Show me your models!
doug f, san clemente, ca
Over the years, I've gotten in the habit of building models of projects to get an idea of proportions, possible joinery, and, believe it or not, ideas on glue up for complicated projects.
The models I make are mostly pretty crude; 1/8" BB ply or balsa wood with no attention to detailed joinery.
My question is: how detailed are your models? Drawers? Joinery? Adherence to proportional stock thickness?
Pictures would be wonderful.
Thanks for any advice.
Doug
Re: Show me your models!
I rarely make models
Bill Tindall
For things that are orthogonal a scaled drawing suffices to get proportions right. But for the few things I have made with curves it was another story. Only a 1:1 scale model enabled me to get the curved parts right. I have used what ever is at hand- thin plywood, cardboard, carved softwood, "scrap wood", etc.
Bob
Re: I rarely make models
Bob
I just started using Sketch up and I like it so much I am going to buy "Sketch up Pro" The learning curve for me is less that what it would take to build a model.
roger lance
I rarely make a model....usually, its drawings....but I did make a little mock-up of my bench which I've keep in the shop....the general shape and proportion are the same but I eliminated the right side door/shelf for another set of drawers....
I do think it is good practice to make a model....a lot can be learned/solved with a 3D representation....perhaps I'll do more in the future with furniture. Models were invaluable in building houses....for all concerned.
Jesse Cloud
I don't make models sturdy enough to last, so they usually go into the trash pretty soon. I find models useful when there is some uncertainty about how a piece will fit in its environment.
The wife and I went back and forth for a while over whether the dining area could accomodate a table for twelve. Once we assembled a cardboard "tabletop" we knew right away.
I think its important to make models simply and easy to change - they are a learning vehicle and you may learn more if you are willing to try different approaches and "sneak up" on just the right proportions.
One exception, I always make a quarter sized and a full sized prototype (or more) of a new chair design.
a few pics of some models
Robin Corell in Atascadero CA
I actually make a quite a few models. I use bass wood exclusively because of its near absence of visible grain makes it more believable as a scale model, plus it is easy to work with. I usually omit some of the fine details such as edge profiles, handles, and joinery. When I first started making models I never put any finish on them but now I put a coat of General’s HP poly to keep them from getting dirty finger prints.
I do my best work when I just start building full size with the intended final wood, with no drawings or model but for some reason clients don’t want to give me a pile of money and let me surprise them. So my solution is to make a model. That way I get to have the freedom of designing by making and they get to see what they are commissioning. By milling out the wood for the scale model to match the size of the stock on hand and using a few scale references such as height I end up with a scale model that becomes my blueprint for the full size version.
It actually takes me less time to make a model than to make a set of working drawings and my designs typically have a lot of curves so they are easier to understand by viewing a model then an orthogonal drawing. For me light is an important element of 3-d design and being able to set a model in front of a client and have real shadows become part of the design is invaluable.
Here is a design I did for a bench for a winery.
The shape of the seat was inspired by a flowing stream and the client liked that part but not the legs. She asked if I could make the legs out of water and I came up with this
Based on this model I received the commission and the only changes I made as I built the full size bench was the stretchers protruded thru the ends of the legs. The carved detail on the legs is one of the few carved textures I do that translates well when reduced in scale. This is one of those models where the shadows are very much a part of the design and they would have been difficult to show in the same dynamic way that they are in scale model.
Here is a model of a case goods design just to show how I handle those. I glue up a large block of wood to represent the case (I use ca glue for everything in my models) I drew the rails and stiles in pencil as well as the drawers but did nothing for the handles. The model is about the overall shape, not the details of the joinery. This model is 17" tall and the actual cabinet is 64" tall, the cabinet was built exactly as the model.
At the risk of making this way to long I will close with a final model of a head board that I would not have gotten the commission for without using a model. This was built so true to the model that I get the thumbnails of the model and the completed design mixed up.
Robin
Re: a few pics of some models
Wow; Robin, those models look much better than my finished projects. The revised legs on the bench are gorgeous. Thanks for the pics.
Doug
