insulation
insulation
insulation
Larry in nw ohio
The shed I built about 5 years ago got very well insulated, but has 2 35x35 inch windows in it, and I really do not like windows very much especially in the winter. So I`m putting in 2" styrofoam to plug them, so they keep the cold out. I had a hard time cutting it. A butcher knife cut the best, but I thought about it a just happen to mthink jig saw, but with the teeth, I`m going to have stuff allll over, but when I was looking there was a toothless blade and wondered what the is that for, so I put it on and that little devil cut like like melted butter. Did anyone know that, I never seen that on the boards before. So I assume that is what a knife like blade is for? Larry
Re: insulation
Re: insulation
Robin Corell in Atascadero CA
I didn't know the jig saw knife blades cut styrofoam. They are typically the go to tool for cutting uhpolstery foam. I have also seen video where they are used to cut trough several dozen layers of fabric.
I have some light weight 1x2 frames covered with aero foil that I hang in front of two west facing windows durring summer heat waves. They work so well I have plans to build some storm shutters with the areo foil between two layers of wood for permanant installation on those windows. I actually have the same foil coveres on the windows at night right now due to the cold and they seem to help a lot for that as well.
Robin
Re: insulation
Re: insulation
John Veerkamp
Electric carving knife works great on foam, both kinds. Steal one from the kitchen, or they are cheap at thrift stores.
Re: insulation
Re: insulation
Larry in nw ohio
I tried an elec. knife years ago and I thought the saw did a little better. But to each his own. I don`t have a knife anymore so I used the saw. I`ll have to get an elec. knife, if I can find a cheat one, just to see how it works. Larry
Re: insulation
Re: insulation
John McGaw (Bodger)
I've tried the electric knife and found that it did a great job on high-density upholstery-type foam but was not quite so good on low-density foam and did pretty poorly on rigid insulating foam. Cutting with a razor knife and a long metal straightedge is a real PITA but it has always given me the best results with the closed-cell styrene stuff. A hot-wire cutter would be the absolute best tool but that isn't something that most folks have ever heard of let alone used.
Re: insulation
Re: insulation
Joseph Mulherin, sr
Years ago i had the position of cutting some insulation and I used a coping saw frame and attached a 12v battery to each end to get the electricity needed to heat the metal to do the cutting....worked out just fine. But, you should look to not let the ends meet before the cool else the will melt together again.
