside the draft inducer. He ran a piece of wire through it and BINGO.
That piece of advice was not to be found on any of the sites I looked at. But I will not forget it!!
Larry in nw ohio
I think that was what was wrong with my water heater just early last week. It was a clear tube about 3" long that came out of the blower fan on the exhaust, or chimney, and went to a sensor to let the unit know that the fan was for sure working. On the fan it had a brass fitting where the clear tube is pushed on. So the tube is taken off and a person takes a wire, drill bit or something to open the fitting of the crud so air can flow thru. Sorry I didn`t post so you wouldn`t have had to call out your HVAC guy, but I didn`t really know what you had or what to call the parts or where they are on your furnace. I called my HVAC guy and being the really nice person he is and the kind of repairperson to have, he just talked me thru what he thought it should be. He saved me $50 or so. He doesn`t send someone out if he doesn`t have to, and if he knows the customer kind of knows what he is doing, not that I do, I just got lucky. Everyone have a GREAT and SAFE Christmas. Larry
