A question about my table saw
Chris Miller
I have an old Craftsman 8" table saw. It has worked well for me for years, but now I have a problem. The belt broke on it last year and I purchased a "V" belt from a local car parts store. I think it has run since then, but not sure how much. Now when I turn on the table saw the motor starts up but does not get up to full speed. Usually I can hear a click when it hits top constant speed. It tries to get there then I hear what sounds like a belt slip and it never makes it to the top speed. The blade simply does not run fast enough to cut any wood. I took it apart and tried to oil the bearings, but I could not get access to the actual bearings, so i just sprayed wd40 on the outside of the bearings. I still have same problem. I take the belt off and start motor and it hits top speed with click easily. I wonder if it cannot take the type of belt I bought for it.
The model number is 103.22170
I believe I just saw one of those for sale on here.
I could use any advice
If it is the belt, what kind of belt do I need?
Thank you,
Chris
Re: A question about my table saw
Keith Newton
Automotive belts are not the same as Fractional power V belts, so you are right in your assumption. The V angle is not the same, and they may be stiffer, but I'm not sure that is all the problem you are having.
What is the HP of your motor?
My first thought, is that the new belt may be a bit too long, for the gravity of the motor to provide the tension, or maybe the belt ended up riding on the motor shaft beside the pulley. Either of these would produce the slow weak blade speed.
Re: A question about my table saw  *LINK*
Hard to understand how the belt itself could be causing the problem, unless it's binding against something as it runs. You might try unplugging the saw and, with the saw/motor set in its normal configuration, turn the motor pulley by hand and see if there's evidence of binding.
The belt should not stick out past the outer edge of the pulley, nor should it be nestled so far down into the pulley that it bottoms out. V-belts come in different sectional sizes; you may have one that's too large in section and rubbing against something.
It's possible also that there's something internal to the motor that's not healthy, and unable to handle the extra load of the blade/bearings. I don't know enough about motors to offer much helpful advice here, though.
You might amble over to Old Woodworking Machines, link below, and pose this question, too (you have to register first, as with many websites).
http://owwm.org
Mark Hennebury
Most likely something simple:
probably to do with the belt if it was working before you changed it.
Could be the bearings; they don't last forever, and it never hurts to put in a new set of bearings.
Try and isolate were the problem is;
Unplug the motor and do a good visual inspection to see if you can see any thing that might interfere.
Turn the saw spindle by hand see if you can feel or see anything.
Take the belt off and rotate the saw spindle, check that its running freely.
Turn the motor spindle check that it is running freely.
Plug it in and run the motor, see if that's running fine.
unplug it and put the belt back on then plug it in and turn it on.
If everything is running fine until you put the belt on then its to do with the belt either wrong size, angle, width, length, tension, stiffness or binding against something etc.
You can usually find the problem by the process of elimination.
Al Stokka - Cambridge, Iowa
Chris,
All of the symptoms you listed point to bad arbor bearings. I think the belt broke because of the bad bearings. Replacing the belt didn't fix the underlying problem.
A new belt, even grossly missized, wouldn't cause the problems you're encountering.
Al
Lee Schierer McKean, PA
Keith has the correct answer. Automotive belts are different than industrial drive belts and cannot be interchanged. You need to go to an industrial supply that carries drive belts. Look on the internet or you yellow pages for one. "Gates" is a good brand of belt, but there are others. If you can take a pulley with you so they can size your belt. Most likely you need an "A" sized belt. You will also need to know the proper length to get the correct operation. If the saw was working fine up until the belt broke then it will probably work fine again once you have the correct belt in it. You can check to see if the motor gets up to speed without a belt, chances are it is okay. The like shows the cross sectional dimensions of various v-belts.
Lee
V-belts sizes
del schisler
my take is that is the belt is riding up on the pulley's than it is to big. It should be down in the pulleys not on top. The click you here is the start run plate inside of the motor on the end opposite of the shaft. If the motor run's at top speed 1725 rpm's probly the belt if the arbor turn's easy. When belt it riding high on the pully's it is like changing the drive belt to a different dia. and that may be too much for the motor to turn. As far as using WD40 for lub is isn't oil, the WD stand's for water displacement . Most of the beiring's are sealed any way . If you can turn the shaft and it turn's and than stop's the beiring are ok. If motor doesn't get it to top speed with the belt off could be the start run plate inside. It should slide on the shaft easy so when the motor is first turned on it will than move up the shaft to the other point contact's which put's the other winding for full speed. my 2 cent's good luck
Re: a reply
Chris Miller
These are all such great replies. Thank you. The arbor bearings seem to turn fine. When I spin the shaft it turns maybe 3-6 rotations then stops. Feels like a nice greased up bearing, but I do not have anything to compare it to. I am not sure if the belt is riding on top. When I take the belt off and run the motor it hits top speed fast and stays there. I do not think it is the motor. I may look for a belt today. I wish I could find a manual on this thing to know what kind of belt to put on it. The sears parts website does not show any parts for a table this old.
Larry in NW Ohio
Chris First off never use WD40 for lubricatinf anything, as said before it is not a lubricant. It will actually clean the grease out of the bearings. Now for your problem, you have had some great responses. First, how big is your motor, like in HP? Make sure your pulleys are tight and that the motor is not stopping on something and not able to make the belt tight enough that it may be slipping.Thats about all I can add to what everyone else has said. If you still have your other belt, take it to a place that handles belts and bearings. Do you have anything like that around you close. Good Luck. Larry
David Bair, Eaton Rapids, MI
You said "Usually I can hear a click when it hits top constant speed." That click is probably the run capacitor of your motor. If you don't hear it anymore, it's stopped working. Fixes run from blowing out any captive sawdust to replacing the capacitor.
Rod Peterson—Ormond Beach, FL
This may or may not be any help, but here's a manual that might prove useful:
http://vintagemachinery.org/pubs/detail.aspx?id=1159
There's a link there to download the PDF. It's for a '160 instead of your '170, but Sears saws shared most of the internals over the years despite changes in cosmetics.
Incidentally, if you didn't know, the "103" indicates the saw was manufactured by King-Seely. The rather more common Craftsman saws with a "113" prefix were made by Emerson Electric.
Rod
K Anderson
The OWWM web site mentioned above may have the manual for your saw. Look under the Manufacturers index then Craftsman in the list and it will be under publication reprents if it is there.
Chris Miller
I have looked all over for the speed of my motor. It is not on the motor, or the section has been worn off. I believe it is a 3/4 or 1 hp. It is a craftsman 113-19240. I found a 113-19040 and it was a 1 hp (if that means anything). I will look for a belt.
Chris Miller
David,
I can hear the click every time when it was working. I can hear it now if i run it without the belt on.
Chris
I believe the motor is a 3/4 or a 1 hp. It does not say on the motor (too worn)
take a pulley with you to the belt place
del schisler
seam's like a 4L ??? is what mine used I now use a link belt which it the best for saw's. good luck. I bet it is the belt
probly doesn't have a start run cap,
del schisler
i bet i uses a start run plate inside on older motor's ?
did you go here  http://www.ereplacementparts.com
Re: probly doesn't have a start run cap,
Bruce, a MN Galoot
Mine has that centrifugal switch on the end of the shaft that clicks out when it gets up to speed. They sometimes just need cleaning so they can move freely. After 40 years the one on mine just wore out.
Chris Miller
Well, I could not find the manual for the 103.22170 craftsman table saw. I found 103.22160 and just bought the belt on its parts list. The belt is too long. I found the original belt that I replaced and it did not fix the problem. I honestly do not think it is the belt. I think it may be the arbor bearings. I just went out disconnected the belt and turned the blade by hand, it did not freely spin on its own at all. It did not bind up or catch. The pressure on the belt is by the weight of the motor. I tried to left up a little on the motor and push down a little, no improvement. I have no clue how to get the arbor bearings out. I watched a videa on you-tube and he used a socket to unscrew a thin nut holding the bearings in place, I see no such nut hold my bearings in. I have a feeling i will not be able to change out the arbor bearings.
Chris Miller
Lancaster Ohio
Re: take a pulley with you to the belt place
Chris Miller
I saw the once similar to mine used a 4L-400. So I went out and bought one today, it is too long. I found the old one I replaced. I put that on, same problem. I am starting to think it is the arbor bearings and not the blet.
If your bearings are that stiff, you may have found the problem. If they are that stiff I would think running the saw for a minute or two would cause them to get HOT. You could try that and it may answer the question.
One thing that has not been mentioned is that sometimes the key comes out and the set screw is loose. The pulley just spins on the shaft. This happened to my motor pulley. Several times, until I used Loctite and put in a second set screw.
I thought table saws were fairly generic and I am assuming you are going to have to turn the saw upside down and remove the arbor/trunion from the saw and then you should find the bearings are pressed into the assembly. Unless you have a bearing puller and are comfortable doing it you should take to a machine shop or bearing shop if they offer the service. That part (Pressing the bearings) should be fairly reasonable. The bearings should be a fairly common size. Buy the best you can afford. Then watch Utube videos on tuning the saw because removing the trunions means you start all over on most saws.
Chris Miller
Thanks for all the replies. The problem is not the key, it is always firmly in place. I have turned the table upsidedown and removed the assembly several times these last couple weeks. I do not have a bearing remover, but since I am a retired hs teacher, I am good friends with the old metal shop teacher. I am giving him a call this afternoon after church. i will let you know my progress in replacing these bearings.
Chris
Re: A question about my table saw  TRY HERE
del schisler
if the arbor will not spin easy than that probly is the problum. It will just get worst when the motor try to spin faster it will not get past a certian speed it just hold's back . I found this link also go here and see if you can get any answare's
http://lumberjocks.com/topics/41661
I am a "do it myself" kind of guy and I know just enough about this kind of stuff to mess things up. OTOH, it does not make sense to spend good money on new bearings and then beat the heck out of them and ruin them trying to install them. Its good to have talented friends with tools. Some bearings are pressed in, some are held by retaining clips, and some have nuts or other devices holding them. Sometimes its obvious and sometimes obscure. Buy your friend a beer or lunch and let him do it. At worst, new bearings can't hurt even if it turns out not to be the problem, but it sounds like you have narrowed it down.
Chris Miller
Here is the latest... I called my buddy who is a metal shop teacher. He told me that if I can easily turn the arbor bearings then chances are the arbor bearings are not bad. He said it is probably the motor. I dont know if this "test" worked, but i held onto the pully and turned on the motor and I was able to stop it from turning pretty easily. I did the same thing to my old craftsman bandsaw and I was unable to hold it. So, I was about to call the local electric motor shop until I found this deal. Someone was selling an old craftsman tablesaw (113-?????) for $50 and it works and it comes with the fence and guide. I asked if that was his lowest price and he said "yes, but Ill throw in a 4" jointer" I was just looking for a jointer!!!. So, now I am waiting on that deal (this weekend) and putting my original table saw on hold. I may just look for a motor next year at yard sales and auctions. I will however take the motor off this new one and put it on my old one to make sure that is the problem.
I want to thank everyone for their help. This is a great site!
Thanks
Dr. Chris Miller
